opening rear windows mk3... i've done them now. brief guide.
52 posts • Page 2 of 2 • 1, 2
Re: .
my_cougar49 :I got them off with a pair of pliers wrapped up in kitchen towel to stop the scratching the glass if I slipped. Just for safety I used masking tape around the rusted caps as well.
Cheers, i'll try that then later tonight
- AGAR
i bought some off ebay and took them to a local garage as i needed some other jobs doing so thought id let them do the windows too.
(plus im crap at diy usually).
got the car back and its as if the rubbers are too small.
they dont go right into the corners and look like there going to leek when it rains.
they said it looks like the rubbers have shrunk???
maybe the rubbers are off a different car....
shall i just go to fords and buy new rubbers,as the scrappers wont sell the rubbers seperate i wouldnt have thought will they....
well puzzled.
well puzzled.
- fiestyRS
With alot of help from ghost my rear opening windows are now done
Took him 5 mins each side. Looks wicked.
Didnt bother with rivet nuts or m4 jobbys.
Thanks again Ghost.
Thanks again Ghost.
- knuckles
- Your car: Fiesta Rs turbo
The seals were second hand but are fine. No wind noise and no water. I just used large rivets to fix the hinges because i dont have a rivnut gun. And the back clasp thing is just bolted on through the holes that are already there
- Raymondo
Just got to clean the dirt and grot from under the original rubbers before you put new windows in.
I aint even fixed the front hinges and it still secure.
- knuckles
sorry guys but just want to clear summit up as im fitting mine on the weekend....
ghost did you rivet the brackets into the B pillar?
- chris-fiesta
fitted my pop outs this weekend and it tookmaximum of 10 minutes each side..
rather than using the captive nuts I used 5mm rivets and they have done the job ace!!
chris
chris
- chris-fiesta
- chris-fiesta
Re: opening rear windows mk3... i've done them now. brief guide.
Does anyone know how much thee are brand new nowadays?
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
good guide, when flawlessy, thank you!
- m3matt
whats the part number for the macine screw that holds the front brackets, that bolt into the rivets
- KINGHORN
Anybody wanting to do this in the Birmingham area , I have the rivnut kit including pliers to be able to do this without a problem , just a thought .
- jonathanj
I know this is a post of 8!! years back,
Excelent shopping list (-:
Just a remark on the captive nuts (Rivnuts) fitting.
Fitting them with the special equipment doesn't use a nut at the end, it just 'pulls' on the thread (please don't mind my english as it is not my native language)
I've fitted these nuts both with, and without the special equipment in the past.
Without the special equipment
Use the same materials as in this guide, but leave the M4 bolt head untouched.
Put a m4 nut on the bolt, the m5 washer and then the rivnut.
Place in hole.
Use 2 wrenches .. one to hold the bolt in place (don't turn, just hold and keep the rivnut in the hole .. a ring or socket wrench is advised)
And tighten with the other the M4 nu .... when tight.. undo the m4 nut a bit.. and undo the bolt..
No grinding needed.., no bolt fishing needed.. and the result is the same
Adjusted picture
http://i106.photobucket.com/albums/m278 ... ivets2.jpg
[img]http://i106.photobucket.com/albums/m278/Jur_99/Fiesta/windowrivets2.jpg[/img]
Place in hole.
Adjusted picture
- Jur
