Re: The Recaro Fiesta
Postby AW3K on Sun Nov 22, 2009 1:16 am
looking good :)
not looked on here in ages but looks like your getting stuck in
AW3K
Postby knuckles on Sun Nov 22, 2009 9:30 pm
AW3K :looking good :)
cheers andy :)
Rs has taken a back seat for now since the mk4 run around has arrived. But i got a 165 powerchip installed tonight, so when weather gets better i will take it for a spin with a few more Psi :D
Desperatly need a uprated Fuel pump next then another trip to torque of the devil :wink:
knuckles
Your car: Fiesta Rs turbo
Postby knuckles on Tue Dec 01, 2009 10:41 pm
Got the Matching mocal oil pressure guage and the Proper mk3 grey dual guage holder
Looks factory fitted now :Q
Just got to plum in the oil pressure line to the Ford T piece and extend the illumination wires from the clock to the ''A'' pillar.
I had to undo the right hand side of the dash and pull it out slightly to get the air line and oil pipe up to the ''A''pillar. Lots of swearing involved whilst holding a tesco wind up torch :lol:
knuckles
Postby jayrs on Tue Dec 01, 2009 10:54 pm
looks good mate :Q
Postby Dave G fsi on Tue Dec 01, 2009 11:12 pm
Looks really good mate :aviator:
Dave G fsi
Your car: Mk1 FRS and FRST
Postby knuckles on Wed Dec 02, 2009 10:38 pm
I Purchased a uprated fuel pump from motorsport developments which is the same as the escort Cosworth pump which is good for 350bhp
Should be with me by tomorrow. Now looking for a -31 actuator now as i know that will be needed next if i rolling road it again with the Proper fuel pump.
gonna keep it running Blues for now and see what bhp it can achieve.
Got the 165 chip in and it seems to have removed the boost limit but it wont boost over 11psi :oooh:
knuckles
Postby knuckles on Thu Dec 03, 2009 10:57 pm
took delivery today of the uprated fuel pump.
got some new bolts to secure the fuel tank to the chassis and a new gasket for the fuel sender.
will attempt to fit it saturday :aviator:
knuckles
Re: The Recaro Fiesta - Fuel pump & actuator
Postby jayrs on Fri Dec 04, 2009 10:13 am
if you never done one before mate have a gandfa at my guide.
but ill be the toher end of the phone if you need be,m but ill be on the xr2 this weekend so if i dont answer right away, keep trying mate
Postby knuckles on Fri Dec 04, 2009 11:54 pm
Another motorsport development purchase arrived this morning. :D
:bonkers:
this should be enough to keep me going for a while :lol: :lol:
knuckles
Postby knuckles on Fri Dec 04, 2009 11:56 pm
jayrs :if you never done one before mate have a ganda at my guide.
but ill be the other end of the phone if you need me but il be on the xr2 this weekend so if i dont answer right away, keep trying mate
just printed out your guide and will be reffering to it tomorrow... and expect some phone calls lol :wink:
knuckles
Postby jayrs on Fri Dec 04, 2009 11:56 pm
now get that 195 chip and beige injectors in it
Postby knuckles on Sat Dec 05, 2009 12:23 am
jayrs :now get that 195 chip and beige injectors in it
ive had mixed views on the 195 map from a few ppl.
just Wondering if i should rolling road it with the 165 chip and the blues to see what i can squeeze out of them with the new pump ?
knuckles
Postby jayrs on Sat Dec 05, 2009 12:47 am
new pump or not, wont make any different as i think ya getting all you can from that
Postby Excursion on Sat Dec 05, 2009 2:21 pm
Get the hell out of my office
Postby knuckles on Sat Dec 05, 2009 8:56 pm
Fitted the new fuel pump today with a few problems as usual.
i took the old fuel sender/pump jayrs sold me back when i had a xr2i, removed the ford pump , soldered the new pump wiring connector onto the sender then used heat shrink to seal the joints. Being a aftermarket item it didnt like sitting in place so alot of fidderling later it was ready to fit.
Drove the car on to the 2 poster car ramp and lifted it up. Wd40'd the nuts holding the tank into place , uncliped the fuel pipes at the back then dropped the fuel tank down enough to gain access to the fuel sender. Didnt have a special tool so i gently tapped round the locking ring to release the sender. pulled off the pipes on the top of the sender and got a mouth full of unleaded :lol:
replaced the old pump/sender with the new unit and got it back in within 20 mins.
The new pump is so much quieter than the ford item.
What a difference a new pump makes to the normal driving of the Car. Just pulling away and the general running is so much smoother.
Had a little blast on the way home from work and its a completely different car ! it gets to 5000 rpm and wants to keep going :Q
Id advise anyone whos Rs is running a bit rough to fit a new pump. my old pump is 18 years old and was well due to be renewed.
