BRAND NEW TOSHIBA VIDEO PROJECTORS £299.95
1 post • Page 1 of 1
I bought these projectors for a job I was doing. This job fell through so I’m selling these projectors off. I paid £600 for each of these from PriceRitePrinters (http://www.priceriteprinters.com/produc ... rodid=1807)
The projectors are still in their original packaging and are perfect for business use or for use at home for movies, games etc.
Please do not be fooled by these cheap ‘No Frills’ projectors. They are useless. Spend that little bit extra and get a top quality projector from a top brand. These projectors have a full manufacturer’s warranty.
Manufacturers Spec:
It's nice to make a good impression. At home, for example with the latest films and games, or at work with a top-quality presentation to your customer. And it's so easy, with Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the s8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. In addition, Toshiba has integrated useful security functions such as panel lock and password function
General
MPN: TDP-S8
Device Type: DLP Projector
Built-in Devices: Speaker
Width: 23.9 cm
Depth: 20.7 cm
Height: 10.7 cm
Weight: 2 kg
Projector / panel
Image Brightness: 2000 ANSI lumens
Image Contrast Ratio: 2000:1
Image Size: 0.88 m - 6.5 m
Projection Distance: 1.3 m - 11 m
Resolution: 800 x 600 (native) / 1280 x 1024 (compressed)
Native Aspect Ratio: 4:3
Colour support: 24-bit (16.7 million colours)
Max Sync Rate (V x H): 85 Hz x 80 kHz
Bulb type: 200 Watt
Bulb life cycle: 2000 hour(s) / 3000 hour(s) (economic mode)
Features: Eco-Mode technology
Projector lens system
Lens Aperture: F/2.7-3.0
Vertical Keystone Correction: -15 / +15
Video input
Analogue video Signal: RGB, S-Video, composite video
Digital Video Format: HDTV, DTV via PC input
Audio output
Type: Speaker(s) - integrated
Speaker(s): 1 x mixed channel
Input device
Type: Remote control - external - wireless
Expansion / connectivity
Interfaces:
1 x VGA input - 15 pin HD D-Sub (HD-15)
1 x S-video input - 4 PIN mini-DIN
1 x audio line-in - mini-phone stereo 3.5 mm
1 x composite video input - RCA
1 x VGA output - 15 pin HD D-Sub (HD-15)
1 x audio line-out - mini-phone stereo 3.5 mm
Miscellaneous
Included Accessories: Carrying case
Cables Included: 1 x VGA cable
Security Features: Security lock slot (cable lock sold separately), control panel lock
Power
Power Device: Power supply - internal
Voltage Required: AC 120/230 V ( 50/60 Hz )
See ebay item 120184277245
Manufacturers Spec:
General
MPN: TDP-S8
Width: 23.9 cm
Depth: 20.7 cm
Height: 10.7 cm
Weight: 2 kg
Projector / panel
Bulb type: 200 Watt
Video input
Audio output
Input device
Interfaces:
Miscellaneous
Power
- tadstar
