Russ' mint green FRST , update :)
Re: Russ' mint green FRST :D NEED HELP!!!!!
that sounds exactly like the bolts i got from the scrappy but they are defo too big
- russ-RST
- Your car: fiesta rs turbo
it'd probably rip em out if any smaller
- frst toady
- Your car: ranger super cab, frst t3
The size stated sounds about right to me.Why not swap the carriers for the ones from the white rs
- rs220bhp
rs220bhp :The size stated sounds about right to me.Why not swap the carriers for the ones from the white rs
onli other thing can suggest is to put that size tap through the hole to make the bolts fit
- frst toady
i havent got the carriers off the rs and i suppose i aint got a choice but to tap em to the right size but that means taking of the carriers to do it properly dont it ????
- russ-RST
frst toady ::-? O well dont think u'd reli want anythin smaller holdin the arb on tbh
it'd probably rip em out if any smalleri'l av a look see if i got anything similar in ma box of bits
theres only a twisting force acting on the arb, nothin much can rip the bolts out
thats what i thought. so what should i do try and find some bolts to fit the existing holes or enlarge the ones on the car to fit the standard bolts?
- russ-RST
jonyb4 :frst toady ::-? O well dont think u'd reli want anythin smaller holdin the arb on tbh
russ if u can find some bolts wot fit the holes mate and your happy boltin em up there probably be ok
just my personall opinion bumpy roads/corners etc etc, as the m8x 1.25's aint massive by no means but thats wot was on mine so..
- frst toady
i agree just try random bolts in the hols and find which one fits, if one is slightly too big/small try the next size, its a jigsaw piece fit
lol iv tried all of the bolts i have
- russ-RST
av a look see if u can get a tap in there without dropping it all down it'll be tight but maybe do-able
- frst toady
and none of them come close? if you aint got the size buy some M6/8 and 10 bolts that are about 15mm long
i might just whip them off at a later date and tap em to the size i want lol
- russ-RST
well not much progress here to report to be honest but i thought i'd share with you where i am up to so far and what's stopping me etc.
well basically i had a really bad xmas consisting of splittin with my missus on xmas eve the battery turning out to be cream crackered and then when i went to do the gasket on my oil return from the turbo i snapped a bolt
so i havent touched the car since but i have a collection of parts and some motivation now and the fact i need my car before the 18th as iv got bloody jury service
just my luck aye!
well i have a full set of gaz coilovers coming this week should be here before the weekend so this is the main update i have for the car
so i can finally be sitting flat and some lovely lowness to go with
i will get off my behind at some point this week then and:
change the fuel pump as its still got the 1.3 pump in
fit gaz coilovers
take off turbo.. send to engine centre to have bolt drilled out and then refit turbo with new gasket but this time without snapping a bolt
once i have the car running again i will be taking it to my freinds to have the brakes fitted as i dont trust myself to bleed them and the 1.3 brakes aren't really up to the job
then once these jobs have been completed (yes i will keep you updated) i have a few bits an bobs i bought for the car some time ago but thought i'd share them with you
fit gaz coilovers
- russ-RST
mintex pads for the rs turbo calipers
my new drop links for the ARB these will get fitted once i find some bolts to bolt the ARB with
my grooved discs for the rs turbo brakes
new cambelt kit +tensioner and waterpump for the engine, again i dont trust myself to do this to my car so i shall be gettin a freind to help me do this
braided brake hoses for the new brake set up
as always there is alot more to purchase but i will write a list in a minute
comments welcome
- russ-RST
the next things i shall be doing to the car are:
new top rad hose
some way of gettin the snapped pin out of my speed sensor in the gearbox
(any suggestions wlecome)
new engine mount and gearbox mounts as the gearbox mounts have defo gone and my crossover pipe is not hitting the bonnet when i let off
fix small exhaust blow in mid section
find out why fan isnt working
any suggestions or ideas on any of the above are more than welcome
new top rad hose
- russ-RST
if its the small platic drive pin from the speed sensor, then a pin may get it out if you stab it in and pull it out, depends how jammed in it is.
as for fan, what fan? rad fan or heater blower fan?
jayrs :if its the small platic drive pin from the speed sensor, then a pin may get it out if you stab it in and pull it out, depends how jammed in it is.
that is a very good idea! why didnt i think of that![]()
i shall try when i get off my arse and will let you know
and the rad fan buddy it never seems to come on although i'v had so many problems with the top rad hose leaking all the time i doubt it has ever got a reading
- russ-RST
coulkd be the thermo switrch in the stat housing, then again it could be the plug that plugs on it, they tend to get pulled off by the wires and the wires break internally.
chech to see if the fan does work, it could be as simple as the fan motor has just burnt out.
im guessing you have checked the green relay already and cleaned the pins? if not, do that too
what suspension set up have you got on the car now?
- fezza89
g-max shocks on the front with jamex 60mm all round
- russ-RST
and i shall give the whole system a check over folllowing your advice but for the moment i think gettin it running and doing the cambelt and waterpump and brakes kind of take priority atm
- russ-RST
are you going to be selling the gmax shocks?
- fezza89
i might consider it PM me if your interested.
- russ-RST
smidydevil :i might consider it PM me if your interested.
pm'd
- fezza89
well i have been suffering with swine flu lately so haven't been doing anything to the car for a while
but i have just recieved my christmas present i bought for my self
yup nice set of gaz coilovers for the fezza
now i can get the ride hieght sorted properly and having it sitting nice and low
hopefully if the weather isn't too harsh to me today and a buddy comes over to lend a hand i should have some more updates by tonight
- russ-RST
how you got on with the coilovers bud
- frst toady
well you'l have to excuse the dirt as i havent used the car in about 3 weeks and i just haven't had any motivation to do anything with it
but yes yesterday i got the turbo off and fitted the coilovers, i havent set them up to the ride hieght i want yet but i did manage to grab a pic to show its already much better
i will have to sort out the hieght i want today and will grab some more pics then
- russ-RST
well ya gettin there anyway bud so its all gd
- frst toady
Getting there, just get those bumpers sorted out and it'll look pretty good.
- bakewell001
uuuh im half and half aobut the colour and body kit/wheels
i liked mine in this colour but it was completely standard bar a mk4 wiper lol
maybe if i saw it in person, you attending any fo the car shows this year?
well done some more work to the car today got the bolt out of the turbo and put everything back together although i'v rounded off one of bolts that bolts thru the exhaust manifould into the turbo
so if anyone has a spare one of these id b interested lol and finished off everything went to start it but im having a blonde moment and can't find a positive wire to the battery
iv got 3 negatives and 2 postives but cant seem to find the 3rd
its really wierd i know its there but cant find it
any pictures off the wires connected up to the battery would be very helpfull as its doing my head in
can't seem to find it
- russ-RST
basically i cant find a missing positive wire to the battery iv got 3 negatives and 2 positives and im sure there are 3 of each
iv got the big cable coming from the alternator with like the cross head fixing battery end and the ingnition cable coming from the loom has about 4 red wires going into it i know theres another one somewhere just cant find it
can anyone explain/ put a pic up of there battery
thanks
welll took a few pics of the wires i have got and can find if anyone can point out where the missing cable should be or even explain to me where it could be
its annoying [ERRR] iv taken the battery off a million times and yet all of a sudden i cant find the cables lol
these are the 3 earths i can find
and these are the 2 positives i can find, wheres the other one
thanks
- russ-RST
im sure there are meant to be more than 2 positive wires
- russ-RST
