project:UFO
Re: project:UFO
tin-ribs :Looking good mate ! What power are you hoping for this time round ?
well hoping the next power level to be around the 350 mark depending how soon the turbo expires lol
- FRSJON
Re: project:UFO
WOW
that should be fun !
- tin-ribs
- Your car: fiesta rst
Re: project:UFO
as im off work for christmas i finally found time to start on the new engine...bottom ends built,not alot else i can do to it until the head is finished.. next thing to sort out over christmas will be positioning the mount for the mtx box...
a couple of pics...
a couple of pics...
- FRSJON
Re: project:UFO
Good to see it being worked one,
Haven't touched mine in two months.
It's all this cold weather.
- SEG1
Re: project:UFO
SEG1 :Good to see it being worked one,
the weathers been rubbish ... still collecting parts for it at the mo.. some tasty valves turned up this morning though
- FRSJON
- 2105adam
- Your car: Ford Fiesta 2.0 Zetec turbo
- FRSJON
Re: project:UFO
Don't tell me you been working on it today as well jon
Re: project:UFO
jayrs :Don't tell me you been working on it today as well jon
lol no mate,bottom ends together and been wrapped up and put away till i get the cylinder head back.. will be down the car tomorrow
- FRSJON
Re: project:UFO
Lol fair enough mate lol
Re: project:UFO
getting there slowly lol
just waiting for shafts to be done then i can get the mount welded on...oh and a bit of trimming needed lol
also got these
also got these
- FRSJON
- rsonblackwheels
Re: project:UFO
It's coming on great mate
Re: project:UFO
Jon, You could take the opportunity to drop the engine a bit, to move the weight lower in the shell.
Re: project:UFO
Excursion :Jon, You could take the opportunity to drop the engine a bit, to move the weight lower in the shell.
thats a good point mark
- FRSJON
- 2105adam
Re: project:UFO
2105adam :Great work. Can't believe this car will be better than before.
cheers adam,always room for improvement
- FRSJON
Re: project:UFO
drive shafts done
a bit risky being white but will see how it goes lol
also a used ,standard focus rs clutch which is off to Budapest for a cheeky rebuild
im going to fit the shafts tomorrow and see if they hit anywhere..if not then i can get the gearbox mount welded in and the rebuild can commence
.. also a rear defuser/flat rear floor is under way
- FRSJON
Re: project:UFO
Jon, What's the craick with the clutch then? What do they do in Budapest?
Re: project:UFO
Excursion :Jon, What's the craick with the clutch then? What do they do in Budapest?
well... i spoke a clever chap over there about clutches as his cars are a bit good lol
http://www.youtube.com/channel/UCWf5Hx2pG4IatKBv4bifcvQ
turns out he makes/rebuilds them.. for a really good price he will rebuild a standard one and make a six paddle plate to handle 400+ bhp. ..so going to give it a go
- FRSJON
Re: project:UFO
Those driveshafts are cool !
- tin-ribs
- Dave G fsi
- Your car: Mk1 FRS and FRST
Re: project:UFO
a couple of pics of the work gary (crazycage) is doing to my cylinder head
once its back its off to be machined for the supertech valves
gary will also be making inlet and exhaust manifolds for the car
- FRSJON
- Dave G fsi
- FRSJON
Re: project:UFO
Very nice mate, I've still not been in it since it was finished (apart from sitting in it at JKM
- Turboboy67
- Your car: 911GT3 RS
Re: project:UFO
Mmmmm, proper tuning stuff
Is there much difference between the potential of your head there (which looks like a silver top to me?) and a black top or ST170 head?
- Smo
Re: project:UFO
Carbonboy67 :Very nice mate, I've still not been in it since it was finished (apart from sitting in it at JKM)
one day mate
- FRSJON
Re: project:UFO
Smo :Mmmmm, proper tuning stuff
it is a silvertop,well once the heads back its going off again to have the big valves fitted. as for a comparison between the different type i could comment but mine looks much nicer lol
- FRSJON
Re: project:UFO
so the engine spec so far...
86mm bore
m12 head bolts
wossner forged pistons
pec steel rods
mls head gasket
ported head
stainless big valves
standard cams at the mo
650cc siemens injectors
custom inlet
custom exhaust manifold
stage 3 t3 turbo ( for now
focus rs clutch/box
once its back together it will be back off to JKM to see what the turbo can produce as thats the next limiting factor..
86mm bore
m12 head bolts
pec steel rods
mls head gasket
ported head
custom inlet
focus rs clutch/box
- FRSJON
Re: project:UFO
FRSJON :Smo :Mmmmm, proper tuning stuff
What I meant was is there scope for more flow with the same work if you'd modified a black top or ST170 head to fit your silver top bottom end? Or would the results be exactly the same? Obviously as standard the black top flows better, and the ST170 even more so.
- Smo
Re: project:UFO
I recently purchased a stage 3 t3 turbo from CR turbos and was told by them it was good for up to 280 bhp ? Not sure if that helps ?
Ps, looks like it's coming along nicely !
- tin-ribs
Re: project:UFO
tin-ribs :I recently purchased a stage 3 t3 turbo from CR turbos and was told by them it was good for up to 280 bhp ? Not sure if that helps ?![]()
mine did 277 at 1 bar ... i heard around 300 was the limit but ive seen this turbo do 25 psi on another car so ill have some of the same....till it dies lol
- FRSJON
