Re: The Recaro Fiesta - Rs alloys
Postby j7aoc on Wed Sep 05, 2007 5:25 pm
h196jne :
jayrs :oh look, the prototype was red, that means white was done as a lower colour for the rs, the frst was designed to be red, turbo boy :P owned, dont even waste time thinking of a come back :lol: :lol: :lol:
It wasn't jay because the car in the picture above was the original on a F plate and that,,,,,,, wait for it......... was WHITE
:lol: :lol: :lol: :lol:
Proper test car in motorsport diamond white :bonkers:
No that isn't a fiseta rs turbo that's a 1.6s with a frst engine in it (sv504 prototype)there were 3. The first frst was (G413 XNO) RED (prototype sv510)
j7aoc
Postby jayrs on Wed Sep 05, 2007 5:49 pm
i dont belive it :oops: but even if its true, white must be cheap and nasty hence why they painted it white then :lol: :lol:
anyway, i wont glog up clarks post, he knows he should of got red so ill go back to the other post :P
T3 or not T3
Postby knuckles on Sat Sep 15, 2007 2:17 am
Update - kinda :lol:
Well no pics unfortunatly as i still havent got a straight of green strips yet.... :cry:
Main consern for me now is the Turbo drinking my oil. The oil just comes out the exhuast in a white cloud of smoke when i start up and also when i drive over 85mph....
So i now have to deside [ERRR] turbo to take its place, a reconed or new T2 is going to cost more than a new T3. But T3 needs a few bits changing to go on.
new stainless downpipe required
oil return swap over
Escort exhaust manifold
different oil feed from back of block
boost pipes changing using std intercooler
Do i leave water cooling on or remove it for better engine temps ???
Will it need to be setup again on rolling road for fueling /boost ?
Let me know your thoughts on the matter and give me the good points and the bad points of going for the bigger turbo.
I wont be going front mount cooler as i am not changing the appearance of the Rs.
Knuckles
knuckles
Your car: Fiesta Rs turbo
Re: The Recaro Fiesta - T3 or not T3 ?
Postby Turboboy67 on Sat Sep 15, 2007 10:04 am
Yeah do it :Q :Q
I was lucky, Chris did all mine before I bought it,
He or somebody thats done the conversion will tell you how easy/difficult it is to do.
All I know is you blank off the water cooling as it make the engine temps higher if you don't.
Just make sure its ready to give those pesky "Reds" a spanking :bonkers: :bonkers: :lol:
Cheers :aviator:
Turboboy67
Your car: 911GT3 RS
Postby jayrs on Sat Sep 15, 2007 10:20 am
T2's can be got for a fair price, you just need to shop around, places like turbo technics etc are a rip of,
T2's can be got for same price of T3's, but you got to ask your self what you wanna do, and you being as tight as you are with petrol etc i would advise against a T3 conversion :lol: :lol:
Postby jayrs on Sat Sep 15, 2007 10:26 am
turboboy67 :Yeah do it :Q :Q
Cheers :aviator:
:lol: :lol: :lol: you "whites" just wanna go fast so no one sees you, where as the reds have to take it slower so everyone gets maxium enjoyment from seeing the "reds" :P :P
Postby Brammer on Sat Sep 15, 2007 11:23 am
Deffo good move clark, done it to both my old ones, really easy conversion
new stainless downpipe required - i used powerflow for JNE cost £40.00
oil return swap over - http://www.fordpartsuk.com cost under £10.00 posted (not availible from ford)
Escort exhaust manifold - £10.00 off ebay
different oil feed from back of block - £20.00 off ebay
boost pipes changing using std intercooler - roose do the kits for T3 mate and they should sell you that seperate so it will match what you already got.
Do i leave water cooling on or remove it for better engine temps ??? - block it off and keep the engine temps down, but you will have to run up and down correctly for around 3-4 mins
Will it need to be setup again on rolling road for fueling /boost ? - Best getting it setup
Few tips, heat wrap the downpipe, try and get a heat sheild for the alternator off an escort also maybe some sort of heat sheild for the starter as it will cook both these items, shaun is having to change a alternator that i bought brand new just over 12 months ago.
