project:UFO
Re: project:UFO
FRSJON :well the rac were adiment the fuel pump in the engine bay had died but its been sorted and and was the fuel cut off switch.it didnt cut out it burnt out apparently........ and apparently just been told they changed the in-tank pump as well
£400
Ahh OK, maybe you should look at using the existing feed to run the lift pump alone and act as a trigger for a suitable relay to feed the engine bay pump. It sounds like two pumps are drawing too much for the switch.
Re: project:UFO
£400
whats this on, im confussed
if the land rover, prob the pump, common fault with them ones
Re: project:UFO
jayrs :FRSJON :well the rac were adiment the fuel pump in the engine bay had died but its been sorted and and was the fuel cut off switch.it didnt cut out it burnt out apparently........ and apparently just been told they changed the in-tank pump as well
£400
whats this on, im confussed![]()
Oh the Fiesta is on a trailer, didn't see that first time
Re: project:UFO
you might of been on about the escort that broke down behind though, hence why im confussed .com
Re: project:UFO
£400
- FRSJON
Re: project:UFO
jayrs :you might of been on about the escort that broke down behind though, hence why im confussed .com
I didn't spot the Freelander, let alone the Escort
Re: project:UFO
Excursion :jayrs :you might of been on about the escort that broke down behind though, hence why im confussed .com
I didn't spot the Freelander, let alone the Escort![]()
£75 aint bad at all mate! cheaper than 2 day returns that, will have to tow each other on from now on to save some cash
Re: project:UFO
done some plumbing today
coolant system,very minimal as no heater
fuel system
boost
also ferriday engineering inlet adapter plate
fuel system
boost
- FRSJON
Re: project:UFO
Stunning engine bay, very interesting to look at
Re: project:UFO
im glad you like it ,i think it must look as good as it goes
every part is test fitted,looked at for a week or two and if i dont like it it gets changed
- FRSJON
- Turboboy67
- Your car: 911GT3 RS
- FRSJON
Re: project:UFO
looking good jon, that the filter i give ya in the fuel line aint it?
- Dave G fsi
- Your car: Mk1 FRS and FRST
Re: project:UFO
jayrs :looking good jon, that the filter i give ya in the fuel line aint it?
no mate another one
- FRSJON
Re: project:UFO
3, lol
what bits you missing? anything i might have that can help?
Re: project:UFO
jayrs :3, lol
some starter motor bolts would be bloody handy
- FRSJON
Re: project:UFO
should have some of them mate, will look when out the workshop as theres little point trying to find any here as i havent unpacked the shed yet
Re: project:UFO
here's a couple of pics of the emerald ecu and engine loom .. now the loom was originally made for a n/a zetec and is missing the following.. map sensor,iscv.. now im crap with wiring but surely a n/a zetec has both of these?
at the beginning of the year i sent this back to emerald to to have adjustments but it was returned as they dont do looms
now i must add this lot hasnt been fitted to a car before but wasnt purchased new,so who made the loom is unclear.. this is pretty much the only stumbling block i have with the car and need to get it sorted sooner rather than later..any advise/comments greatly accepted
to add i do now have a diagram from emerald on which pins the wires should go to so if anyone wants the job or can recomend anyone let me know
- FRSJON
Re: project:UFO
dont know what to suggest except having a new loom made,
unless you just go for it yourself?!?
- RS rob
Re: project:UFO
RS rob :dont know what to suggest except having a new loom made,
i just need to have some extra wires put in to this one but im not doing it
- FRSJON
Re: project:UFO
Looks like that loom as made for throttle bodies hence it not have iscv etc wiring.
Have a word with a guy on here called onslack, him and his friend run cw looms and do alot of loom work for MSD
- rs220bhp
Re: project:UFO
rs220bhp :Looks like that loom as made for throttle bodies hence it not have iscv etc wiring.
cheers mate, i thought it looked more for throttle bodies
- FRSJON
Re: project:UFO
CW looms should be able to sort you out mate, I can pm you onslack (Terry)'s number if you like? Good mates with him and Alex who run the business
- Dave G fsi
Re: project:UFO
sorted
- RS rob
Re: project:UFO
Dave G fsi :CW looms should be able to sort you out mate, I can pm you onslack (Terry)'s number if you like? Good mates with him and Alex who run the business
cheers dave
- FRSJON
- Dave G fsi
Re: project:UFO
the engine loom is nearly complete
decided to sort it myself in the end. all soldered,head srunk and braided
all im waiting for now is some pins for the ecu plug from emerald.
today i fitted the alternator as i finally got the right one
plus the air filter
only have pics of the filter at mo
- FRSJON
Re: project:UFO
looking good jon.
you gunna mesh them light surrounds like ya did on ya old rs? cos that looked good imo
- rs-tom
Re: project:UFO
cheers chps
jay- not going to bother mate
tom-
the tow strap may not be staying as a miss calculation buy me means you have to take it off to get the bumper off so a threaded tow eye maybe used.but if it stays the washer will be changed
tom-
- FRSJON
Re: project:UFO
you gotta put something there mate, even if its a scoop of some form.
or maybe a little sealed pocket for a camera for track days
Re: project:UFO
jayrs :you gotta put something there mate, even if its a scoop of some form.
yeah the scoop might happen,oil cooler going in the other side
- FRSJON
Re: project:UFO
bin the flexy hose from your turbo to your filter mate , a friend of mine did the same and on boost the turbo sucked it into the compressor
cost him a new gt35.
make a ally one or steel ect
love the car tho its right up my steet
- crazycage
Re: project:UFO
it deffo needs something mate
