MWSTEWART | Guide: Fit Mondeo Mk2 Master Cylinder and Servo
9 posts • Page 1 of 1
Re: Guide: Fit Mondeo Mk2 Master Cylinder and Servo
good read buddy and looks like there is no adjustment reqired to the bar as with the escort one!
altho i may end up waiting and fitting a pedal box now as my fse will prob foul the servo!
- dangerousdave
Nice one, will move it to the guide section. Please don't compile loads of awesome guides then delete the site like project did
- JamieFRST
- Keep It Tidy
Cheers chaps. My site is on the FT server :) Big Horse Phallus.
ive been after a guide on this in aaaaaaages,, as ive got 2 mondeo servos in the garage, just abit too pusy to fiddle about and get them to fit,
nice one
nice one
- curly
im doing this on mine,
whats the differance between the mk1 and mk2 servo? as all i can find is the mk1 version.
Excursion on my set up there are one set of pipes that are m13 and one set m10, so it just bolts up with a bit of pipe manipulation
also from what i can make out the cap wires are the same but will investigate further.
the mk1 servo you can get one from a cable clutch with the hydrolic clutch take off bunged up from the factory.
- AW3K
Cheers, that's handy to know about the Mk1 reservoir. I might order one of those.
I did another one last weekend and used an ABS MC, as you have there. I used two M10 T pieces to split the existing lines, then made a bit of pipe to join from T's to MC. I didn't even need to cut any of the existing lines, just bend them. Far easier than using the non-ABS MC!
anyone got any feedback on this is it worth doing? ive got escort cossy brakes and its still not as good as it should be
- stu_frst
i've done this and i can feel a diff,
i have escort rs2k fronts and focus discs on the rear and it stops on a penny
http://www.fiestaguides.co.uk has guides i wrote on this and the focus rears
- AW3K