Brammer
Your car: Sierra Cosworth
Postby Max M4X WW on Sat Sep 15, 2007 5:45 pm
As above really, Maybe look at this as well..
http://www.proalloy.co.uk/cgi-bin/sitew ... d=proalloy
Postby 285Andy on Sat Sep 15, 2007 6:05 pm
id have to say go T3 as well. i wasnt convinced for quite a while until a mate done it to his own FRST. he kept badgering me to do mine and this was within a year of spending out over 750 quid for a recon T2 so i wasnt in a hurry to do it :oops: :aaah: anyway, a used standard T3 and fannymould came up for for 80 quid so went for that. also bought a new ford oil feed pipe at around 40 quid and a oil return elbow for around 25-30 quid again new from ford. got a ERST down pipe from a local motor factor for about 25 quid new! welded this to a mongoose T2 down pipe leaving the flexi in and the downpipe fitted snuggly inside the other to make a real neat job! :D at first after the swap you kinda feel a bit disapointed, but after a few days of running around with it you all of a sudden "get it" :lol: its the only way i can describe it :lol: dont get me wrong, the T2 can make the car feel really point and squert but the T3 makes it feel faster. dont know if that makes sense and if other converted owners get what im rattling on about :lol: if you do T£ it, make sure you get a turbo with a .36 exhaust housing (from a standard ERST) .48 is too big and will be far to laggy :)
285Andy
Your car: fiesta rs turbo
Postby Superal on Mon Sep 17, 2007 3:20 pm
Easy choice:
T3 turbo
Pro Alloy in max's link
Get it setup again (A must!!)
Enjoy :D
Superal
Postby knuckles on Mon Sep 17, 2007 4:01 pm
I have made my decision :)
Another ebay steal ! :D
Picked it up yesterday. Came off a escort cabriolet, was only removed to change back to a series 1 turbo. Apparently was running 180bhp at 18psi.
I dont know much about these turbo's so if anyone spots any markings etc let me know what type it is.
T3 here i come !
CheeRS
Knuckles :Q
knuckles
Postby bakewell001 on Mon Sep 17, 2007 4:42 pm
Nice one matey
Although wasn't it just yesterday you were telling me you had no money for one! :lol:
bakewell001
Postby j7aoc on Mon Sep 17, 2007 5:10 pm
Look's very good as you have the elbow pipe work manifold but the blades on the wheel look like they have sucked in a bag of nail's :lol:
j7aoc
Postby knuckles on Mon Sep 17, 2007 5:51 pm
Dont worry steve, i will just have to eat beans on toast till next month :lol:
Are the damaged blades no good then jamie ? :-?
knuckles
Postby j7aoc on Mon Sep 17, 2007 5:58 pm
knuckles :Dont worry steve, i will just have to eat beans on toast till next month :lol:
It's not abad thing mate as long as it all work's but i don't know how that kind of thing would happen if it has sucked some thing in that might be bad
j7aoc
Postby Max M4X WW on Mon Sep 17, 2007 6:50 pm
Looks like the sort of damage you get after its sucked in a small child or animal..
Postby jayrs on Mon Sep 17, 2007 7:09 pm
you got another unknown turbo, mate we need to have words.
damage to the fins dont look to bad, it should effect it, just hope it aint a smoker mate.
talking of smokers, i want your old T2 stuff :D
Postby knuckles on Wed Sep 19, 2007 7:06 pm
The cleaning process began today. Simply used a wire brush drill bit and some T-cut metal polish
Didnt spend much time on the manifold. Still got more to do, plan to wrap the manifold with heat wrap and replace the rusted water pipes.
I think i will keep the water cooling for now as i make alot of short trips.
Knuckles :D
knuckles
Postby jayrs on Wed Sep 19, 2007 7:22 pm
good call mate :)
came up ok didnt it, fingers crossed it works ok for ya mate :Q
Postby Ghost on Thu Sep 20, 2007 5:22 pm
you gimp :lol: :lol:
Ghost
Postby Brammer on Thu Sep 20, 2007 5:22 pm
Clark please don't put it in the bay without painting the turbo and manifold with black heat paint, or it will look :(
Great buy though, i would say if it was running 18psi then i would hope it was at least a stage one as it would have strained the knackers of a standard unit at those figures.
