Which tuner...?
Which tuner...?
Postby escortmatt on Tue Jan 21, 2014 3:34 pm
I've got real problems with my FRST, wiring/possible ecu problems causing it not run properly, I want to book it in somewhere for a diagnosis for the problem but unsure who to use, who are the best people out there for this.
Any help would be great.
escortmatt
Re: Which tuner...?
Postby FRSJON on Tue Jan 21, 2014 11:37 pm
id say the nearest to you would be power engineering or devil developments.. the trouble with your issues are that it will be time consuming/expensive and probably all need replacing after. but hopefully some diagnostic work will point you in the right direction :)
FRSJON
