Speaker adapters
Speaker adapters
Postby Gazeddy on Thu Mar 09, 2006 8:39 am
Has any one else come up with this problem?
im trying to mount my new 13cm speakers in the front doors of my mk3.5 but the screws that came with the adapters wont allow the adapters to sit close enough to the doors to screw them into place?
would pop rivets do the job or do i need glue etc?
1.6 si coming soon
5 Door Register
Gazeddy
Postby Cage on Fri Mar 10, 2006 7:31 pm
Use longer screws mate.
Is it an Autoleads adapter kit?
Cage
Postby Gazeddy on Sat Mar 11, 2006 12:59 am
i think it is its from halfords
1.6 si coming soon
5 Door Register
Gazeddy
Postby Cage on Sat Mar 11, 2006 1:07 am
Do you already have 5 1/4" speakers to go in?
The reason i ask this is it would be a good idea to replace your standards with bigger speakers.6" speakers fit in nicely with a little bit of work:wink:
Cage
Postby Gazeddy on Sat Mar 11, 2006 1:09 am
yeah i do a nice set of kenwoods
1.6 si coming soon
5 Door Register
Gazeddy
1.6 si coming soon
5 Door Register
Gazeddy
Postby Cage on Sat Mar 11, 2006 1:17 am
Shame that. I fitted a set of 6" Kicker KS Components in mine and i was well impressed with how good it sounded after.It's a bit of work but worth every minute.
Back to the screw problem i reakon its a case of use longer screws on the adapter plate.
When i bought my Si it had 5 1/4" rockford's in the doors which were fitted using plates and the adapter plates were nutted and bolted in with cut down bolts of some description :rolleyes: CUSTOM Thats what its called :lol:
Cage
Postby Gazeddy on Sat Mar 11, 2006 1:19 am
in the morning im goin to try riveting the speakers to the adapters
1.6 si coming soon
5 Door Register
Gazeddy
Postby Cage on Sat Mar 11, 2006 1:32 am
Rivet the adapters to the door then screw the speaker to the adapter
Job Done :)
Cage
Postby Gazeddy on Thu Mar 16, 2006 10:15 am
job done sounds top now
1.6 si coming soon
5 Door Register
Gazeddy
