car spraying
car spraying
Postby MK4 Rick on Sat May 19, 2007 8:41 pm
has anybody ever sprayed there car with aerosol cans .can you get a decent finish
MK4 Rick
Your car: Mk5 Fiesta
Postby mike_w on Sat May 19, 2007 9:06 pm
never done it but heres a guide to doing it
http://www.geocities.com/kandifiesta/Sp ... attles.htm
mike_w
Postby dawsfezzie on Sun May 20, 2007 11:14 am
yes i have, you can get just a good finish [ERRR] a rattle, its all in the prep work, sand everything down nice and smooth, and using wet and dry 1500 inbetween coats to get it smooth you should be fine, bearing in mind, you've got to get the right colour, as i think rattle can matches are poo, also just spraying isnt that easy theres a knack to it aswell!!!
dawsfezzie
Postby Dkmode on Sun May 20, 2007 7:26 pm
you can get a very decent finish with cans but it can be costly if doing a large area. but ive found from experience colour matching can be poor as said
Dkmode
Postby nickjohnwatson2002 on Wed May 23, 2007 3:25 pm
i painted a door for a volvo s70 with rattle cans and it came up really good!
the door was rusted at the bottom
rubbed it down with 240 grit to get the most off, then used 600grit, then primered it
rubbed it down with 800 grit wet n dry the put 8 coats of paint on.
then rubbed down the orange peel effect with 800, 1200, then 1500 wet n dry, then polished it up
it took 2 days to do altogether, i imagine it will take ages to do a car with cans, but i intend to do my mk3 fiesta that way
nick[/img]
T.W & S Barker Renault specialists - 0191 - 2329532
nickjohnwatson2002
spraying
Postby MK4 Rick on Wed May 23, 2007 6:20 pm
the door looks nice mate,so there is a nack to spraying with cans
MK4 Rick
Postby nickjohnwatson2002 on Thu May 24, 2007 4:01 pm
yeah just take ur time and preperation is the key, make sure the panels are really smooth and put quite a lot of paint on as you will need to flat it back and polish it up, just make sure when spraying you go from side to side evenly and then cover the panel again going up and down it to make sure you have got an even coat, i would say do about 6 or 7 'dry' (thin) coats then do one 'wet' (thicker) coat, nick
nickjohnwatson2002
