Woohoo! It flies! Update on Page 7/8 :D
Postby ju575 on Sat Apr 30, 2005 10:28 pm
Didn't reply last night because i didn't have anything helpful to say, and well i dont now but glad to hear your not breaking it, :D would be a shame after everything you've put into it.
I know its easy for us all to sit back and say stick with it when very few of us are in your position, and truth be told if i was in your position i would have probably given up long ago :oops: i was gonna fit my electric pack items the other day but gave up as soon as i took the fusebox out :lol:
Good luck with it and hope this finally gets the problem fixed. :)
ju575
Postby FezzR on Sat Apr 30, 2005 10:48 pm
andyhardy :
FezzR :gotta love the fiesta fuse box :cry: :x
It's a bloody mess to work with! :x
Oh well - hopefully won't have to touch it again after I've finished finding this fault :)
tell me about it, after all my additions the fuse box would no longer fit in position :x had to all be held in with cable ties,
wont be like that if it ever does go back together lol
FezzR
God Damn Lazy
God Damn Lazy
Postby andyhardy on Sat Apr 30, 2005 11:58 pm
FezzR :
andyhardy :
Where do you plan on relocating it mate? Over the winter I'm stripping my car out so I plan to remove alot of the un-necessary wiring in the car (stereo etc.) - relocating the fusebox somewhere handier would be a bonus :)
Postby FezzR on Sun May 01, 2005 12:05 am
well if plans stay as they are ( :lol: not bloody likely) most of it wont be needed
and was would be left would probably be passenger side, floor or bulk head
FezzR
God Damn Lazy
God Damn Lazy
Postby andyhardy on Sun May 01, 2005 12:09 am
FezzR :well if plans stay as they are ( :lol: not bloody likely) most of it wont be needed
Cool - sounds like your plans are sort of similar to mine, I've figured that with the engine and turbo being so loud on this car that the stereo might as well go along with most of the interior and get it all caged up. The carputer will be staying but will be relocated and used for telemetry/data logging and video purposes only :)
The plan is to make the car a full on track-day toy, possibly even losing it's road legal status, the engine and transmission side of things are sorted, just shell stiffening, chassis and suspension to sort out :)
Postby FezzR on Sun May 01, 2005 12:16 am
andyhardy :
yea my original plan was to combine yours and marks ideas so all out every toy possible, computerise everything, then fez went off the road and brought the audi, why try and make a fez comfutable and full of toys when you have an audi, so fez is hopefully gonna get rebuilt (bare shell) as a track/rally car, need to strip it down more and make sure the inner sills arent too shagged tho
FezzR
God Damn Lazy
God Damn Lazy
Postby andyhardy on Sun May 01, 2005 3:04 am
Cool stuff - I've cleared a space ready for work on the loom tomorrow, got bloody Fiesta bits everywhere! :x :lol:
Postby SPo0n on Sun May 01, 2005 12:40 pm
i have absolutely no idea what's wrong with the car or what you're up to but good luck :lol:
wires are scary i couldn't even get my headunit working properly and that was a case of plugging stuff in...
SPo0n
Postby MarkRS2K on Sun May 01, 2005 9:28 pm
glad uve changed your mind mate, im sure you would have regretted it, like they say, take your time and dont rush. :)
MarkRS2K
Postby heeman10 on Mon May 02, 2005 12:39 am
It would've driven you nuts not to have driven it on full boost....keep plugging Mandy! I found my problem today...my brand new, out of the box fuel pump doesn't work! :lol: :rolleyes:
Postby andyhardy on Mon May 02, 2005 12:57 am
heeman10 :It would've driven you nuts not to have driven it on full boost....keep plugging Mandy! I found my problem today...my brand new, out of the box fuel pump doesn't work! :lol: :rolleyes:
Sorry to hear about that mate - hopefully you can get it replaced on warranty? :)
I've got a bit of an update for you all.
I have been keeping a track of my progress through the continuity testing of the loom I've been doing today on passionford.com, the post can be found here:
Engine loom testing post on passionford.com
The continuity testing is basically a test to make sure that an electrical connection is being made between the ECU plug and the sensor connectors themselves.
