Brake upgrade
Brake upgrade
Postby Oliver xr2i on Sat Mar 12, 2016 8:02 pm
Hi guys ! I converted my 18d fiesta into xr2i zetec 18 and i need to upgrade the front brakes. Would you demand sierra cosworth front brakes or something similar ? Preferabbly without any alterations.
Oliver xr2i
Your car: Fiesta xr2i
Re: Brake upgrade
Postby BOBFRST on Mon Mar 21, 2016 11:09 pm
Escort Cosworth setup is definitely the best & most cost effective upgrade mate & I think theres a fitting guide in the guides section :D
CheeRS
BOBFRST
BOBFRST
Your car: 1991 Fiesta RS Turbo
Re: Brake upgrade
Postby HCS PIMP on Mon May 07, 2018 10:10 pm
Focus st170 calipers should fit upgrading to 300mm discs but you'll need 16" wheels and may need to trim the front wheel arches if lowered
HCS PIMP
Re: Brake upgrade
Postby Mav Singh on Fri Aug 17, 2018 7:21 am
I just put some fremax high carbon discs and ebc yellowstuff pads on my 1.6si. Very good combo no pad fade yet. With the eurocarparts pagid pads there would be fade after 2 heavy brakings from 70mph to 20
1.6 si
Mav Singh
Your car: 1995 Fiesta Si 1.6
Re: Brake upgrade
Postby Joris on Fri Aug 17, 2018 9:58 am
Hi-Spec used to do a kit for the fiesta which just bolted on.
There's several opinions about the company though, I'm happy with my brakes.
Bought them try Mike Rainbird at r&b motorsport back in the day.
http://www.randbmotorsport.co.uk/shop/P ... &offset=20
He also has most of the conversion brackets for going to cosworth brakes.
Joris
