Aerials
9 posts • Page 1 of 1
Aerials
Thinking about removing my aerial but still want radio, ive seen those dab window aerials but dont really want it on the windscreen. Would it be possible to mount one of these under the headlining and still retain good reception or are there any aerials that i can mount under the headlining?
Cheers Sam
Cheers Sam
- 0010
- Your car: BMW E30 318is
Re: Aerials
there are none specifically used for under the headlining, have you considered putting it on the rear or 1/4 windows?
bassboy
bassboy
- bassboy
- Authorised Trader
Re: Aerials
Good idea, need to sort my rear window out first before i go ahead. so you wouldnt recomend fix one of those window mounted ones under the headlining, the roof skin will probally cause bad reception wont it.
Cheers Sam
Cheers Sam
- 0010
Re: Aerials
the only problem with putting one in the headlining is the reception as you said...I dont want to give you a 101% answer just incase it doesnt work...i think the rear screen will be the best option...
if you need a glass mount give me a shout mate
bassboy
bassboy
- bassboy
- Authorised Trader
- 0010
Re: Aerials
have u got a link to these ariels mate sounds quite interesting
- Minstral
- Your car: *
Re: Aerials
no afraid not fella, DAB aeriels wont work on analogue signals...you will have to get them specifically for the job...again i can get you these also...
mistral...unfortunately i dont have them listed on my site but have a look here http://ice.dndservices.co.uk/shop_show_ ... p/IID/2654
ill do the same aeriel for £12 delivered
bassboy
bassboy
- bassboy
- Authorised Trader
Re: Aerials
is that a digital 1 or normal aerial?
- Minstral
- Your car: *
