breaking 1800 5 door
13 posts • Page 1 of 1
Breaking mk3.5 n reg 5 door
Rs 7 alloys 14 inch with 185 55 14 tires £200
1.8 zetec engine For sale 1800 zetec engine. Around 70k miles
Rebuilt. New gaskets
2.0l cams
2.0l throttle body (looks brand new) modified for fiesta use.
2.0l mass air flow sensor
Polished Escort crossover pipe
Silicone reducer
K&n filter
New timing belt kit fitted.
New waterpump
Polished lead cover.
Stainless steal fixings used throughout.
Custom made Braided fuel lines on the injector rail.
Rs1800 Front engine mount/alt bracket
Rear engine mount for fiesta
Fiesta zetec flywheel and bottom pully (not shown in pics but is included)
Zetec gearbox sandwich plate
New locating dowels between block and gearbox
Zetec Exhaust mid section
1.8 ecu but have a 2.0l one if needed for a fee.
All you need to finish this engine
is an alternator and belt
45 degree silicone reducer to go between maf and crossover
Spark plugs
Oil
Down pipe
And correct wiring.
Finish polishing the inlet manifold if required.
Add a set of jubilee clips.
As you can see a lot of time money and effort has gone into this engine it's a shame to sell but need to move on.
I'm the owner of http://www.fiestaguides.co.uk aswell.
I also have zetec water pipes and radiator
£200 ovno
Si interior wing backs. Rear seats 4 door cards handles and door cards all fittings parcel shelf £60
Profelx front poll bushes for arms with poll arb bushes £40 kit. SOLD
Gmax shocks and springs 40mm mk3.5 only £75 SOLD
Rear si beam with drums and anti roll bar. £50
Front anti roll bar with fixings and new drop links £40
Xr2i calipers painted red with pads and discs just need tidying up. £30
Xr2i master cylinder and servo. £20
Black dash £15
Center console with pockets and fixings £15
Steering wheel with air bag £15
Pass airbag £15
Black carpet £10
Central locking motors x4 electric window motors X2 boot popper x1 all wiring needed 3 window switches 1 boot popper switch. Complete kit £60
1.1 has engine looked after around 80k £50
1.1 gearbox £30.
S brace with fixings £15
Any other bits you need please ask.
Shell is quite solid but I'm cutting bits out for my project.
All collection castleford west yorks.
but could post some stuff
2.0l cams
Silicone reducer
K&n filter
New waterpump
Spark plugs
Oil
Down pipe
And correct wiring.
£200 ovno
Black dash £15
Pass airbag £15
Black carpet £10
1.1 gearbox £30.
- AW3K
Re: breaking 1800 5 door
Are the front arm poly bushes for 3.5 with power.steering? Is it a full set of 4 bushes or just front or rear? I'd be very interested although the arb bushes I already have if you would split? Pm.me.if you like
Russ
Russ
- russ-RST
- Your car: fiesta rs turbo
russ-RST :Are the front arm poly bushes for 3.5 with power.steering? Is it a full set of 4 bushes or just front or rear? I'd be very interested although the arb bushes I already have if you would split? Pm.me.if you like
Russ
They fit all mk3 and 3.5 4 bushes in total to fit a pair of front arms.
Rather sell as a set. No need for arb bushes myself either.
- AW3K
Gmax kit and poll bushes sold
- AW3K
- AW3K
Is the strut brace a front or back, and do you know if it'll fit a 93 XR2i mk3? If it'll fit a mk3 I'm interested.
- frodo_monkey
- Your car: Fiesta XR2i 2.0l Zetec
It's the lower s brace that fits between the lower arm carriers
- AW3K
Ah ok, sorry I misunderstood - was after an OMP type. Thanks for getting back to me though!
- frodo_monkey
Would you be prepared to sell the RS1800 front engine mount separately?
- frodo_monkey
Id be interested in the zetec rear engine mount and the gearbox plate between box n engine if your willing. to split also the coilpack and bracket depending on which one it has
- russ-RST
Hi sorry engine went . Along with most of the shell.
- AW3K
Would u sell just the door cards?
- johnson91
- Your car: ford fiesta
Interior gone sorry
- AW3K
