[rough guide] changing lower arms
16 posts • Page 1 of 1
... is now here:
http://www.djstalker.com/content/view/94/45/
/al
/al
- Project
- fiftyoneCL
way i do it...
-wheel off
-remove pinch bolt, (liable to snap or round off the torx end of the bolt)
-drive a chisel into the opening where the pinch bolt was (this allows the ball joint to slide out easier)
-remove the other two arm bolt
TIP if your stuggling to remove or insert the ball joint, and youve already openned up the clamp and tried spray lubricant. try jacking up the hub, basically your pushing the shock absorber back up to its normal on road position, reducing the angle of the dangle of the arm
on a ramp this method takes about 10mins a side
-wheel off
- FezzR
- God Damn Lazy
found it easier 2 remove the lower arm cradle.
as when the car is jacked up all the weight of the brake and caliper is on the lower arm, and i found it hard 2 remov the nuts and bolts.
but it was a piece of pisss to do with the whole cradle off the car.
i also reccomend new nuts and bolts for the lower arms
- ianFRST
maybe im being a bit noncy here but why mess about with the brake caliper and track rod end?
youve made it sound like the best way to the pistons is through the exhaust pipe
sorry chap. dont mean to come across as a c**t
- 285Andy
- Your car: fiesta rs turbo
Looks ok to me Al, although you forgot to mention the need for colourful language and regular cups of tea.
<==== long gone- phils_wicked
spot on mate, thats they way i've done mine in the past. agree with ian on the bolts/nuts defo. maybee as i have a tendancy to be a little heavy handed
but spot on whack it in the forum
still need to update this sig
- ~Tony~
am i the only one on here who has no idea what the hell u lot are on about (i feel left out!)
how do you guys know all this stuff. i only know what a track rod arm is (sort of) because i needed a new one.
im gonna get a little mk2 fez to use for work so i can do things to my Si. any good references of how to do things like books tv programmes people?????
weird question i know but always wanted to b a mechanic but was given wrong advice as a child so never did it.
daz
daz
- Benno210
Seems good as i did mine a couple of months ago, tho with the car back on the ground, tightening up the bolt on the back of the wishbone, where u have to wedge a spanner in the top to stop it turning as you torque up the underneath nut, is a complete bugger on a lowered car. Unless you're fortunate enough to have a set of ramps. Would say its adviseable to have a mate on hand
- festajon
- Phil Si
Car: 2000 BMW 330 Ci
What size is the torx??
- Rhinopower
- Your car: Volvo FH330
Breaking 2i, lots of parts available!, pm me
