polo lights
116 posts • Page 4 of 4 • 1, 2, 3, 4
i wouldn't mate, looks too much like the mark 3 headlights, i think if anyones going to do a headlight conversion it should be to a light thats nout like the original, no point otherwise
phase 2 zetec s, slammed, smoothed, euro'd, ronal turbo's, coilovers, stretched tyres
- woodwardsbodyshop
i wouldn't bother really, all the times i have seen it done there has been big gaps, not attractive, just get a subtle curved badboy, just to notch the corner of to make it more rounded and smooth, smooth out swage line on bonnet and smooth swage line on bumper, also smooth over washer jets and move to the scuttle panel, they make look small but you notice them gone straight away
- woodwardsbodyshop
This is a translation of the installation guide of polo 6n2 lights..
This isn’t created by myself, just a good try to translate it.
I will try to post the pictures .. as soon as they arrive..
for now.. here's the text..
Ok, to install the polo 6n2 lights into a mk3 fiesta you will have to modify the slam-panel (part where the lights fit in) A corner has to be taken out.
Also some cutting is required for the lights themselves to get the lights fitted. The original polo fixing points will have to go.
He used the old (fiesta) bracket ( I guess from an electrical adjustable headlamp) and fixed (plastic welded) it onto the polo light so he could use the original top fixing points.
He will create another point to fix them on his own fiesta, but the 2 top fixing points should do.
The first problem will arise. The lights will point inwards in stead of straight ahead. To solve this issue you can modify the housing. This isn’t done here yet, and a picture will be added when the modification is done.
The second issue is that the Polo light is arched whilst the fiesta indicator is straight.
You can modify the indicator to lign up.. also you can create a clear indicator then.
The german guy who did this mod can (and is willing to) create and sent these indicators..
To create these indicators you will need a polo indicator (reflector and clear glass) and glue this in and onto the fiesta indicator housing.
You can also use the original indicator and just put some clear glass over it .. and shape it correctly. Just your choice.
These are the 2 main problems that occur.
You will have to have a badboy bonnet, because the polo lights top line isn’t the same as the fiesta one, otherwise it will look ridiculous.
This is all the german could tell for now.. but he could have forgotten something.
The original german text
also um diese teile einzubauen musst du den schlossträger eine ganze ecke bearbeiten- also material weg nehmen..... das selbe gilt für den scheinwerfer- die originalen haltepunkte müssen alle ab..... dann den scheinwerfer stück für stück anpassen ist klar..... das erste problem was auftritt wenn sie mal drin sind ist dass die scheinwerfer nach innen leuchten und nicht gradeaus...... eine lösung des problems hab ich mir schon ausgedacht aber ich bin noch nicht dazu gekommen- es ist was an der halterung im scheinwerfer zu modifizieren- bilder gibts wenn es fertig ist...... die nächste sache ist dass die scheinwerfer gewölbt sind und die fiesta blinker nicht d.h. es bleibt eine kante..... an dieser lösung arbeite ich grade...... ich habe blinkergläser selbst angefertigt- ich kann auch kopien der gläser verschicken.. die selbst gemachten blinker sind dann auch klarglas.... ich habe den reflektor des polo blinker ausgeschnitten und in den fiesta blinker eingeschweißt mit kunststoff- sieht besser aus- das ist aber nicht notwendig.. das sind eigentlich die 2 hauptprobleme die auftreten..... optisch bräuchtest du eine haubenverlängerung- ähnlich wie meine dass man nicht sieht dass es ein poloscheinwerfer ist- sieht sonst sehr komisch aus um nicht zu sagen total scheiße..... und des weiteren ist eine xr2i stoßstange angebracht [ERRR] das auto mit der originalen aussieht wie ein fisch wenn sie drin sind......ach und die blinker musst du auch noch bearbeiten [ERRR] die sonst nicht mehr passen- man sieht aber wenn man versucht sie ein zu bauen was zu machen ist...... du kannst die originalen blinker klar machen in [ERRR] du versuchst das blinkerglas ab zu machen und dann die riffel abzuschleifen(immer feiner werden) und dann zu polieren oder du machst es so wie ich mit selbst angefertigten gläsern.....
.... ich hab mir einen halter an den scheinwerfer oben ran geschweißt mit kunststoff damit ich den oberen original halter der alten scheinwerfer benutzen kann aber ich schweiße mir noch einen an- also 2 haltepunkte brauchst du mindestens....
.... ich glaub ich müsste jetz erstmal das wichtigste erzählt haben...... aber kann sein dass mir noch was einfällt......
- Jur
