Postby heeman10 on Sat Jan 01, 2005 4:55 pm
No Max, I was disappointed in the looks of the thing mainly. I spoke with Wayne while they were developing it, and let him know that more and more, people were looking for a cooler which didn't require any cutting, and would sit below the bumper line. There the GRS EVO3 for anyone who wants something big, but to claim the other half of the market, we'd need something subtle. They did neither. It doesn't sit below the bumper line, and it's not a huge great thing that would rake in all the air available, it sort of peeps over the bumper at a funny angle :-?
They do use very free-flowing cores, but like Ian says, that may reduce lag and pressure drop, but doesn't cool as well as a more restrictive core. It's always lose-lose anyway from that perspective. The only way I see I can get what I want is to have a cooler made to my dimensions, which is what I plan on doing.
Postby Max M4X WW on Sat Jan 01, 2005 5:39 pm
Surley you could buy just the cooler from them, Mount it where you want and pipe it up :-?
Postby mike_wall15 on Sat Jan 01, 2005 5:47 pm
Hay, straw...all the same to us townies! :P
So do the ST150 brakes actually fit without modifying? I thought SimonT said it needed work :-?
If they fit on fine, then my advice would be to break the car and stop the project, just not worth wasting your money on it mate.... I'll give you £200 for the brakes! :lol:
:oooh:
mike_wall15
Car: 2002 BMW M3
Postby heeman10 on Sat Jan 01, 2005 10:19 pm
Max - The shape of it would make it a bugger to work with, I'd rather spend less money on a more useful intercooler built to my dimensions.
Mike - They seem fine to me I think....hard to tell fully without trying them a bit, but they certainly bolt on with the same bolts, so no drilling required.
Postby James-UK on Sat Jan 01, 2005 10:47 pm
What happened to the diesel engine then, do you know why/how it died?
James-UK
Location: Cornwall Drives:Whatever is outside at the time.
Postby heeman10 on Sun Jan 02, 2005 5:02 pm
James - A question I get asked a lot, followed by "It was the boost wasn't it?". I still deny that as the reason, and believe it was a slow-forming problem created when a metal water pipe fractured and the engine ran dry, at about 90mph for something like 50 miles on a hot summers day, only indicating a mild increase in temperature because there was no water in the system, just air. It got worse and worse, and in the final stages was putting huge pressure through the cooling system, making me think a cylinder has cracked and the combustion process was forcing the gases into the water jacket. It's now in the hands of another FT.com member and he has a replacement bottom end coming for it. Would love to see it back in action!
Postby Max M4X WW on Sun Jan 02, 2005 6:25 pm
heeman10 :It's now in the hands of another FT.com member
Who who who???
Postby FezzR on Sun Jan 02, 2005 8:21 pm
Max M4X WW :
Who who who???
you really are thick as pig s**t aint you :rolleyes:
if the person wanted everyone to know he has got the tdi engine then heman would have named them.
or they would have posted detailing thier plans for their car and engine Image
FezzR
God Damn Lazy
God Damn Lazy
Postby StreetDragster on Sun Jan 02, 2005 8:27 pm
Looking Good James!!!
What do you mean by this---
and my Mondeo starter motor came this morning too
What starter motor you using and any particular reason why?
Matt
(Using the FRST Starter, and its getting too hot)
StreetDragster
Postby FezzR on Sun Jan 02, 2005 8:37 pm
StreetDragster :Looking Good James!!!
Matt
i would assume any Mondeo start would be stronger than a fiesta one,
diesel engine with their higher compression ratios will require a stonger starter motor also
FezzR
God Damn Lazy
God Damn Lazy
Postby StreetDragster on Sun Jan 02, 2005 8:41 pm
Probably the case, i'm only having problems with starting when hot because the exhaust is close to the starter, the FRST starts the car no problem when cold.
Matt
StreetDragster
Postby Max M4X WW on Sun Jan 02, 2005 8:51 pm
FezzR :
Max M4X WW :
Who who who???
you really are thick as pig poo aint you :rolleyes:
Maybe they just havent got round to it or they dont use this place as much as some of us or they think no one would care?
Postby FezzR on Sun Jan 02, 2005 10:16 pm
StreetDragster :Probably the case, i'm only having problems with starting when hot because the exhaust is close to the starter, the FRST starts the car no problem when cold.
Matt
got the frst heat shield? or room for it?
