Postby jayrs on Fri Dec 29, 2006 7:54 pm
dunno tbh, i called and asked cos i was interested to see how much it was, he didnt say you couldnt, but there exchange.
you can get short motors, or could which just a recon bottom end
Postby russ_si on Sat Dec 30, 2006 4:47 pm
Even tho there reconed i gess they would use O.E parts?
russ_si
Postby onslack on Sat Dec 30, 2006 8:11 pm
i have just read the thread from the beginning and you have been making some good progress 8)
keep it up knuckles( sorry dont know you name)
onslack
Your car: Si
Postby jimmyesh on Sat Dec 30, 2006 8:35 pm
I've heard people saying that you can get recon engines from ford, though never tried it myself... yet! (until i blow my st170 lump :lol: :bonkers:)
Interesting about the cam situation though as I tried ordering a replacement new standard CVH cam from Ford for my sister's XR2i a couple of years ago and ford said it was a "special order" and that they're made in Germany :rolleyes:
I waited a MONTH for the illusive cam to materialise and ford just said they couldn't set a date for it to be due-in.
In the end I went to piper and ordered the closest cam they had to standard, (which gives 6bhp over standard). Not sure whether Ford hardened the standard cams properly either as they did wear out RAPIDLY :x or whether the lifters were too hard for the cam lobes :-?
Good luck with the car mate it's coming along nicely :wink:
jimmyesh
Your car: Yes
Postby knuckles on Sat Dec 30, 2006 9:30 pm
Thanks alot guys for the replies :)
cant wait for the rest of the parts to get sorted and get this car on the road.
knuckles
Your car: Fiesta Rs turbo
Postby jayrs on Sun Dec 31, 2006 1:08 am
jimmyesh :I've heard people saying that you can get recon engines from ford, though never tried it myself... yet! (until i blow my st170 lump :lol: :bonkers:)
thats nothing mate, i waited 2 years, yeah you heard me right, 2 years for a streeing rack for my FRST and it cost me £120 :oooh:
Postby jayrs on Sun Dec 31, 2006 1:11 am
russ_si :Even tho there reconed i gess they would use O.E parts?
ford dont make there own spares mate, other places do and put fords nam on it :wink:
Postby knuckles on Sun Jan 07, 2007 1:32 am
Update
Mainly today i got on with Fitting the turbo and water pipes. I'm still awaiting new o rings for the injectors so couldn't properly assemble the refurbished Efi unit. So i mock fitted most of the engine components until its all ready.
Anyway i let the pics do the talking... :)
Turbo placed on - I'm guessing the blocked off water pipe shown with the red arrow must connect to the turbo here... i need that pipe.
Closer picture
Starting to look like a engine bay again.
Close up of turbo - Do the following in that pic connect up ?? :-?
Picture of the xr2i looking very sad & lonely - missing out on the attention :lol: Some kid broke off my electric mirror :cry:
Exhaust manifold Fitted with new gasket and new brass nuts. Not bad for someone who ain't got a clue what goes where and not a Haynes in sight :lol:
Getting there.... mock fitted Radiator and intercooler, coolant hoses, and charge carrier. Cheers Nomad for the roose hoses :P
Comments welcome :D
knuckles
Postby Xr_Dub on Sun Jan 07, 2007 1:38 am
nice work :aviator:
Postby heeman10 on Sun Jan 07, 2007 1:41 am
Wahey! That looks better! As for the water hose/pipe pics/questions, I'm no use as I've never worked on a FRST, but they seem like logical assumptions :)
The AMAL valve usually sits between the actuator and the compressor housing, and acts as the boost control valve :)
So sorry to see/hear the 2i mirror was nicked, what an absolute sh*tter of an area :(
Postby knuckles on Sun Jan 07, 2007 1:44 am
Mirror wasnt nicked fella it was simply yanked down and left hanging by the wiring. Gobbed on the window too.
