Fiesta Oil Usage
8 posts • Page 1 of 1
Fiesta Oil Usage
My Fiesta seems to use up quite a bit of oil. On a 200 mile run it can drop from the MAX to the MIN mark and I have to regularly make sure it's topped up with town driving too.
Is this kind of oil consumption typical of Fiestas or is it a sign that I'm leaking/burning it somewhere?
Cheers for any help!
Will.
Will.
- willobrien
What sort is it?
My mum's 1.0L engine burns almost as much oil as petrol. However my old 1.6s CVH engine also had this for a while
Turned out some rubber seals somewhere inside had perished so the oil was being burnt. You could tell cos there was blue smoke when starting up.
Anyhow my engineer replaced those rubber things for the cost of £20 and it paid for itself in a month. Oil hardly went down at all after that and no blue smoke either. Bargain.
- Stoned
Stoned :What sort is it?
Stoned, you're talking about Valve stem oil seals.
- MikeyXR2i
snake :mk3 classis? 1.1, engine rebuild time probably unless its obviously stem seals(unlikely) or u gotta leak..
1.1's usually suffer from worn rings.
Easiest and cheapest is to replace with a known decent engine
John
Audi quattro turbo
- bowdenj
