My car!! UPDATE
83 posts • Page 3 of 3 • 1, 2, 3
- Dave G fsi
- Your car: Mk1 FRS and FRST
Re: My car!!
im not too sure iv heard as long as theres one on the front it should be ok, if not il have to make one up under the rear bumper somewhere
old fords never die...............they just get faster!!!!!
- white diamond
Re: My car!!
Mine has been through 2 MOT's with no towing eyes and hasn't failed
Should be okay mate.
- Big_Phil
Re: My car!! UPDATE
corrr been ages since an update.
well after a lot of hard work put in to the car i had finished all the body work n had it painted! looks the nuts now!!
it now has a half stripped interior aswel, painted the dash n all plastic in black so they look new, the rear is fully carpeted with black carpet
unfortunatly the head gasket went so it is now back off the road again. i have a new headgaset kit to fit along with a new thermostat, plugs, leads, oil + filter
whilst it was stripped down i thought i would give 'polishing' a try!!! it is cast alloy so i had to sand back all th casting marks with 80grit, then 120, 240 etc etc
then went through the wet sanding with 400, 600, 800 then 1200. finished off with some autosol metal rubbing compound.
heres the results!!!!!
thought i would polish up my thtottle body so it flows better, also removed one of the springs so it opens more freely. painted the brackets so it looks a bit newer
Before!
After!
Shortened my gear lever by an inch so it gives a 'short shift' effect, it now has a much better feel to it.
Before!
After!
Before!
After!
Before!
After!
- white diamond
Re: My car!!
Now have 1600 escort brakes to fit, vented discs and bigger calipers
Also got some H&R coilovers to go on!!!
Going to strip them all down an give them a repaint so its all new n fresh!
- white diamond
Re: My car!! UPDATE
TB and inlet look amasin man!
did you get the coilovers from the Hog?
Re: My car!! UPDATE
Yes coilovers bought from THEHOG
- white diamond
Re: My car!! UPDATE
lol coilies get about dont they
fiesta is looking good
- xr2irhys
Car: 1996 Ford Fiesta Classic
Re: My car!! UPDATE
you realise 1600 escort brakes are no bigger? only difference is theyre ventillated, much like the XR/SIRS brakes
Re: My car!! UPDATE!! Back again 2014!!! 2litre zetec!!!
well im unsure why I stopped using the site and posting updates!!
anyway onto some pictures!!!
back in 2011
at a local cruise with a mates mk4 puma powerd fez
I then fitted some 13inch 5 spokes which I sprayed imp blue
I then drove it like this for ages attending various shows meets cruises etc!!
the car always got lots of attention!!!
[/url]
back in 2011
[/url]old fords never die...............they just get faster!!!!!
- white diamond
Re: My car!! UPDATE
What happened to the cr in the end then mate??
- Gus!!
- Your car: Mk3 Fiesta ghia 1.1!!