knuckles
Postby jayrs on Sun Jan 07, 2007 2:01 am
knuckles, catch me on msn at some time and ill let ya know about then vac pipes from actuator etc, it dont connect as you think.
as for the injector O rings, ill be getting them monday or tuesday for ya mate :wink:
ill also have a look in my spares box to see what water pipes i got, they wont be samcos just standard water pipe but might have something so you can connect both water pipes up from the turbo :)
Postby heeman10 on Sun Jan 07, 2007 2:18 am
I forgot to say...please will you measure the length of the clutch lever arm on your gearbox? Wherever...just tell me where you measured from and to, then let me know...it looks as though it could be a mysterious "short" arm.
Postby jayrs on Sun Jan 07, 2007 2:47 am
that arm is standard mate.
same as what i got, the bit the round end of cabel fits in is in direct line to the hole furthest to inner wing
Postby heeman10 on Sun Jan 07, 2007 3:23 am
Oh do you work on the car Jay? Looked as though it could've reached to either hole, and the parallax doesn't help judge which it is!
Postby onslack on Sun Jan 07, 2007 9:03 am
coming along nicely
seeing the pictures from your project should give me a better idea on what goes where as well :Q
keep it up :wink:
onslack
Your car: Si
Postby jayrs on Sun Jan 07, 2007 1:46 pm
heeman10 :Oh do you work on the car Jay? Looked as though it could've reached to either hole, and the parallax doesn't help judge which it is!
theres 2 arms for the fiesta, 1 is that one and the other has a big weight on it, and seeing as thet dont have the weight on it then its gunna be same as my one aint it, lines up to the outer hole.
mind you so does the one with the big weight on it as i fitted one to a mate FRST years ago.
cant say in all the years ive been working on cars ive every come across a fiesta that has the cable in the inner hole and been right, in line with the arm that is.
maybe this "shorter" arms were fitted to mondeos or something as they had a different cable set up and adjusted gearbox end not pedal end :wink:
Postby Cellze on Sun Jan 07, 2007 6:38 pm
Looking really good :D , shame to here the xr is getting abused :( just hope it doesn't happen to the rs once all finished!
Cellze
Cellze
Postby ~nomad~ on Sun Jan 07, 2007 6:59 pm
hi mate, forgot you were running t2, the pipe on the water hose was blocked off as I ran t3, you just need a lenth of hose and connector to extend it to where you think it goes ( it does go there )
~nomad~
Your car: Breadvan
Postby MarkRS2K on Sun Jan 07, 2007 7:38 pm
coming along matey :)
MarkRS2K
Postby knuckles on Sun Jan 07, 2007 10:59 pm
Whats left to do :
Fit both drive shafts into gearbox
Re-attach gear selector onto gearbox
Fit injectors with new o rings and fit fuel rail
Connect all water and boost hoses
Fit alternator
Fit radiator/intercooler properly and wire up the fan
Finish fitting interior, seats, carpet, trims, door cards, mirrors etc
Fit new fuel filler pipe as current one has been modified for alloy fuel cap.
Oil change/ new filter
Change cossie brakes from xr2i onto the Rs
replace old rubber brake hoses for goodridge hoses
Bleed brakes / new brake fluid
Fit rear beam
Fit full exhaust system
Weld bonnet catch pannel pack on - fit bonnet catch
Better get started :oooh: :rolleyes:
knuckles
Postby AW3K on Sun Jan 07, 2007 11:29 pm
Looking good so far mate :)
the xr will get a new lease of life :) :P
also heeman this is the link from my SI
AW3K
Postby heeman10 on Sun Jan 07, 2007 11:49 pm
Jay/AW3K - Cheers guys, there are a large number of variations of clutch lever arms on Fiestas/Escorts/Mondeos, and they all get muddled around, was worth asking :)
knuckles - I find it massively useful and important to make lists like that, you'll find it makes you much more efficient for a number of reasons: a) You know what needs doing, b) you can prioritise and c) you can tick stuff off as you complete it and get a feel for how well you're cracking through it :)
Postby AW3K on Mon Jan 08, 2007 12:04 am
i have a list on the wall in the garage
needs updating tho
AW3K
Postby wakeboardtom on Mon Jan 08, 2007 1:14 am
Good work matey! :D
wakeboardtom
Postby knuckles on Tue Jan 09, 2007 12:39 am
Another update
More tinkering today - the rain kept coming down today. So i got on with the interior. Took carpet and recaros out of the xr2i and fitted them in the in the Rs. So much time consuming. :rolleyes:
Rs1800 steering wheel needs a clean. White dials fitted, indicator stalks fitted, center console fitted.
