puddle problems
puddle problems
Postby adamingley on Thu Jul 17, 2003 2:14 pm
i drove through a puddle and my car stalled and is now sitting at 500rpm. what happened? are the spark plugs wet? its a 1.6 si 1995 M reg :x
1.6 si M reg
adamingley
Postby Rich si on Thu Jul 17, 2003 2:31 pm
I did that once and had to rebuid the engine after!
Rich si
Postby DaveZetec on Thu Jul 17, 2003 8:31 pm
check each spark plug lead and spray wd40 or other penetrating oil on the connectiong (only take 1 off at a time lol)
is it misfiring on one cylinder?
DaveZetec
Postby xr2i-carl on Thu Jul 17, 2003 8:37 pm
mate that is no good for ure engine if water got into the engine it will wash the bores dry of oil and wash into the sump diliting the oil makin it to thin and wear the engine enourmously i wud change oil and filter straight away then see how it runs but it wud ave done quite a bit of damage i did it in 1 of me 1.1 and it never woz as quick again
DMS Automotive 13.0@106mph Aiming for the 12's next.
xr2i-carl
Postby Excursion on Thu Jul 17, 2003 9:45 pm
Before the water actually had time to wash the oil from the bores it would have bent 2 connecting rods.
I can't see that it could get into a zetec unless there's a very low hung cone filter.
I'd hazard a guess it's plugs as dave said, and if not remove the ECu and all connections you can see and dry them out.
Postby HaggisTurbo on Thu Jul 17, 2003 10:32 pm
xr2i-carl :mate that is no good for ure engine if water got into the engine it will wash the bores dry of oil and wash into the sump diliting the oil makin it to thin and wear the engine enourmously i wud change oil and filter straight away then see how it runs but it wud ave done quite a bit of damage i did it in 1 of me 1.1 and it never woz as quick again
is a 1.1 ever quick to begin with :P
HaggisTurbo
Postby snake on Fri Jul 18, 2003 12:32 am
lol, common fault to suck up water as air filter feed pipe is low slung, go through deep water bang bye bye rods, lol had a few of em
snake
Trainee Burger Flipper
Your car: ford
Postby Rich si on Fri Jul 18, 2003 9:18 am
snake :lol, common fault to suck up water as air filter feed pipe is low slung, go through deep water bang bye bye rods, lol had a few of em
Exavtly what happened to mine!
Should have none not to go thru it wez a lowered fez when the lasnd rover in front of me struggled!
Rich si