Brammer
Postby knuckles on Thu Sep 20, 2007 9:24 pm
h196jne :Clark please don't put it in the bay without painting the turbo and manifold with black heat paint, or it will look :(
The Ebay add did say it was a stage 1 and the guy said the car was kept off the road for over 4 years. He only sold it to go back to a series 1 turbo :)
I will be painting the turbo in high temp black and heat wrap the manifold.
Ghost :you gimp :lol: :lol:
i was wondering when you was gonna pop out of the wood work :lol: :o
knuckles
Re: The Recaro Fiesta - updated !
Postby knuckles on Mon Oct 08, 2007 11:50 pm
Its been a while.... and i bit the bullet and decided to fit the greens :Q
The door ones aint perfect but i love driving it with the outside looking standard the way it should of been :D
knuckles
Postby hb69 on Tue Oct 09, 2007 12:01 am
it looked and sounded so good when i watched you driving out of the car park yesterday, its a real credit to you mate, almost makes me want a white rs turbo :aviator:
hb69
Your car: Fiesta 1.1 LX
Postby Turboboy67 on Tue Oct 09, 2007 12:05 am
Looks lovely Clark, better with the Greens on :Q :Q :Q
I fell in love with those wheels @ Trax :devil:
Cheers :aviator:
Turboboy67
Your car: 911GT3 RS
Re: The Recaro Fiesta - Updated !
Postby bakewell001 on Tue Oct 09, 2007 9:15 am
Looking great now!
When are you coming to see me? :)
bakewell001
Postby ~nomad~ on Tue Oct 09, 2007 10:57 am
looks the funlumps mate. got a exhaust for the t3, still got a uber cheap one here. :D
~nomad~
Your car: Breadvan
Postby Brammer on Tue Oct 09, 2007 12:47 pm
100% better, it's the best that car looked :D
Brammer
Postby jayrs on Tue Oct 09, 2007 2:18 pm
as said last night mate, its looking damn fine, but i still think you need to loose the "recaro" stickers now, i know you said i cant cos its the recaro car, but at end of day, its not, its your car now and to who it matters eveyone know the car anyway :)
Postby ianFRST on Tue Oct 09, 2007 6:32 pm
jayrs :as said last night mate, its looking damn fine, but i still think you need to loose the "recaro" stickers now, i know you said i cant cos its the recaro car, but at end of day, its not, its your car now and to who it matters eveyone know the car anyway :)
i agree. all fiestas had recaro's anyway, so im not too sure why it was called the recaro fiesta :-? :bonkers:
and that had buckets in aswell :lol:
id even go as far to say, higher the rear up a tad
ianFRST
Postby Max M4X WW on Tue Oct 09, 2007 7:58 pm
Lovely mate, Will have to meet up some when so i can have another look :lol:
Needs a 3/4 size plate on the front i think. Or at least a new style font one cut down as much as you can to keep it legal!
Postby Big Walker on Tue Oct 09, 2007 10:55 pm
hb69 :it looked and sounded so good when i watched you driving out of the car park yesterday, its a real credit to you mate, almost makes me want a white rs turbo :aviator:
Keyword being ALMOST, admittidly i like whit a bit but you can't beat a nice clean BLACK fez :)
Lower than a snakes bollox
Each day I break my own personal record for the number of consecutive days I've stayed alive :)
Big Walker
Your car: Seat Ibiza
Postby knuckles on Tue Oct 09, 2007 11:22 pm
Thanks guys :D
Your right max, some Rs dealer plates might have to be done soon. I went fords today and ended up £60 lighter again :lol:
More filthy updates tomorro if the rain holds off :P
knuckles
Postby jayrs on Tue Oct 09, 2007 11:25 pm
good good mate.
im gunna go for them bits i told you about for mine.
just gotta work out if its worth me getting them via you with cost of post etc.
will be on to fords tomorrow and see what discount i can get, they know me down there now as ive had so much :lol: :lol:
Postby j7aoc on Wed Oct 10, 2007 8:13 am
Look's ace mate!! Have you got that T3 on there yet?
j7aoc
