the bufty work starts again. UPDATED 17th April
Postby KEVFRST on Sat Apr 07, 2007 12:21 pm
Andy, I too used to hate the flaps, but they just tidy the car up a little and as the front wheels stick out a litle further than the std, poo gets flung all over the sides and will also keep stones at bay too.
I must confess that as im so far behind time on this the front isnt getting bufty`d as thats going to be a winter project, so as much as it pains me to do so, rust bolts are going back into the wheel arch liers/struts and arb mounts :(
KEVFRST
Postby KEVFRST on Sat Apr 07, 2007 9:21 pm
all the coilovers are on today, brakes wont fit due to the disc being a fraction too thick, exhaust is off for a polish so in the meantime i carried on painting the underside and coating the rear brake caliper/mounts.
KEVFRST
Postby KEVFRST on Tue Apr 17, 2007 2:43 am
update..........
after hours of messing around over the weekend, some...and i mean some work got done on making a handbrake bracket and fitting the mk5 handbrake lever...............
you would never recognise it from that pic above would u.
time to push the bearings back into the hubs and DISASTER STRIKES!!!!
time to invest in that press i been promising myself. :wall:
In the meantime, after lots of :wall: :wall: :mad: :mad: :mad: I got the fuel filler back in and put the beam back into position.
got there in the end...............nearly trial fit for handbrake cable which is a real pain to sort!!!!
disc fitted, pads in, caliper fixed in..........still no f*&^*(& handbrake though........but it looks better.
:top:
KEVFRST
Previous