Clark :)
knuckles
Postby rob pace on Sat Dec 05, 2009 9:06 pm
i need a new sender, my fuel gauge goes all over the place once ive got over half a tank! :lol:
rob pace
Postby jayrs on Sat Dec 05, 2009 10:23 pm
told ya it was a easy job mate.
easier for you as you had the use of the ramp :bonkers:
Postby knuckles on Sat Dec 05, 2009 10:57 pm
yes certainly a big advantage with the use of a ramp. I would of been going mental laying on my back doing that and wouldnt have any room to manouver the sender in and out.
I only had one hour till they closed and i was just refitting the fuel pump in the tank. Started at 11:45 finished at 12:45 :)
Lush :D
knuckles
Postby jayrs on Sat Dec 05, 2009 11:40 pm
good going mate.
when i done mine it was cold, wet, getting dark and i was laid under the car with hardly any space, i remember it well, as i had the same problem with one bolt as you, and the rachet slipped off as i was hanging on it and i smacked my finger on the rear beam so hard i didnt feel it at first till it started to warm up.
first time ive felt sick from hurting my self, as it was a proper whack too.
not like you in the warm and dry :lol: :lol: :lol:
Postby rsonblackwheels on Sat Dec 05, 2009 11:45 pm
good stuff mate, like the new gauges look very tidy
sounds like fitting the new pump went well, mouth full of unleaded sounds nice :lol:
:Q
rsonblackwheels
Postby knuckles on Sat Dec 05, 2009 11:47 pm
i used my christmas long bar on that rusted bolt with mole grips on the top spring washer :lol: :lol:
knuckles
Postby jayrs on Sat Dec 05, 2009 11:56 pm
:lol: the christmas long bar :lol:
Postby knuckles on Wed Dec 09, 2009 1:19 am
Let there be light :D
Clock is now back where it belongs as the boost guage is on the a pillar
Ambers are back !
And are back for good :D
knuckles
Postby Dave G fsi on Wed Dec 09, 2009 1:25 am
Looking really good mate :aviator:
Dave G fsi
Postby MAD_Adamski on Wed Dec 09, 2009 2:08 pm
love this dude :aviator:
MAD_Adamski
Postby RS rob on Thu Dec 10, 2009 12:32 am
wicked progress with the fuel pump,
awesome it can make such a difference
cant wait for some new power figures soon????????
RS rob
Postby knuckles on Thu Dec 10, 2009 11:08 pm
Ive got the T3 running 15 psi yesterday :D
blanked off the dump valve and it chatters so loud now the actuator is fitted.
Its a animal compared to before i renewed the pump. Thinking of putting the beiges and 195 chip before the rolling road setup
It was 170 bhp last time running 10psi max :oooh:
knuckles
Postby RS rob on Fri Dec 11, 2009 6:37 pm
maybe speak to TOTD about it, as the 195 chip is a bit marmite
gauges look smart to, not ott either
is it a nomad a-pillar??
RS rob
Postby jayrs on Fri Dec 11, 2009 7:20 pm
nothing wrong with the 195 chip, i got one fitted, as long as you get it set up it will be fine, there not plug and play like some people think they are.
and the super chip chips are not as good as others, but i have a superchips chip and its fine
15 psi, bit much really mate, i would knock that down a touch tbh
Postby knuckles on Fri Dec 11, 2009 7:29 pm
RS rob :gauges look smart to, not ott either
I got it from burton power along with the oil pressure guage
think its a nomad one but not to sure.
the fuel pump has made a difference regarding fuel consumpstion. £15 fuel didnt even last 80 miles on wednesday :lol: :lol: :oooh:
knuckles
Postby jayrs on Fri Dec 11, 2009 7:35 pm
knuckles :
:lol: :lol: , mate when i changed my fuel pump i noticed it, my car was running fairly lean for a month before hand, was peob the most economical FRST going! :lol: :lol: :lol: :lol: even matey at power engineering said and i qoute " how the f**k that engine isnt fcuked i dont know!" :lol:
thing is it used to run alright with no tell tell signs, but then again at the time i wasnt really booting it about just normal driving so it didnt require the extra fuel, like yours, but once you know its in there you wanna use it/try it :bonkers:
Postby knuckles on Fri Dec 11, 2009 7:40 pm
jayrs :15 psi, bit much really mate, i would knock that down a touch tbh
ive dropped it down to 12 just in case.
was just wondering if it would go over 10 psi which is the limit on the ecu.
Thinking about a FMIC now :aaah:
knuckles
Postby knuckles on Fri Dec 11, 2009 11:44 pm
Get your sun glasses out again people !
:D :D :D :D :D :D :lol: :lol:
knuckles
Postby jayrs on Sat Dec 12, 2009 12:22 am
oh helllllllllllllll no!
Postby jonboisescort on Sat Dec 12, 2009 12:54 am
that was a shock
and f;;k me thats bright :lol:
jonboisescort
Car: 1994 Ford Fiesta
