project:UFO
Re: project:UFO
Postby FRSJON on Fri Mar 14, 2014 9:17 pm
Smo :
FRSJON :
Smo :Mmmmm, proper tuning stuff :D
Is there much difference between the potential of your head there (which looks like a silver top to me?) and a black top or ST170 head?
it is a silvertop,well once the heads back its going off again to have the big valves fitted. as for a comparison between the different type i could comment but mine looks much nicer lol :D
What I meant was is there scope for more flow with the same work if you'd modified a black top or ST170 head to fit your silver top bottom end? Or would the results be exactly the same? Obviously as standard the black top flows better, and the ST170 even more so.
im sure gains could of been had with either of the other but ill stick with the silvertop engine...stick with what you know and all that lol
FRSJON
Re: project:UFO
Postby Smo on Fri Mar 14, 2014 10:03 pm
FRSJON :im sure gains could of been had with either of the other but ill stick with the silvertop engine...stick with what you know and all that lol
Yeah, that's fair enough :)
Smo
Re: project:UFO
Postby FRSJON on Mon Sep 15, 2014 9:36 pm
time for a update :lol:
some pic first..
this..
turned into this..
bumpers now look like this
front splitter is carbon
cylinder head is back from having the big valves fitted and a skim
the turbo has now been changed and is CR turbo t38, plus the injectors changed again to siemens 875cc ones. i have this week off to get as much done to the engine as possible as the cars been engineless for a year now ! :o
FRSJON
Re: project:UFO
Postby jayrs on Mon Sep 15, 2014 10:06 pm
:Q
Re: project:UFO
Postby Smo on Mon Sep 15, 2014 10:19 pm
The front bumper looks really good! Very suiting to the rest of the car.
Do you have a power figure in mind?
Smo
Re: project:UFO
Postby FRSJON on Tue Sep 16, 2014 10:02 am
cheers chaps,power wise id still like to see 350 but whatever it makes after that is a bonus :D
FRSJON
Re: project:UFO
Postby FRSJON on Sat Oct 04, 2014 11:03 pm
first pic of the new exhaust manifold crazycage has made me :)
FRSJON
Re: project:UFO
Postby Smo on Sun Oct 05, 2014 8:45 am
That's some amazing skill there!
Very nice :)
Were you tempted to move the turbo over the box at all?
Smo
project:UFO
Postby 2105adam on Sun Oct 05, 2014 10:04 am
Lovely bit of kit that. How are going to make room at the front now? Guessing there isn't much left for the rad and cooler.
2105adam
Your car: Ford Fiesta 2.0 Zetec turbo
Re: project:UFO
Postby FRSJON on Sun Oct 05, 2014 10:43 am
Smo :That's some amazing skill there!
Very nice :)
no,i wanted it in the standard position...charge pipe and wiring locations put me off the over the gearbox type
FRSJON
Re: project:UFO
Postby FRSJON on Sun Oct 05, 2014 10:44 am
2105adam :Lovely bit of kit that. How are going to make room at the front now? Guessing there isn't much left for the rad and cooler.
we will see lol to be fair the turbo itself 'looks' closer to the box and slightly further to the right of the bay so room should be ok..my rad/cooler are as far forward as they can go..
FRSJON
Re: project:UFO
Postby FRSJON on Thu Oct 23, 2014 4:30 pm
manifold all welded up :)
FRSJON
Re: project:UFO
Postby jayrs on Thu Oct 23, 2014 4:40 pm
Very nice jon :Q
Re: project:UFO
Postby Dazza on Thu Oct 23, 2014 4:41 pm
Nice work
Dazza
Re: project:UFO
Postby chrisxr2it3 on Thu Oct 23, 2014 8:13 pm
Manifold looks really good mate
Chris
chrisxr2it3
project:UFO
Postby 2105adam on Fri Oct 24, 2014 8:41 am
Very nice indeed.
2105adam
Re: project:UFO
Postby rsturbonutter on Fri Oct 24, 2014 8:53 am
Looks spot on fairplay what's the space between turbo and rad like with one of these fitted
rsturbonutter
Your car: Fiesta RS turbo
Re: project:UFO
Postby niracka on Fri Oct 24, 2014 10:21 am
That manifold looks lush. Good to see it done properly!! Can I ask what radius of bends he used for the sections?
