MY FIESTA RS PROJECT ...
That looks fookin awesome, front looks really meen and I quite like that bonnet vent, suits it imo!
6 Point Safety Devices Cage.
- purple_fiesta
- chris-fiesta
it may have arrived today ad???? i got a card but not had the chance to pick it up
so could be there
will fill you in.....
thanks for all the kind replies everyone
- MAD_Adamski
Looks awesome ad, loving the front end, didnt like the vent to start but its certainly growoing on me
Bet your so pleased with yourself for sticking with it!! must be the best feeling when you drove it/drive it for the first time
Ade
Ade
- Faith
- GeForce Junky
- Location: Gloucestershire Claims: To be FT's Sole Hillman Imp Launtic
thanks guys, faith it is a good feeling yes
but the problem is i haven't had the chance to test it much as the gearbox is shafted so the speedo wont work as its gone in the box
so never know how quick i am going
and can't thrash it till the setup is done, but the power is strong at 12psi was keeping up with a audi tt 225 tuesday so thats a good sign its pulling well... so hopefully i can test it when its setup
- MAD_Adamski
How hard was it to get the dash in as im considering doing the conversion on my Si and i heard that you have to cut a new hole in the bulkhead for the MK4/5 heater box?
- Cage
it is a hard conversion imo its worth keeping the mk3 heater and making air ducts to fit the mk5 dash as the wiring for the mk5 is quite different and can be complex
... dash fits well tho as described in projects guide, but i had 2 special nuts welded on the sides so the dash fits factory perfect and solid as a rock
- MAD_Adamski
ok small yet large update
new box is on!!!
works lovely feels great and drives much nicer
downside after fitting there seems to be 2 small problems
rubbing/slight grinding which we can't explain checked shafts,nuts bolts, rod ends, ball joints etc etc etc and all are fine
SO we have had to guess that the pass wheel bearing has gone s.h.i.t.e altho they were new!!! also the drivers side gearbox shaft seal is leaking slightly
must have happened by accident by gatman or something??
all said and done tho, FINGERS SUPREMELY CROSSED the car will be fit as a fiddle on tues for me to bring home.....
then rebook the rollers for a week tues (cutting it close to FF) then back to jamie for a few days for the touch up
and a valet
this is all down to if things go right
which in my book ain't too often!!!
thats me for now
Ad
new box is on!!!
thats me for now
Ad
- MAD_Adamski
Are you sure the grinding isn't the drive shaft touching the anti-roll bar? When does it happen? Gay news about the seal leaking already
A rolling road will not be happy with you taking that there and making a mess of their equipment, not one bit!
james: yes it isn't good hence me getting the leak sorted tomorrow.... also the grinding happens all the time any driving the faster you go the louder it gets nothing is touching that we can see its real odd we were both v v v confused so we thought the only thing it could be would be the bearing
we even had the car on a ramp and jacked the front and drove it through the gears it did it but we couldn't see where it was doing it
m4frd: have replied to your thread dunno if it helps
i was just unfortunate the seal was damaged not too much bother tho hopefully be all sorted tomorrow
only the grinding that worries me a touch
- MAD_Adamski
Boy oh boy gearbox oil costs a lot, when my driveshaft popped out it was like watching £10 notes dribble out!
75w90 grade if i remember?
- mike_wall15
Car: 2002 BMW M3
yes gents i have the correct stuff in and yes i filled it too the top no worries
the old box had loads of oil in too, turns out the old box was shafted+also this other rubbing prob not a good mix
- MAD_Adamski
i get a grinding noise everytime i pull off with my gearbox, was alot worse when i had the rs1800 box but it really annoys me!!
- chris-fiesta
well hopefully all sorted tonight my mate is going to replace the pass bearing and hope that solves it
as nothing else was rubbing
BUT on a brighter note the rollers are rebooked next tues
1st AUG
lets hope the car's a good car for a long time now!!!!
- MAD_Adamski
sweet.. looking forward to the results
My ProjectS..
viewtopic.php?t=97195&start=0
rich
07834862431
rich
07834862431
- rich_frst
ok went today got the train to go get the car
grinding was the bearing it was mashed!!!!!!
box is now fine too
so i went about finishing little niggly things on the car also cleaned the car about 1/2, just the alloy to finish and the dash and also if i have time a couple of other lil things i am thinking of
also car seemed a touch slow my boost guage was readin about 12psi
thne started being eratic, so i redid the pipe this time to find the car was only running 6 psi
, so soon altered that! back at 11psi peak now
feels much stronger gearbox is v good too car is a bit of a handful too takes some getting used too with the torque
ok so enough from me will be driving / checking the car for next week to make sure she's fine then to the rollers for the boost upped and the official BHP/LBFT
PICS i hear you say????
just catch the new gearbox in this pic
cheers Ad
box is now fine too
cheers Ad
- MAD_Adamski
- mike_wall15
Car: 2002 BMW M3
he has been in the fiesta ever since i owned it
''TIGER TURBO''
so he is sort of a lucky charm i always said he will stay when the car was finished
so he is so go finger ones b.u.t.t
''TIGER TURBO''
- MAD_Adamski
looks the balls ad!!!!!
its a credit to all your hard work matey!!! under the bay looks sweet...
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
also, you gonna be putting up any hew vids of the car in action?? like before...
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
- MAD_Adamski
looking excellent ad.... credit to you!
hope it makes the figures you expect on the rollers
i think 215bhp
good luck
good luck
- garyhurn77
my god ure car is gay, not bad though
- Rhinopower
- Your car: Volvo FH330
- XRMike
- XRMike
