*RE-AD* Ian Howell/Fiesta Frenzy/Area Six Zetec Turbo Engine
11 posts • Page 1 of 1
RE-ADVERTSIED
ALL ITEMS HAVE NOW ARRIVED AND ARE READY TO COLLECT FROM BLACKPOOL, PICTURES TO FOLLOW. NO TIMEWASTERS, EVERYTHING YOU NEED TO KNOW IS IN THIS ADVERT. DEPOSIT, BALANCE AND COLLECTION WANTED ASAP. NO OFFERS
Zetec Turbo Engine
2100cc 16v Zetec Turbo engine, built by Ian Howell @ Fiesta Frenzy Motorsport/Area Six. The engine will be supplied with the turbo and inlet/exhaust manifolds loose and a number of ancillaries required including the engine mount, oil feed pipe, etc. Please note this engine has never been started.
Spec-
2100cc with BRAND NEW 86mm Diameter Fiesta Frenzy Spec Arias Pistons
Eagle H-Section Forged Steel Con Rods
BRAND NEW ARP Conrod bolts
BRAND NEW oil pump (1800cc Zetec Fiesta)
Less than 30 miles old crank
BRAND NEW shells, rings, seals etc
7.6:1 compression ratio
Fiesta Frenzy Ultimate Camshafts
Fiesta Frenzy Uprated Valve Springs
Focus Central Blue Vernier Pulleys
APR Cam Sprocket Bolts
Blue 8mm Magnecor Igntion Leads
1800cc Sump
BRAND NEW Ford Motorsport Tubular Exhaust Manifold
BRAND NEW GT28RS Ball Bearing Turbocharger with 0.64 exhaust housing
Extensively Modified 1800cc Alloy Inlet Manifold and throttle body
440cc Ford Racing Injectors
FSE Motorsport Fuel pressure Regulator with gauge
OFAC Engine Loom with ECU, Motorsport Developments Live Map Chip for Zetec Turbo (Will require remap), AMAL and MAP sensors.
Should easily make 320bhp+ with this spec, the ball bearing turbo is absolutely perfect for ZT's, minimal lag, much quicker than a journal bearing turbo, good to 350bhp
Ian will offer his warrenty on the engine, and write out a spec sheet verifying what he has assembled. Collection will be from Blackpool unless payment is made within two weeks and the buyer lives between Blackpool and London, in which case delivery is possible for £60.
£3250
With the loom/ecu supplied this package should fit any mk3 Fiesta and with a small alteration to the alternator arrangement any mk3.5 (mk3.5's have a front engine mount aswell). I will not split the engine/manifolds/turbo or fit any of the items. This is in-no-way a bolt in package, changes to your exhaust, fuel system, intake system, piping, wiring and layout will be required. The same package from Ian Howell would cost you around £7k and this is a bargin.
Please email ZetecTurboParts@streetdragster.com
Matt
Zetec Turbo Engine
Spec-
1800cc Sump
£3250
Matt
- StreetDragster
Ian recommended it, but i didn't get it from him
For the one with the 0.64 housing it was £848 with the gaskets
The 0.86 one was around £720 i think but its not really the ideal housing for 320bhp ish
Matt
Matt
- StreetDragster
Ah look at that thing, it's just an animal waiting to be unleased. Wish I had a project car it could bolt into! This engine is a stunner, under warranty, ready to go, for 3,250....once in a lifetime opportunity!