Olly
niracka
Your car: E46 M3
Re: project:UFO
Postby FRSJON on Fri Oct 24, 2014 11:48 am
cheers chaps,space between manifold and rad are a unknown at the mo as neither of them are on the car :lol: ,as for the radius,all bend were 90 degree and straight sections added where needed if thats what you mean.pretty sure the tube is 40 something mm heads getting bolted down in a min with cams fitted..just waiting for the cam pulley then i can fit the belt and get it in the car :)
FRSJON
Re: project:UFO
Postby niracka on Fri Oct 24, 2014 6:59 pm
Was after the actual bend radius but if you don't know it don't matter was just interested but its something i'll be able to work out with some more research. If I get a frst I'll be making myself one. Has it got a separator in the collector??
Olly
niracka
Your car: E46 M3
Re: project:UFO
Postby FRSJON on Fri Oct 24, 2014 8:01 pm
the collector is four sections of tube cut and welded to make one.. its awesome
this is how it started..
FRSJON
Re: project:UFO
Postby niracka on Sat Oct 25, 2014 7:05 pm
Nice work there. Like I said its nice to see it done properly!!
Look forward to seing it all fitted
niracka
Your car: E46 M3
Re: project:UFO
Postby FRSJON on Sat Oct 25, 2014 7:24 pm
well after tomorrow the engine will be ready to go in the car so wont be long before i can try it :)
FRSJON
Re: project:UFO
Postby Turboboy67 on Tue Oct 28, 2014 8:47 pm
Great progress mate :Q
Turboboy67
Your car: 911GT3 RS
Re: project:UFO
Postby FRSJON on Sun Nov 02, 2014 8:09 pm
no pics yet but engines in :)
FRSJON
Re: project:UFO
Postby FoFi-ToppeR on Wed Nov 12, 2014 8:48 pm
It´s a great car. I love it.
But is the diffusor right ? Your diffusor is horizontally to the ground. But for the ground effect, you need angle.
http://ais.badische-zeitung.de/piece/00 ... 801317.jpg
FoFi-ToppeR
Re: project:UFO
Postby FRSJON on Wed Nov 12, 2014 10:00 pm
FoFi-ToppeR :It´s a great car. I love it.
you sir are correct :) i think a 15 degree angle is the most efficient but mine is only a diffuser to the eye,it wont be working in the way it should.mine is more to open up the rear bumper and look mean lol to be fair rear down force is not something the car really needs and most will tell you i wont drive it fast enough to make it work any way :oooh: :lol: :lol: :lol:
FRSJON
Re: project:UFO
Postby FRSJON on Sun Nov 16, 2014 4:16 pm
a few pics of how it stands at the mo...
FRSJON
Re: project:UFO
Postby jayrs on Sun Nov 16, 2014 6:57 pm
Very nice dude :Q
Re: project:UFO
Postby niracka on Mon Nov 17, 2014 7:46 pm
Looks lovely. not a lot of room for the rad though :o
Olly
niracka
Your car: E46 M3
Re: project:UFO
Postby FRSJON on Mon Nov 17, 2014 10:06 pm
niracka :Looks lovely. not a lot of room for the rad though :o
Olly
my rad sits on the outside of the lip on the cross member so all good.. hope the turbo has enough room though :lol:
FRSJON
Re: project:UFO
Postby freak power on Mon Nov 24, 2014 10:52 pm
Makes me want to buy a FRST and build a monster Zetec turbo
Just a shame I have problems sorting out my 650bhp Audi S3
freak power
Re: project:UFO
Postby FRSJON on Tue Nov 25, 2014 6:07 pm
freak power :Makes me want to buy a FRST and build a monster Zetec turbo
think you should as well ;)
FRSJON
Re: project:UFO
Postby Seanymk2 on Fri Nov 28, 2014 2:11 am
Since getting rid of Facebook I'd not seen this car in so long! Glad to see the build is coming on well john!
Seanymk2
Your car: Mk3 fiesta si
Re: project:UFO
Postby FRSJON on Fri Nov 28, 2014 5:36 pm
Seanymk2 :Since getting rid of Facebook I'd not seen this car in so long! Glad to see the build is coming on well john!
cheers mate :) had some time away from it and had a mk6 fiesta st..sold that and now back to getting this one working again lol
FRSJON
