Detailed guide to fitting rs/xr2i skirts/arches...UPDATED
Postby craigc38 on Thu Apr 13, 2006 3:44 pm
Put my kit on this morning, thought i would share my expirience.
Tools...
- sealant/bonding (i recommend tiger seal or sikaflex) with gun
- drill with drill pieces for metal
- 1 roll of wide masking tape
- roll of tissue
- bucket of warm water
- rivet gun/rivets (i used original ford ones, available from ford for £6.54)
- minimum of 4 G-clamps (plastic ones if possible as they are lighter)
Ok start by laying you kit out on a smooth surface to avoid scratching, then 1 by one hold the each part against your car in place to see if it goes well against the body, the smaller arches are your front ones and obvously the other 2 larger ones are the rear then you got your skirts.
Starting with the front i held the arch in place and masking taped it in place while a drilled a hole in the body at the bottom near the door where your hole is in the arch, then I riveted it in place
Might be a idea to have some masking tape torn off and ready to apply (stick it somewhere on the car witin reach)
You can still move the arch about (up and down and towards you) enough to squeeze some sikaflex all along the arch including the little humps that run along the inside of the arch.
Once you have got a sufficient amount on there push it againt the body and mask it up tight again the body of the car, you might need to use one or two of your clamps here, if so use em! If you get any of the glue on the car where you dont want it get some warm water and attack it with a cloth straight away as it wont come off if it sets, so could be a idea to keep the bucket of water and a cloth close to hand
Repeat this for the other side and then the rears (rivet the rears where the jack cover are). Make sure you mask it up well and check to make sure its stuck tight.
Now the skirts... alot easier, slot one end in to the front arch and the other end just sits on tope of the rear arch, line tem up untill you are happy then mask it up to hold it (I found i had a half inch gap between one of my arches and the skirt but still looked fine.
Once your happy and have it masked up, start with drilling your 4 holes for the rivets (holes are already in skirts so it would just be the car) once done go ahead and rivet it in.Repeat this or the other side... rest assured they will not be falling off!
Its up to you how you do under the skirts.. either self tappers or rivets, i have not got round to the underside of mine yet but its not noticed and they dont hang down at all.
Make sure you leave the arches tapped up for 24hrs to allow for the sikaflex to dry.
I will post pics of completed job tomorrow... mine is still drying :p
Ok removed tape/clamps this morning, this is the result...
im lookin to swap for a diesel or reliable golf, anything considered
craigc38
Location: xr2i spares to be collected from hounslow tw3 4lr
Postby AGAR on Thu Apr 13, 2006 7:00 pm
Great guide - im doing the same in a few weeks time.
Only thing is, i imagined it would be better if you added the bonding solution straight onto the arches and then offered the arches up to car and secured them, you'd get much more bonding solution on (and therefore a stronger fit) than your method which seems just to add the solution between gaps in the masking tape.
on my arches theres a bit of sponge-like material along the upper lip of them on the inside - is it best to remove this?
AGAR
Postby craigc38 on Thu Apr 13, 2006 7:20 pm
i got the same, i left mine and they still press up fine, the whole job took me 2hrs and i have never done it before so u got nothing to worry bout.
i found my way easier but we all have our own tactics, let us know how u get on m8.
rgds
craigc38
Postby AW3K on Fri Apr 14, 2006 12:33 pm
Nice one craig top work :)
with craigs perrmission this guide is now on fiestaguides if any body wants to have a look
AW3K
Postby craigc38 on Fri Apr 14, 2006 12:52 pm
thanks mate,
will be postin pics once i got some touch up paint to go round arches and am also gonna fill the gaps between bumpers and arches (that are even on standard 2i's/rst's) and paint them.
rgds
craigc38
Postby 16v on Sat Apr 15, 2006 6:23 pm
good guide mate, where can i get sikaflex from and how much isit and how many tubes will i need?
16v
Postby craigc38 on Sat Apr 15, 2006 7:01 pm
thanks mate
i got mine off ebay m8, from this seller...
http://cgi.ebay.co.uk/SIKAFLEX-291-ADHE ... dZViewItem
i only used a quarter of a tube and that was plenty, i latered it on!
so if you want to bond anything else do it quickish as the tube is only meant to be good for 3 days once you have opened it and if you buy off ebay, state that you want it in white unless you have a black car and want it in black.
it is also paintable and make sure you got a few G-clamps and you leave it all taped/clamped up for 24hours (no peeking lol)
All the best
craigc38
Postby 16v on Sun Apr 16, 2006 1:26 am
lol top man craig nice one mate
16v
Postby mk3dean on Sun Apr 16, 2006 2:04 am
could u not use gripfill as im doin this soon on my 5door, and i get the gripfill free from work, well wot my boss doesnt no :lol:
mk3dean
Postby craigc38 on Sun Apr 16, 2006 8:36 am
i have not used it so i cant comment mate.
do you know others who have used it?
rgds
craigc38
Postby craigc38 on Mon Apr 17, 2006 10:01 am
can a mod put this in the guides forum?
rgds
craigc38
Postby Project on Mon Apr 17, 2006 10:17 am
Consider it done.
Project
fiftyoneCL
fiftyoneCL
Postby craigc38 on Mon Apr 17, 2006 10:48 am
cheers m8
might save questions beingasked as i found myself asking alot last week :lol:
craigc38
Postby craigc38 on Tue May 09, 2006 8:36 pm
just thought i would add, i fitted a 2i kit on my mates fiesta van with success last week... though the inner stubbs had to be filled down... so be warned they vary.. some need filling down some dont.
rgds
craigc38
Postby mattfiesta1987 on Wed May 10, 2006 10:09 am
if you fit the xr2i bodykit on a 5 door you need to that the inner studs out as it wont sit close to the car. i learnt this last week.
mattfiesta1987
Postby Cl@ssy Burd on Fri May 12, 2006 3:23 pm
I shall be doin this tonight after i finish work :D :D
Cl@ssy Burd
sealant
Postby lukestkd on Fri Oct 06, 2006 10:56 am
do u reckon white or black colour for the sikaflex cos i've got a dark green mk3?
Drives - Combo Van for Work!! 1986 Xr2 hopefullyl!!
lukestkd
