fiesta si 1800 105ps Deep ECU query!
18 posts • Page 1 of 1
hello, I have a fiesta Si with a 105ps engine from a L REG escort and i want to make it the 130ps. i've got the 2ltr camshafts and maf from a mk1 mondeo M REG but it had different inlet manifold so i couldn't get the throttle body and the ecu was wrong, but i can get hold of a DEEP ecu from ebay, but will all this combination work together? cheers, any help welcome, really need to get this going.
- fiesta_rst2
You can use the Mondeo throttle body but you need to switch the linkage for the Fiesta/Escort one and grind away the throttle stop on the throttle casting to allow the butterfly to open fully.
Match the MAF to the ECU spec - 2.0L to 2.0L, 1800/105 to 1800/105, 1800/130 to 1800/130 and so on.
Best of luck!
/al
Best of luck!
/al
- Project
- fiftyoneCL
Not off topic, but a hijack!
I've got a Mondeo 1.8 ECU which I presume will be 115ps?
I've got a Escort 1.8 MAF which I presumt will be 105ps?
Should I match these both to the same spec? Just wondering as it hesitates when pulling away sometimes if I plant it
- PaulC
right so i now have 2ltr cams, throttle body and MAF. Will a deep 2ltr ECU work with all this on my 1800?
- fiesta_rst2
Project :You can use the Mondeo throttle body but you need to switch the linkage for the Fiesta/Escort one and grind away the throttle stop on the throttle casting to allow the butterfly to open fully.
Best of luck!
/al
Project you seems to know your stuff
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
The DEEP ecu is not compatible with the 1800 cc engine. Calibration data is different for a whole range of items, e.g. MAF, engine size, injector size, fuel tables, spark tables and many more besides. This infomation is critical to getting the fuel and spark timing right and swapping ecu's without thought to the consequences will ruin your engine.
- sailorbob
to make a 105ps 1800 the 130ps 1800 you do need a 2ltr ECU, it is a known fact i just need to know if a deep ECU will work with all my other bits from the 2ltr mondeo with the wrong ECU.
- fiesta_rst2
I am using a DEEP ecu on my 2.0, I do believe that using the DEEP ecu, 130ps (2.0) cams and a the 2.0 throttle body will work nicely.
As for this it not matching the engine cc etc, so what? yes the engine will be harder pushed as it will be producing more power. in swapping all the parts needed you are making the 1.8 flow air, flow fuel and spark the same as the 2.0 hence giving it more power.
Like I said I am running this setup on my 2.0, but with the same idea If i was to swap my bottom end for the 1.8 it would still run the same.
- Percy!
- Your car: Citreon
Having re-read the original post, I'd have to agree with Sailorbob - the 2.0L map is designed to produce the extra torque of the bigger and slightly-better flowing 2.0L lump; the 1800 won't be too happy with it.
Track yourself down an 1800/130 setup like wot 'e sez
Ollie - could probably do with the right (115) cams to match that lot; I'm guessing the miss is related to overfuelling.
Also worth trying to match the injectors to the engine output as Rhinopower swears the Zetecs all used different flow-rated injectors depending on output power.
/al
/al
- Project
- fiftyoneCL
No it isn't, this is a common mistake people make. Ford didn't use a 2000cc ecu on the RS1800 to get 130ps, they used an ecu set up for an 1800cc. Please try to use one of these and convert to external EDIS.fiesta_rst2 :to make a 105ps 1800 the 130ps 1800 you do need a 2ltr ECU, it is a known fact
I agree, manufacturers try to fit the smallest flow injectors they need to keep emissions down.Project :Also worth trying to match the injectors to the engine output as Rhinopower swears the Zetecs all used different flow-rated injectors depending on output power.
- sailorbob
right ok so does anyone know what the right part number i should look for?? do rs1800's have internal edis or external edis?
- fiesta_rst2
Any help?
Mk5 Xr3i ECU codes:-
105.......92/93......92FB12A650CD (short code 2FCD)
105.......92/93......92FB12A650CE (short code 2FCE)
105.......94 on......94FB12A650BB (short code 4FBB)
130.......92/93......92FB12A650BC (short code 2FBC)
130.......92/93......92FB12A650BD (short code 2FBD)
130.......93/94......92FB12A650BE (short code 2FBE)
Fiesta RS1800 ECU code:-
130.......92/93......92FB-12A650-DD / ALSO
EDIT: years added to ALSO ecu
- sailorbob
sailorbob :Fiesta RS1800 ECU code:-
130.......??/??......92FB-12A650-DD / ALSO
Is there a change from ALSO for the later codes as you have eluded to in the other thread?
- Ollybee
Did you say you might be able to replace the code on another ecu? Do you have the code for a CULT ecu? If so how much would you want for sorting me out if I provide a GURU ecu?
- Ollybee
Unfortunately I don't have any rom code from any RS1800 ecu (though I have tried to borrow the ecu's to no avail). If I could get this to work I wouldn't want payment, you simply supply a replacement blank chip and be the guinea pig
- sailorbob
Sounds like a fine plan. I'll keep you informed!
- Ollybee