This is my continuity test sheet as it stands now:
Pin number Description Continuity Status
1 Earth Yes
19 Earth Yes
2 Lambda Sensor N/A
20 Positive Power Feed Yes
3 Crank Position Sensor Yes
21 Not Used N/A
4 Crank Position Sensor Yes
22 Knock Sensor Yes
5 Distributor Connection ?
23 Distributor Connection ?
6 Knock Sensor with Earth bonding shield Yes
24 Ignition Module (pin3) Yes
7 Canister Purge Valve N/A
25 Ignition Module (pin6) Yes
8 Electronic Control Loom ?
26 Not Used N/A
9 Linked to ECU pin 30 (MAP and TPS) Yes
27 Electronic Control Loom ?
10 EFI Power Delay Relay Yes
28 Fuel Pump Relay Yes
11 MAP Sensor Yes
29 Coolant Temperature Sensor Yes
12 Not Used N/A
30 MAP Sensor and TPS Yes
13 Octane Adjust N/A
31 Air Charge Temperature Sensor Yes
14 Octane Adjust N/A
32 Injector 2 Yes
15 MAP Sensor Yes
33 Injector 3 Yes
16 Boost Control Valve ?
34 Idle Speed Control Valve Yes
17 TPS Yes
35 Injector 1 Yes
18 Injector 4 Yes
Pin-outs still needed to be tested/eliminated from testing:
ECU Pin 16 - Boost Control Valve ? - surely this should connect to the AMAL valve lead which came out with the loom? Or is that just an earth lead?
ECU Pin 27 - Electronic Control Loom ? - what does this or should this have connected to? I'm assuming this is something to do with the interior loom which my car doesn't use?
ECU Pin 8 - Electronic Control Loom ? - same question as for ECU Pin 27
ECU Pin 5 - Distributor Connection ? - what should this be connecting to or is this something else my loom doesn't have?
ECU Pin 23 - Distributor Connection ? - same question as for ECU Pin 5
The next bit of continuity testing I'm going to do (once eliminating the last 5 pins on the ECU) are to test all the Earth's from the loom backwards, once that's done I'm going to take the insulation off the whole loom and manually inspect each wire and solder/repair whatever I think warrants it.
Postby andyhardy on Mon May 02, 2005 3:07 am
I have now checked the whole loom out in terms of ECU plug to sensor connectors continuity (checking for breaks in the line).
All of them were as they should be except for Pin 16 - Boost Valve control (in layman's terms - the AMAL valve activation wire).
I thought that it seemed odd that there was a break in the line so I rolled the insulation back and found that there was another lead within the insulation. Upon peeling it back further I managed to expose the end of that wire. I could see no joins in the wire that was connected to the AMAL valve.
Anyway - out of interest I thought I'd check and see if the lead that had been tucked away was the correct lead to the ECU for the AMAL valve, and guess what - it bloody well is! :lol:
I'll make sure I rewire that into the car properly when I put it all back together so I'm going to cut the other cable and loop that back into the insulation, the other lead to the AMAL valve goes to a switch within the car which activates the high/low boost setting. I don't think this was the cause of my problem with the car not firing though but it's a good thing that I found it as I'd be peed off with not being able to change to high boost via the switch!
My bets are on the problem being caused by the dodgy phase sensor connector found here...
The plastic surround for the connector had been broken. Normally this wouldn't cause any problem but these connectors use a metal clip to hold them in place on the sensor, and in this case because of the broken casing the clip itself looks like it could easily have moved within the plastic casing and touched across the sensor terminals causing a short out and thus causing my ballache! Of course, with the loom out of the car and not connected to anything it's impossible to say if that's the case or not, but I'm replacing the connector with one I have from an XR2i fuel rail I have lying around :)
Some progress at least with it - once I've done the rewiring of that connector and checked the Earth's for continuity I'm going to check the multimeter readings from the phase sensor itself to see if all is ok with it considering the damage that's been done to the connector.
Postby Jur on Mon May 02, 2005 7:49 am
well .. this sounds good... no other words needed..
and measuring to the frequency you're posting.. and the posts themselves..
you seem to have become from grumpy to enthousiastic again..... great to hear..!!!!
keep up the work
Jur
Postby Captain Tightpants on Mon May 02, 2005 7:57 am
Should be running this afternoon by the sounds of it!
Good luck mate, loom problems are a right nightmare.
Steve
Captain Tightpants
Postby RS_Rawli on Mon May 02, 2005 10:00 am
he cant help being a grumpy c**t
one hes to 1.21 jigawatts running through his loom he will be a happy bunny :lol:
good work andrew :Q
RS_Rawli
Postby heeman10 on Mon May 02, 2005 4:35 pm
Well done Mandy (a) for getting back into it and (b) making the progress you have. Did Grove gain access to that AMAL valve multiplug? Seems funny for it to be left in that state if they did :-?
