[FAQ] Turbo shaft Play
Postby KEVFRST on Sun Jul 13, 2003 7:27 pm
How much play should there be in the turbo shaft?
[promoted to FAQ section - Proj 03.07.2K4]
KEVFRST
Postby AndyBlackFRST on Mon Jul 14, 2003 12:44 am
Only slight movement mate,
Car is back...
AndyBlackFRST
BANNED SELLER
Postby fiesta3rst on Mon Jul 14, 2003 6:29 pm
there should only be minimal play side to side on the shaft and there should not be any play at all inwards and outwards on the shaft, this will mean the oil seal has gone and the turbo needs a recon
fiesta3rst
Postby Gaz7 on Mon Jul 14, 2003 8:06 pm
up/down side/side movement is ok with the engine off, as the oil pressure removes this once running. There should be no endfloat at all, this indicates wear.
Gareth :)
Gaz7
Authorised Trader
Authorised Trader
Postby Project on Sat Jul 03, 2004 3:07 pm
New one for the FAQ's :)
Project
fiftyoneCL
fiftyoneCL