FezzR
God Damn Lazy
God Damn Lazy
Postby StreetDragster on Mon Jan 03, 2005 12:06 pm
I will have when i get off my arse to fit it :D
Matt
StreetDragster
Postby heeman10 on Mon Jan 03, 2005 7:33 pm
Now now children! As Ian said though, I didn't mention the buyer's name for a reason, just as I didn't mention Mikee when I picked the engine up off him. I'm sure he'll tell all when he knows what's happening.
Matt - You ask a good quetsion - why use the Mondeo starter? Well...it doesn't work, so I know have a FRST starter on it :lol: Did the FRST have a shield as standard then?
Update from last night and today
Got the flywheel dowels from Ford at last, so flywheel on, clutch on:
Then to fit the gearbox. The shim plate that came with it didn't have a cut-out for the CPS, so that needed changing as follows:
Held it up, saw where it needed cutting back, then stitch-drilled it out:
Ground back the rough bits and ended up with this:
Then went for a trial fit. Wasn't quite enough, so a bit more grinding...
And on it went, you can see where it needed to clear the CPS (silver circle on the left!)
So, gearbox on, lifted it back onto the pallet truck and it was ready to go in:
Oo er :aaah:
And it's in! Of course there are still things to do, but I can't say it wasn't a nice sight :)
Then came the bad part...towing it back to its shed :( It's only about 50-100m, but on the two corners I had to turn, I was getting a kind of rubbing...clunking....jumping noise/feeling, perhaps 3, 4 or 5 times per wheel revolution? It did not feel good, and I'm wondering if it was a driveshaft not in place properly. I'm sure I remember people saying the FRST had longer driveshafts, so I'm wondering if I need different driveshafts, and the diesel ones just aren't long enough. Any ideas? It was only on very tight turns...it was too dark to investigate.
Anyway, it's now in the smaller shed. It used to be where my sister's Polo is, but my dad moved a trailer so it can go where it is now, and the ramp's shallower so no more exhaust scraping when I drive in :D
Postby FezzR on Mon Jan 03, 2005 7:43 pm
FRST didnt have the shield as standard but it is a ford part, so optional i suppose
yead sounds like the noise you get when the shafts arent in properly and they hit arms and stuff as the wheels turns the shaft
FezzR
God Damn Lazy
God Damn Lazy
Postby heeman10 on Mon Jan 03, 2005 7:56 pm
No it was still on enough for the gaitor to be attached without the clip around it, it was still physically in the hole, I just wonder if it had partially disengaged for some strange strange reason. Something's definitely not right down there.
Postby FezzR on Mon Jan 03, 2005 8:01 pm
please paint your calipers, or just laqure them or summink
FezzR
God Damn Lazy
God Damn Lazy
Postby StreetDragster on Mon Jan 03, 2005 8:26 pm
Alright James,
Did you have you hub nuts up to torque? Mine made exactly the same type of noise when i moved mine without the hub nuts tightened up.
Shield came as standard, about £23 from Ford, i bought one last week, Item 3 in the pic, FINIS 1654781 :D
Hope that helps, looking good, got my mates rebuilt FRST started today, were happy aswell, but his starter motor was also toast, so it running mine for now.
Matt
StreetDragster
Postby Sphinx on Mon Jan 03, 2005 9:43 pm
Looking very good!! Working really fast by the looks of it!! :)
Oh have i got a lot of questions for you when you get on msn :lol:
Postby Max M4X WW on Mon Jan 03, 2005 9:56 pm
How easy were the brakes to fit? I really want some!!!!!
Engine looks lovley in, Rocker really matches car 8)
Postby ju575 on Mon Jan 03, 2005 11:30 pm
looking great :D
Best use of pallet trucks i've seen yet though :lol:
Hopefullyyou'll get it all sorted fo FITP so we can all see it properly :)
ju575
Postby heeman10 on Mon Jan 03, 2005 11:50 pm
Ian - Why? My last ones were red, and I think too many pikeys are painting their calipers these days, gotta keep on your toes otherwise what you thought looked ok and customised can now throw you into chavdom! I think they look ok silver. Am making a conscious effort not to concentrate on small details like that, and cleaning things, and polishing/chrome etc for now, focusing on the important stuff for now :)
Matt - I left the hubs on the ends of the shafts throughout. The gearbox has no oil in yet...would that cause some problems of this sort?? Thanks a bunch for the heatshield info ;) Glad your mate's is working now, he can now be toasted by The White One :devil:
sphinx - Yeah I thought today...I guess I can't complain at putting an engine in, fitting the AND getting it back on the ground in such a short time period. Looks like I'll be having a few late MSN nights when I get back to uni :lol:
Max - They bolted straight on, and as far as I can tell so far there are no problems. Need to bleed all the braking system thoroughly, as we did it briefly just to get it all rolling today. Pedal travel is long, but I think it's to be expected. Wasn't expecting them to feel spongy, but that could be down to a long-awaited fluid change. I noticed the cam cover colour match just as I left the car tonight, good innit? :D
ju575 - I'm not expecting to be at FITP this year sadly :( I go back to uni in about five days till March or something. There's too much to do in the time available to me, bearing in mind MSD need about a 2 month warning before my live map! Next year eh?
Postby RS_Rawli on Mon Jan 03, 2005 11:59 pm
5 days :o :o :o
im not back for another fortnight mate, why so soon
RS_Rawli
Postby heeman10 on Tue Jan 04, 2005 12:13 am
Cos there's nothing to do at home, mates all live MILES away, and got lots of work to be done, need clothes, gym, and people really! :lol: See you back in Depresston ;)
Postby Ben_frst on Tue Jan 04, 2005 12:33 am
did u sort ya shaft prob? if not did you replace the retaining clips b4 fitting them and another thought did u check the CVs as there not rly that hard 2 break when removing as far as i know all mk 3 fiesta shafts are the same :)
Ben_frst
Postby MAD_Adamski on Tue Jan 04, 2005 2:44 am
james looking all good!!!! get ur ass on msn to tell me more!!! :D
MAD_Adamski
Postby heeman10 on Tue Jan 04, 2005 4:50 pm
Ben - No I didn't replace the clips. Haynes said you should, but they look alright, and most Haynes stuff can be disregarded usually :lol: Do they really need replacing then? Haven't had a look yet, but will see if the joints are still properly engaged. The driveshaft problem was...let's say...a judgement error :lol: Diesel and petrol driveshaft ends are indeed the same! :rolleyes:
Ad - Yeah I'll have proper net and communication in 5 days or so :D You can fill me in on the crazy Scottish new year :lol:
Postby wilson123 on Tue Jan 04, 2005 5:03 pm
looking quality mate! The speed your moving on seems crazy too, I've only had a turd, got p1ssed up and ate xmas dinner and you've done all this :lol:
What ya pay for the Zetec Turbo engine?
:'( goodbye uni it has been fun!
wilson123
Postby heeman10 on Tue Jan 04, 2005 5:44 pm
Rich - You really do have a way with words don't you? :lol: I paid money for the engine :p Might given an indication of the final price of the conversion once it's all done :)
Postby FezzR on Tue Jan 04, 2005 7:13 pm
reason for painting them, SO THEY DONT RUST!
did i say paint em red?
i suggested Laquer so they stay the colour they are now :P
i would have replaced the driveshaft clips, but IF the shafts are back in and secure your probably alright
heeman10 :Rich - You really do have a way with words don't you? :lol: I paid money for the engine :p Might given an indication of the final price of the conversion once it's all done :)
so the price you were gonna sell it for doesnt reflect what you paid??
FezzR
God Damn Lazy
God Damn Lazy
Postby xrsi on Tue Jan 04, 2005 7:14 pm
looking good mate!
bet ya cant wait to get it all running!
a 2i interior loom is exactly the same as an FRST if that is any help! prob easier to come by and cheaper as well as it hasnt got the RS inflated price to go with it even tho its the same thing!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby StreetDragster on Tue Jan 04, 2005 7:19 pm
Matt - I left the hubs on the ends of the shafts throughout. The gearbox has no oil in yet...would that cause some problems of this sort?? Thanks a bunch for the heatshield info Glad your mate's is working now, he can now be toasted by The White One
Alright James,
Are they on and torqued up or just finger tight?? The hub nuts when tight will hold the wheel bearings together you see, if they are loose, the bearing may start to seperate, the hub will become unsquare to the hub carrier and the brake discs will contact the pads (this is what happened to me). Failing that check that when on full lock or whenever this noise is being made that the cv joints arn't touching the hub carrier (may need a mirror and torch for that one) I doubt the oil int he gearbox would make the noise you describe, unless its the diff making the noise (If LSD is very possible)
On your intercooler problem, why don't you want the Evo 3? Is it because its not stealth enough, because if thats the case, with a bit of nipping and tucking it can be made to be almost stealth, failing that the small one like GavRST's???
Matt
P.S I may toast him now, cause he's almost standard, but in 6-8 months when we do his ZVH conversion he may be a serious contender! I'll have to leave a few nuts in the cylinders when we do his rebuild :)
StreetDragster
Postby andyhardy on Tue Jan 04, 2005 7:25 pm
Postby Andy.B on Wed Jan 05, 2005 11:27 am
Weezer 8) cool stuff :D
Andy.B
