Zetec-S rear beam and Focus rear discs on the Type-R
Postby fiestakingfisher on Mon Jul 21, 2003 6:10 pm
mmogenius :louise these are the very same disks that you were going to get... but i payed £45 a side...
Better luck next time :bonkers:
they were still there 12 months later? :o:o:o:o
aw well, at least the baxtered didn't get the £200 they wanted for them :D
fiestakingfisher
PurePower
PurePower
Your car: Fiesta 2.0 Kingfisher, BMW Z4
Postby FezzR on Mon Jul 21, 2003 9:42 pm
is it 10 mm wider than a normal beam or a frst beam?
as im sure brummy boy pointed out the frst beam is norrower than the smaller n/a engined ones?
FezzR
God Damn Lazy
God Damn Lazy
Postby AdrianFRST on Mon Jul 21, 2003 10:16 pm
The Zetec-S beam is identical in width to the FRST one, which in turn is identical width to an XR2i one.
Base model ones are the same as well.
The track increase comes from the Focus stub axle assembly.
Baby Battle Scratch
Baby Battle Scratch
Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
Postby dannyboy on Mon Jul 21, 2003 10:31 pm
Ade one last question, trying to get as much info as poss.
I plan to use alloys from a cougar, which I have been told have an offset of et46. If I was to run these with the existing drums 11mm spacers would be needed :o. So if the stub axle assembly spaces it out by 10mm each side does that cancel out the need for spacers?
I'm not sure, kinda learning as I go along :lol:
Dan
dannyboy
Postby fiesta boy on Mon Jul 21, 2003 10:32 pm
as ade says the beam its self is the same but the rear drums on the base models cause them 2 have wider track at ther rearthan 2i/ frst
fiesta boy
One big spelling error...
Postby AdrianFRST on Mon Jul 21, 2003 10:38 pm
dannyboy :Ade one last question, trying to get as much info as poss.
Dan
Yes.
Baby Battle Scratch
Baby Battle Scratch
Postby 8skellerns on Tue Jul 22, 2003 8:09 am
Surely you are losing the rear anti roll bar? Or doesnt this matter?
Drives: MK2 Fiesta 1.4 Ghia (1988) Focus 2.0 Zetec (2003)
8skellerns
Postby AdrianFRST on Tue Jul 22, 2003 8:16 am
MarkFRST :
sphinx :Jus 1 more thing. wot about ARB's? z-s doesnt have 1 does it?
If you put the beams up on their end, and hold the bottom, you can twist the frst beam with arb quite alot,
do the same with the mk5 beam and it won't twist at all, its sooo much stiffer.
As Ade says, it doesn't need an arb.
Baby Battle Scratch
Baby Battle Scratch
Postby EvilFranky on Tue Jul 22, 2003 3:49 pm
This is fantastic!
Hmm, so then...i have to have 5mm spacers on the back to keep my tyres from scraping the spring cups, so does this mean i can just take them away cos they will be spaced out 10mm cos of the brakes?
And :o @ £180 quid...bargain.
EvilFranky
Postby CarismaDave on Tue Jul 22, 2003 3:59 pm
Most importantly...does it handle better now?
As you have changed to rear discs do you uprate the Master Cylinder or leave as is? I'm wondering whether standard is good enough for rear disc set-up and 4-pots at the front?!
Dave :D
Area 6 355bhp monster!
CarismaDave
Postby EvilFranky on Tue Jul 22, 2003 4:15 pm
Yeah, does it handle significantly better then? Do you really notice it in normal driving?
EvilFranky
Postby AdrianFRST on Tue Jul 22, 2003 4:39 pm
EvilFranky :Hmm, so then...i have to have 5mm spacers on the back to keep my tyres from scraping the spring cups, so does this mean i can just take them away cos they will be spaced out 10mm cos of the brakes?
Yes.
Handling, don't know yet cos it's still up in the air with the gearbox to be swapped but it's a forgone conclusion that it will be much better. The car already stuck like glue round corners (IH lower arms, front strut brace), so with this and a rear strut it should be awesome.
I've spoke to people who have had the Puma rear beam conversion (£450 and not as stiff as this one - ooops!!) and they say it makes a huge difference so it's looking good.
Baby Battle Scratch
Baby Battle Scratch
Postby AdrianFRST on Tue Jul 22, 2003 4:41 pm
Master cylinder upgrade is on the cards, but we need to do this with the brake lines first:
That way we can try out all sort of cylinders regardless of how the fixed metal piping is routed.
Baby Battle Scratch
Baby Battle Scratch
Postby MikeyXR2i on Tue Jul 22, 2003 4:54 pm
Just for peoples info, when i changed to disks up the back, i had to change the master cylinder to a MK5 Escort item, including the servo.
The brakes are stunning.
MikeyXR2i
Postby EvilFranky on Tue Jul 22, 2003 5:59 pm
Well if thats the case then i can see me doing this in the very near future...a Mk3 Fezzy out handling a Saxo/106 Gti anyone? :D
EvilFranky
Postby AdrianFRST on Tue Jul 22, 2003 7:06 pm
EvilFranky :Well if thats the case then i can see me doing this in the very near future...a Mk3 Fezzy out handling a Saxo/106 Gti anyone? :D
Run rings round 'em.
You ain't seen nothing yet... ;)
This is one area of development and modification that's been almost completely ignored. People have build 400hp+ Zetec Turbos and fitted 19s, but no-ones really pushed the boundaries of what can be done with the chassis setup.
