amp problem
8 posts • Page 1 of 1
amp problem
ive got a 1000 watt renagade amp im runnin to 1000 watt jbl subs but the amp protection prt lite keeps coming on neideas wots rong cos i have come to a stump n the girl keeps complaining there no bass for her on the way to work so if ya cud help me wud save ear ache thnkx guys
FUK RED BULL THESE ARE MY WINGS
- ash4nat
sorry mate couldnt understand much of what you wrote,but check that nothing is shorting out,you have a good earth to match a good power supply. has it ever worked before as asked? it could have been damaged somehow ie by overheating.has the amp ever felt.been damp? this can cause problems.
HTH
- XRMike
disagree,
it could be an earting problem, definately worth checking first, but i reckon its most likely to be a short circuit somewhere within the unit,
amplifiers are notorious for doing this, and audio shop is the only place to fix these, not amazingly expensive as sometimes it can just be a small resistor gone, which is pennies plus the labour of bloke looking at it
local place fixed my old sony one for me for a tenner, had the same prob wud start up (green light come on) then about 5 secs after turning the key the red light would cut in.
i got fed up with the sony one int he end, unreliable piece of poo, sold it on ebay as broken! got a fair wack for it as well as amp repairs ant too bad, just got fed up with it.
- 2309andy
it sounds like to me your running your amp on max and the amp cannot take it so it autmaticaly puts the cut of switch on. try turning down the gain if you need the gain on max your amp is clearly not powerfull enough for the sub. just because its 1000w and so is your sub it doesnt mean that they are a good match for each other .
- turbohurky
