centre console fitting
Postby matt188 on Tue May 29, 2007 1:19 pm
iv got a centre console and im about to fit it, although it looks like the air pipe will get in the way, does the pipe need to be modified as the air will be blowing straight at the centre console? what does everyones pipe look like behind the centre console?
thanks
matt188
Postby hb69 on Tue May 29, 2007 1:54 pm
hb69
Your car: Fiesta 1.1 LX
Postby heeman10 on Tue May 29, 2007 3:44 pm
The lowermost vent can be slid out of its housing. It does blow straight into the console, then the console directs it sideways at the driver and passenger's legs :)
Postby matt188 on Tue May 29, 2007 5:15 pm
thanks for the info, the guide says i need to change the pipe to an open ended one, is this really needed? can i just leave it like it is?
matt188
Postby AW3K on Wed May 30, 2007 7:01 pm
matt188 :thanks for the info, the guide says i need to change the pipe to an open ended one, is this really needed? can i just leave it like it is?
All you need to do is to remove the grill off the end, it just pulls off
AW3K
