Can any 1 help please with a couple of questions?
Postby Farooq on Sun Aug 24, 2003 2:27 pm
1. Is the 2i and fezzy turbo fuel pump the same?if not how easy is it to change?
2. Is there a knack to setting the timming?
3. Where is the termal timming swith on the fezzy turbo?
4. What could casue a car to turn over on stater motor but not kick in?
Any help please?
Farooq
Postby FezzR on Mon Aug 25, 2003 6:59 pm
1. all efi engines run 3 bar fuel pressure so pumps should be same! will certain run if the engine is standard.
2. check haynes manual
3. the what?
4. check for spark check for fuel, are u running an aftermarket imobilizer?
HTH
FezzR
God Damn Lazy
God Damn Lazy
Postby Farooq on Mon Aug 25, 2003 9:15 pm
im using a cat 2 imobilier whihc is aftermarket do u think that could have a bearing on the car?
Ans the other thing i was talking about was the THERMAL TIMIMING SWITCH WHIHC TELL THE FAN TO COME ON?
Farooq
Postby FezzR on Mon Aug 25, 2003 9:22 pm
i believe the fan switch to be on the top/side of the thermostat housing on EFI engines.
ensure the imobilizer is working correctly or by pass it till u get it running
what is the situation with the engine?
has it been sat?
have u had work done etc????
FezzR
God Damn Lazy
God Damn Lazy