Baby Battle Scratch
Baby Battle Scratch
Postby EvilFranky on Tue Jul 22, 2003 7:12 pm
Any chance of some help locating the parts? Anyone?
EvilFranky
Postby KINGHORN on Tue Jul 22, 2003 7:18 pm
DOES IT HAVE TO BE A ZETEC-S rear beam or will any mk5 rear beam work or even mk4
turbo restoration in progress
painted, interior half in, windows in let the rebuild continue
http://www.fiestaturbo.com/forums/post1715280/#p1715280
http://www.kinghorn1.wordpress.com
KINGHORN
Postby AdrianFRST on Tue Jul 22, 2003 7:54 pm
Mk4 won't fit, shock mounts are totally different.
Has to be a very late mk5.
Baby Battle Scratch
Baby Battle Scratch
Postby snake on Tue Jul 22, 2003 9:12 pm
mmogenius :there is no need for a guide mate it's really simple all you have to do is bolt everything on you cant go wrong seriousaly you cant...
but that's besides the point....
DONT copy me :P you buggers :P
he he he :wink:
llama why do u think i didn`t tell no one :lol: :P :P , had bits ready to be fitted to my car over 1 and half years ago :P :P :P , project>> :P :P :P :wink: , few xtra mods bein made though :wink:
snake
Trainee Burger Flipper
Your car: ford
Postby EvilFranky on Tue Jul 22, 2003 9:20 pm
What other stuff are you having done like Snake?
EvilFranky
Postby snake on Tue Jul 22, 2003 9:22 pm
just stuff :P lol, some peeps know, should be done by the end of the year if i get me arse in gear!, been toooooo long now, 1 year 9 months off the road :aaah: :aaah:
snake
Your car: ford
Postby Gaz7 on Wed Jul 23, 2003 12:10 am
Snake - i bought you those parts a very VERY long time ago now..... do some work and fit them instead of just sleeping/eating all of the time :wink: :P :P :P :P :P
Gareth :D
Gaz7
Authorised Trader
Authorised Trader
Postby EvilFranky on Wed Jul 23, 2003 2:32 pm
Just been quoted 200 quid for the bits required...posted. Not to bad me thinks! Now then, lets see about raising the cash :wink:
EvilFranky
Postby Stoned on Wed Jul 23, 2003 2:33 pm
Where from Evil Franky?
Stoned
Postby EvilFranky on Wed Jul 23, 2003 4:13 pm
Sorry that was meant to say 250 quid delivered...which i still dont see as being too bad.
Stoned, that was a quote from these i found on the net...
F.M.S Spares LTD
01708 522207
EvilFranky
Postby zetec69 on Thu Jul 24, 2003 3:28 pm
I assume this means the 2.0L Focus rear stub axles/discs/calipers/pads will fit directly onto a mk4 Fez rear beam. Adrian?? :-?
Brad
LoW MoToR
zetec69
Postby EvilFranky on Thu Jul 24, 2003 8:13 pm
Question...will a brake biasing valve be needed to set the rear brakes?
I don't wanna be pressing the pedal for my back end to swing oot! :o
EvilFranky
Postby AdrianFRST on Thu Jul 24, 2003 8:20 pm
zetec69 :I assume this means the 2.0L Focus rear stub axles/discs/calipers/pads will fit directly onto a mk4 Fez rear beam. Adrian?? :-?
Brad
I don't know if the stud pattern is the same on the mk4 as it is on the late mk5s. It's possible that they changed it when the new beam design was introduced. You'd have to check somehow, if the breakers has all the bits try it out before you buy.
Baby Battle Scratch
Baby Battle Scratch
Postby MikeyXR2i on Thu Jul 24, 2003 8:22 pm
the fiesta's already have em, just look behind your battery, there is 2 of em bolted to the inner wing. They adjusts the pressure to the back brakes.
MikeyXR2i
Postby AdrianFRST on Thu Jul 24, 2003 8:23 pm
EvilFranky :Question...will a brake biasing valve be needed to set the rear brakes?
The proportioning valves (silver cylinders on the inner wing) are supposed to stop that happening, but they might only be set to work with the std drums.
The best idea is to find a large carpark and in the wet jam the anchors on with the car cornering. The idea being that if it's gonna lock the backs first you'll spin but not hit anything, nor cause tyre damage due to the wet surface.
Baby Battle Scratch
Baby Battle Scratch
Postby EvilFranky on Thu Jul 24, 2003 8:37 pm
I'll wait till Mmo has tried it first lol :wink:
This really is a fantastic mod...vastly improved handling, better breaking, makes me get happy in my pants :D
EvilFranky
Postby Jon_mk4 on Fri Jul 25, 2003 9:57 am
I'm running Focus stub axles and calipers with my rear disc conversion (although over FRP discs and using the FRP handbrake cable).
My rear beam set up isn't as stiff as the ZS stuff (and especially not as stiff as the Type R with it's rear strut brace) yet there was a notable difference and improvement in cornering grip and general handling characteristics that can only be attributed to the increased rear track.
One word of warning, though. Don't even think about doing this conversion unless you've ground your arches down to next to nothing and are running a stiff suspension set up.
Jon_mk4
Postby TJ on Fri Jul 25, 2003 10:43 am
Why does that need to be done then? Is that for mk3 aswell or mk4?
TJ
Postby Jon_mk4 on Fri Jul 25, 2003 12:30 pm
Unless you've rolled or ground your arches, it'll catch. If you look at my sig you can see how far out the wheel sits in comparison to the rear arch.
Jon_mk4