I found the problem with my pump. Took the tank off, pump out, and the damn multiplug between the pump and tank cap connector wasn't plugged in! :lol: It's now plugged in, back on the car and squirting fuel out into a jug in my engine bay :D Progress!! Give us the necessary updates when you put it all back in the car :)
Postby andyhardy on Mon May 02, 2005 5:29 pm
I'm now jury-rigging the loom back up into the car to see if it will now fire - as soon as I get it running the car will be put away and tomorrow taken up to my Dad's for help with tidying of the engine loom (he's an electromechanical engineer so pretty good at this type of thing! :D).
One more wire (positive power feed into fuse box bus-bar) and that's it - it's all ready for testing! Finger's crossed guys! :lol:
Postby MotorcyclesFish on Mon May 02, 2005 5:36 pm
*waits*
*crosses fingers*
...um, if this doesn't work, no-one talk to him on msn unless it's to give him e-hugs. OK? :)
MotorcyclesFish
Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Postby Brycey on Mon May 02, 2005 5:37 pm
andyhardy :I'm now jury-rigging the loom back up into the car to see if it will now fire - as soon as I get it running the car will be put away and tomorrow taken up to my Dad's for help with tidying of the engine loom (he's an electromechanical engineer so pretty good at this type of thing! :D).
Brycey
Postby SPo0n on Mon May 02, 2005 5:41 pm
Good luck doctor
SPo0n
Postby andyhardy on Mon May 02, 2005 5:53 pm
IT'S ALIVE!
8)
Putting the alternator back on it now so we can do continued testing with the jury-rigged loom, once we've finished doing that I'll rewire it properly and take it for a couple of short test-runs and wire the AMAL valve back in semi-properly.
Tomorrow is going to be spent at my Dad's making use of his nicer soldering irons! :D
Postby MotorcyclesFish on Mon May 02, 2005 5:54 pm
fudgekin RAAAAAAAAAAAAAAAAAR! :D :D :D
Bloody ace mate, hopefully this is finally the end of all the crap!
:D :D :)
MotorcyclesFish
Postby NU773R on Mon May 02, 2005 5:56 pm
:D woohoo :D well done mate
NU773R
Postby Kartracer69 on Mon May 02, 2005 6:12 pm
thank god!
patience young man, has paid off!
Kartracer69
Location: Herts Drives: Fiesta VTS Abuses: Zip Rotax 125cc
Postby FezzR on Mon May 02, 2005 6:20 pm
cool beans
FezzR
God Damn Lazy
God Damn Lazy
Postby Rodge on Mon May 02, 2005 6:33 pm
Well done mate....
Hope to see it at some shows to admire all the hard work you've put onto it.
Rodge
Postby scotty_boy on Mon May 02, 2005 6:39 pm
whoa. :D
scotty_boy
Postby PaulC on Mon May 02, 2005 6:51 pm
Great stuff mate, good news :D Had a look at AutoData, its got all the EECIV pin outs, but none of the cossie stuff :(
PaulC
Postby Sphinx on Mon May 02, 2005 6:51 pm
scotty_boy :Image
"About 30 years"
whoa. :D
Yes i'm sad :lol:
Postby Captain Tightpants on Mon May 02, 2005 6:55 pm
Excellent news mate!
The board is full of GOOD news today, its great! 8)
Steve
Captain Tightpants
Postby Excursion on Mon May 02, 2005 7:31 pm
score 8)
Postby Jur on Mon May 02, 2005 7:45 pm
it's alive...
ALIVE!!!!!!
Jur
Postby andyhardy on Mon May 02, 2005 8:34 pm
Alternator belt stops play unfortunately - due to the 'fixed' CPS bracket using a new stud to hold the CPS in place, the end of the thread is fouling on the alternator belt (hard to explain without photo's).
I've tried adjusting the belt with less slack in it but now the car just fires for a short while then the alt belt starts squealing.
Not got many options left with this part of the engine so I could seriously be delayed by another week or so - just what I don't bloody need! :x
Ho-hum, someone upstairs really doesn't like me.
Postby FezzR on Mon May 02, 2005 8:40 pm
cant you just cut it down a bit?
FezzR
God Damn Lazy
God Damn Lazy
Postby Captain Tightpants on Mon May 02, 2005 8:42 pm
Ahh man,
This threads like a roller coaster, full of ups and downs.
Hopefully will come to an end though, feeling GREAT!
Steve
Captain Tightpants