Magnex Stainless system delivered - £80
Need to connect the boost valve up. Need to get some vaccum hoses. Also just worked out that this other thing is a washer pump for the cossie headlamp washer jets.
Where does the boost valve mount if no air box is being used ?
Pictures please people :D
Also should i fit a standard Rs breather pot ?
knuckles
Postby jayrs on Tue Jan 09, 2007 12:48 am
monkey is that all you done.
fit eh boost control valve on the drivers inner wing, ill get a pic of mine for ya
and yes, fit a standard breather :lol:
Postby knuckles on Tue Jan 09, 2007 1:04 am
Shut it you :P
Im doing my best , will try to get round to changing the calipers on xr2i to the Rs tomorrow.
knuckles
Postby jayrs on Tue Jan 09, 2007 2:32 am
gotta fit the drive shafts yeat mate :bonkers:
Postby heeman10 on Tue Jan 09, 2007 1:21 pm
Seems you're making good progress from someone who was so scared of doing it all! Interior looks farrrrrrrr more civilised now, and I can't help but think the painted white parts look a bit odd now, after all I said :lol: :rolleyes:
Postby j7aoc on Tue Jan 09, 2007 1:39 pm
Looking good mate some fast progres. Not using your lovely sprayed red plasctic trim out of your xr2i then :-? :lol:
http://www.clark7250.pwp.blueyonder.co.uk/interior1.jpg
j7aoc
Postby NeoMagic on Tue Jan 09, 2007 1:46 pm
j7aoc :Looking good mate some fast progres. Not using your lovely sprayed red plasctic trim out of your xr2i then :-? :lol:
He's using the standard items as far as im aware now.
NeoMagic
Postby knuckles on Tue Jan 09, 2007 6:52 pm
Please print that picture and burn it - i give you my permission :lol:
What on earth was i thinking - it was that max power haynes manual - I blame that book for all the chavy mods. :P
knuckles
Postby knuckles on Tue Jan 09, 2007 7:34 pm
The Rs turbo saw some daylight today as we fitted the Cosworth brakes from the xr2i to the Rs and switched over the wheels.
Finally got those drive shafts back in - alot of mucking about with poxy ball bearings when your hands are covered in cv grease. Thank you Jayrs for the suberb advice on how to get them in and a gold star for adam for actually doing it. :)
Also Fitted the goodridge hoses while doing the brake calipers. Then discovered the car actually has a rear beam ! Doh :oooh: :oops: :lol:
I assumed there wasnt one as the handbrake cable was just hanging on the floor....
Blue strip was removed by adam as he couldnt bear looking at it no more :lol:
Mk3.5 Tailgate bolted up nicely - Thank you max ww :D
Rear mondeo wheel fitted - loving the ride height on the spax coilovers.
Bonnet Re-fitted - yes i know it needs a clean :rolleyes:
Bit blurey as it was getting dark - Front wheel fitted with cosworth 4x4 brakes.
knuckles
Postby jayrs on Tue Jan 09, 2007 7:35 pm
ah im blind, god damn thats some red there nipper :lol: :lol:
ebay that lot, someone will have it :lol: :lol:
you knows you wanna go standard again in that white one now.
black dash though :lol:
