Fiesta mk2 - ready for ford fair !
Re: Fiesta mk2 - lucky escape
Postby Fraggle on Wed Aug 17, 2011 2:44 pm
:lol: :lol: Gotta love the mk2...Mine exploded last night :rolleyes: :( ,,Dont suppose ford still sell genuine rear bearings for em anymore...Quentin hazels all the way now then :(
On a brighter note she looks lovely fella...and yes im still alive :P :P :P Not that you bothered :( :(
Fraggle
Postby knuckles on Wed Aug 17, 2011 3:37 pm
after using a puller i borrowed from work to remove the drum then cracking the drum outer removing it. The outer bearing has chewed up the spindle. So axel is scrap now.
Ive therefore been sourcing parts to renovate the rear end.
Brand new adjustable panhard rod - from xrtwo.com
brand new genuine ford brake shoes, wheel cylinders, brake adjusters
brand new non ford brake drums
brand new non ford wheel bearings - ford no longer service them.
Brand new genuine ford rear axel
axel and drums have been dropped off this afternoon to be powdercoated black. So tomorro will be all systems go to get old axel off and fit all new parts. Pictures will follow shortly :)
knuckles
Your car: Fiesta Rs turbo
Postby MK2 Jamie on Thu Aug 18, 2011 2:54 pm
knuckles :after using a puller i borrowed from work to remove the drum then cracking the drum outer removing it. The outer bearing has chewed up the spindle. So axel is scrap now.
:o
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby knuckles on Thu Aug 18, 2011 9:08 pm
This is a going to be a huge update. I got so many pics i dont know where to begin....
After borrowing a gear puller from ford to remove the drum i found out what the damage was
This is the deverstation the outter wheel bearing has caused. completly mullered the spindle - making the axel scrap
I decided to go for a new axel over a 2nd hand jobbie. Ordered it from ford
Old axel removed.
drums, trailing arms, handbrake cable, brake lines, wheel cylinders, shoes, shocks, springs & backplates all removed.
New axel powdercoated black - shock absorbers refitted
Brand new drums - powdercoated black too - brand new wheel bearings fitted
New spindles :D
axel bolted back onto car this evening.
I had to replace the drums with no shoes or handbrake connected as it began pouring down with rain once again. Even under a tarpourline i got completly drenched. Car is back on 4 wheels for now until the weekend when i can refit the rear brakes and bleed up the system again.
Working outside in the street is a right baxtered ! :rolleyes:
knuckles
Postby Ghost on Thu Aug 18, 2011 11:38 pm
Told you you would break it before Ford Fair :lol:
Ghost
Postby rs-tom on Fri Aug 19, 2011 12:12 pm
Nice work mate . I need to do this soon on my mk2
rs-tom
Postby HCS PIMP on Sat Aug 20, 2011 9:06 am
gutted least you know the rear end is spot on now. Had a similar problem a few years back with my mini was driving to leeds front wheel locked up stopped the car at 30mph
pulled over and jacked the mini was nothing that I could see wrong when i took the wheel off the brake caliper dropped to the floor with a clunk
it sheared the caliper mouting lugs and one of the bolts was gone
this is why I never skim on brakes
HCS PIMP
Postby knuckles on Sun Aug 21, 2011 9:47 pm
New shoes , new cylinders & new brake adjusters fitted.
1st time ive ever attempted shoes and it took me about a hour to do both sides properly.
All rear end is back together now - test drive is tomorrow :D
on other news i have done other bits a few weeks ago prior to ford fair so here are the pictures
New header tank & cap + new alternator
knuckles
Postby Smo on Sun Aug 21, 2011 10:24 pm
That washer bottle alone does it for me :D
I love your car though, so much more of a sleeper than mine, I reckon!
Smo
Postby knuckles on Mon Aug 22, 2011 10:51 pm
Smo :That washer bottle alone does it for me :D
cheers simon :D
its a expansion bottle though
we should have a race once u sort your gearbox gremlins :wink:
knuckles
Postby Smo on Mon Aug 22, 2011 10:53 pm
It was a long day yesterday, I knew what it was, I just wrote the wrong thing :lol:
Smo
Postby knuckles on Tue Aug 23, 2011 10:17 pm
im considering some xr2 pepper pots :D
knuckles
Postby Excursion on Wed Aug 24, 2011 5:53 pm
Get it thoroughly waxed, Clark, before the real bad weather sets in :)
Postby jayrs on Wed Aug 24, 2011 9:22 pm
told ya it wouldnt be much hassle doing the shoes, dunno what ya were worring about. :lol:
looking good though mate, and pepper pots, na, dont bother, they look alright on some xr2's but dont do it mate, theres better wheels out there
Postby knuckles on Wed Aug 24, 2011 9:45 pm
Excursion :Get it thoroughly waxed, Clark, before the real bad weather sets in :)
ive been eyeing up the waxoyl sprayer in halfords for quite a while.
is it easy to use ? :-?
never done it before
knuckles
Postby Excursion on Thu Aug 25, 2011 8:30 am
knuckles :
I've not used it mate, but if it's a pressure pump type thing it should be pretty easy. If you don't want to buy the gun then I recommend this: http://www.ebay.co.uk/itm/DINITROL-3125 ... 19c81b96d7
it's amazing, you heat the cans in warm water and when spraying you can see the wax come out of the seams! For the rest of the underneath you can just use a brush for the Waxoyl.
