quick turbo question
Postby Swanick on Mon Aug 11, 2003 8:24 pm
my erst
night i bought it i got it home and a bit of blue smoke came out. was gutted. over a few weeks this got worse and eventually u could be sat at traffic lights and u would see this big blue cloud slowly drift past you :lol:
could tell turbo was on way out as well because it wasnt boosting like it used to.
then the smoke stopped. no blue smoke when it was idling and none when u started it up. only very occasionally would u see a bit :-?
but the turbo wasnt boosting like it should.
Swanick
Escort RS Turbo
Escort RS Turbo
Postby InS@nE on Mon Aug 11, 2003 8:25 pm
so whats the actually question :P
if it's why did it stop ya ran out of oil :D
InS@nE
Postby andymac on Mon Aug 11, 2003 8:26 pm
Turbo oil seals ? Using any oil mate ?
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby Swanick on Mon Aug 11, 2003 8:27 pm
was worse than that and all of a sudden it stopped.
oil was always good. didnt use much and was changed every 3k
Swanick
Escort RS Turbo
Escort RS Turbo
Postby Joris on Mon Aug 11, 2003 9:09 pm
Mine does exactly the same.
Had a new turbo, and still the same :x
Replaced head gasket, still the same :x
Probably new turbo that is not working properly,
but color of smoke is exactly the same
sometimes it doesn't do it for a couple of days, then all of a sudden it decides to chuck out loads :Q
If you find out what it is, let me know :(
Joris
Postby Swanick on Mon Aug 11, 2003 9:11 pm
the pic of my FRST is actually the valve stem oil seals. that was constant smoke though which is why i didnt think it could be them on my escort :-?
Swanick
Escort RS Turbo
Escort RS Turbo
Postby Joris on Mon Aug 11, 2003 9:15 pm
so only thing left is turbo then :x or breather ? or piston rings :(
Joris
or if it stopped all of a sudden ? you overfilled with oil, now it's all used and you're fine :) ?
Joris
Postby Swanick on Mon Aug 11, 2003 9:17 pm
piston rings have been mentioned to me many times :(
to be honest i dont think it was ever overfilled with oil :(
Swanick
Escort RS Turbo
Escort RS Turbo
Postby Joris on Mon Aug 11, 2003 9:19 pm
did you have a compression test done ?
Mine was in for one, but the gauge wasn't long enough :lol: was someone that only does cossies normally.
Joris
Postby Swanick on Mon Aug 11, 2003 9:21 pm
no i never got that done. we just took the engine apart ready to rebuild it.
just thought it was weird that the smoke stopped and the car ran perfect
Swanick
Escort RS Turbo
Escort RS Turbo
Postby Joris on Mon Aug 11, 2003 9:22 pm
if it doesn't come back it might just have been overfilled a bit and the car might have drank it by the breather or chucked it in the exhaust ?
let's hope that for you :)
Joris
Postby Swanick on Mon Aug 11, 2003 9:25 pm
cheers mate :)
Swanick
Escort RS Turbo
Escort RS Turbo
Postby ~S1~ on Mon Aug 11, 2003 9:56 pm
Have you always used the same grade oil at changes? Cos a few years back I tried filling my ERST with Mobil 1 0W/ 30 or whatever it was. It smoked really badly and sounded like a bag of nails. I changed it for a different grade synthetic oil and it was fine.
~S1~
Hold On...
Hold On...
Postby DaveZetec on Mon Aug 11, 2003 10:34 pm
kink in the oil return pipe from the turbo forcing oil past the seals?
DaveZetec
Postby Swanick on Mon Aug 11, 2003 10:37 pm
everything was tidy under the bonnet :(
Swanick
Escort RS Turbo
Escort RS Turbo
