Cutting OUT!
Cutting OUT!
Postby MIK3Y on Thu Jul 24, 2003 12:54 pm
What the fu*k. A few weeks ago it started doing this but cleaned the connections in the ECU and has been fine since.
Now when it does it, it doesn't make a rapid clicking noise @ the relays like last time but still judders then the revs r all over the place when u leave it at idle b4 it cuts out.
Any1 hav any help? :(
MIK3Y
Postby MIK3Y on Thu Jul 24, 2003 1:04 pm
PS: Last time the problem was a loose earth connection in the ECU which is why a relay was ticking with electrics on but wouldn't start! :rolleyes:
MIK3Y
Postby TJ on Thu Jul 24, 2003 1:14 pm
Have you tried that again?
TJ
Re: Cutting OUT!
Postby bowdenj on Thu Jul 24, 2003 1:45 pm
MIK3Y : but still judders then the revs r all over the place when u leave it at idle b4 it cuts out.
What spec ?
Idle stabilisation valve?
John
Audi quattro turbo
bowdenj
Postby Project on Thu Jul 24, 2003 2:25 pm
Posted on PassionFord - didn't see this one here - d'oh!
Project
fiftyoneCL
fiftyoneCL
Postby CRABBY on Thu Jul 24, 2003 10:55 pm
should have bought mine m8 :o
CRABBY
Postby MIK3Y on Thu Jul 24, 2003 10:58 pm
I'll find the earth and sort it @ the weekend. Thanx 4 the help.
MIK3Y
Postby MIK3Y on Sat Aug 16, 2003 1:06 am
THIS PROBLEM HAS REARED IT'S UGLY HEAD AGAIN! :rolleyes:
An autoelectrician is looking at it Monday but it is tempremental and does it for no reason then works fine!
We still think it's a bad connection with the ECU as the engine coughed a bit when i shook it and the indicator lights came on (permanantly, not flashing) with electrics when it wasn't working, left it a minute then back as if nothing had happened. :-?
The problem is finding it as it is suddenly fine again which means it will be hard for an auto-electrician to find it unless the problem is happening when he looks at it! :rolleyes:
MIK3Y
Postby MikeyXR2i on Sat Aug 16, 2003 8:49 pm
sounds like another earthing problem, if the indicators stuck on.
MikeyXR2i
CHIP!
Postby MIK3Y on Sun Aug 17, 2003 10:57 pm
Im pretty sure it's the 195 Superchip i had plugged in. :rolleyes:
Took it out and didn't hav any problems for 2 days then put it back in and started Kangarooing after 10 mins! :-?
Now ive got the problem with the standard ECU cutting the ignition cause it can't handle the power, happens at around 5psi!!! :o
The fuel pump still infinatly primes but am having the wiring looked at tomorrow morning.
MIK3Y
Postby MIK3Y on Fri Aug 22, 2003 12:20 pm
WAHAY
Fixed, earth to fuel pump. :Q
MIK3Y
Postby MikeyXR2i on Fri Aug 22, 2003 2:00 pm
top man, knew it was an earth somewhere.
MikeyXR2i
Postby TrekkieFRST on Fri Aug 22, 2003 2:12 pm
I read somewhere that a dodgy earth could permanently damage your ECU!
Just for Info
R.I.P Rob...
"The Teenage Chicks Love The Car"
TrekkieFRST
Location: Kings Lynn Drives: Honda Prelude Sex Appeal: 52.30% Loves: Stuff!!!
Postby MIK3Y on Sat Aug 23, 2003 12:48 am
Yeah, can u explain this m8. I still suspect a funny Superchip though, jumped a few times tonight but never cut out, so gonna replace the fuel pump relay then it can only be the chip as it didn't happen with-out it. :rolleyes:
Thanx 4 the help.
MIK3Y