Postby knuckles on Thu Aug 25, 2011 7:53 pm
how many cans of wax would do a car mark you think ?
ive already waxoyled the outter sills with the brush on stuff :)
knuckles
Postby - Danny Boy - on Fri Aug 26, 2011 10:59 am
Clark, I used the spray can waxoyl you can get in halfords, managed to do the whole of the underside of my car and sills with 1 big can of it, but I would perhaps recommend 2 cans of it depending on how you apply it. I dont know if thats what you was saying about the sprayer, but I thought id have my input just in case it is lol
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Excursion on Fri Aug 26, 2011 11:13 am
4 cans of Dinitrol should do most of the key hidden areas: I did inside chassis sections, inside the car behind the wheel arches and around the front wheel arches. The attachment you get with the Dinitrol is pretty good as it sprays out the wax in a 360 degree pattern inside the box sections :)
You will need some surface protection wax (its a bit thicker) for the rest of the underneath, I use Waxoyl for this as it's just as good for surface protection but works out cheaper.
If you want to stick with Waxoyl for the lot then what I have done in the past is to thin some of it with Parrafin or petrol then use a garden spyrayer or something for the box sections.
Postby knuckles on Sat Aug 27, 2011 6:05 pm
cheers for the info mark & danny.
the thing im dreading most is removing the rear door cards. which means rear bench out and rear parcel shelf supports :rolleyes:
very time consuming :lol:
knuckles
Postby rs-tom on Wed Aug 31, 2011 8:54 am
Could u get me a new expansion tank.
rs-tom
Postby knuckles on Wed Aug 31, 2011 8:59 am
rs-tom :Could u get me a new expansion tank.
£56.93 + p&p for the expansion bottle less cap
i accept paypal :)
knuckles
Re: Fiesta mk2 - 2.0 zetec sleeper
Postby knuckles on Thu Sep 08, 2011 9:45 pm
not much of a update but i find these little things make the car a much nicer place to be :)
The xr2 steering wheel jay kindly sourced me had a worn out badge on the center cap. Of course a new center cap is no longer availible from ford so i got in touch with DMB graphics.
One brand new Ford gel emblem :Q
i used a nail scrubbing brush with hand soap to clean the center cap and remove the last remaining bits of print off the metal badge
badge fitted
Reffited to the car - much better ! :aviator:
knuckles
Postby jayrs on Thu Sep 08, 2011 10:40 pm
that looks much better mate!
Postby Smo on Thu Sep 08, 2011 10:44 pm
I love your car :D
Smo
Postby ben17southport on Sat Sep 10, 2011 11:10 am
nice to see you sorted it bud. wouldn't mind having a go at claying my car. was it a kit you bought or was it all seperate? and off a website?
thanks, ben
fifi
ben17southport
Your car: Ford Fiesta mk3 Si
Postby knuckles on Sat Sep 10, 2011 8:21 pm
ben - i bought that megulairs kit from halfords. Was just over £20. i would of paid double for the end result it gave. :)
knuckles
Postby ben17southport on Sat Sep 10, 2011 10:49 pm
yeah it looks awesome! just got rid of the sap like that?
will have a look mate, dont mind spending that much on a kit that will sort a few things out and give a finishing result like that! :Q
fifi
ben17southport
Postby knuckles on Sun Sep 11, 2011 4:19 pm
ben17southport :yeah it looks awesome! just got rid of the sap like that?
I was dubious at first whether the kit would work or not. But it done the trick !
The kit done wonders on the 23 year old paintwork. I tried everything to remove the tree sap and ingrained road grit. Tcut wouldnt shift it - neither would tree sap remover ! :lol:
The clay bar and detailing mist got everything off leaving a glass finish ready to wax :D
claying the paintwork for the 1st time takes quite a while - but when you come to do it again it will be so quick and easy.
knuckles
Postby Fraggle on Sun Sep 11, 2011 4:42 pm
lucky with that bearing :o ......just doing both mine now :(
Axle was a lucky find fella... :Q
Looking lovely.. :wink:
Fraggle
Postby knuckles on Sun Sep 11, 2011 8:12 pm
lucky find ?
Its still availible from ford main dealers while stock at daventry exists.
knuckles
Postby Fraggle on Mon Sep 12, 2011 9:44 am
knuckles :lucky find ?
Pricey?
Fraggle
Postby knuckles on Mon Sep 12, 2011 2:20 pm
£415 inc vat
knuckles
Postby Ratspeed on Tue Sep 13, 2011 8:59 pm
Not tooooo bad that price i suppose. I bet its hard to find a £20 quidder in the scrap yards though
Ratspeed
Postby ben17southport on Tue Sep 13, 2011 10:11 pm
knuckles... was in halfrauds today buying a bike... the kit was £24.99... baxtered... is it cheaper on tinternet or not? would have bought it if i didnt have a huge ass box with me!
fifi
ben17southport
