Excursion :ianFRST :how did you get them spare wheel brackets off![]()
i had a quick look, but decided against wrecking my car in order to remove them
There wasn't enough room to get the drill/spot weld bit in there. I chopped off the top with the angle grinder then ground off what was left. It took around an hour
yup thats how i did mine to, not a too bad a job really, the other side of the hanger was the bugger i found!
looking good mate let hope you crack on this weekend with loads of pics
- FezzR
- God Damn Lazy
Just read this post from start to now, and FCUK ME you've put some serious hard work into it!!!
Good luck with the rest of the project!
Escort GTI Turbo
- LeePFRST
Car: 1990 Ford Fiesta RS Turbo
Audi 02M Quattro 6 speed gearbox & transfer box:
Point of note: the top bellhousing bolt centres are at 135mm - exactly the same as the Ford Zetec, Interesting!
Transfer box:
Input side:
O/S output:
Combined:
I also picked up a spare set of driveshafts & CV's:
Transfer box:
Input side:
O/S output:
Combined:
- Mikee_RS
Car: 1995 Ford Fiesta
gonna be an impressive car that is.
have you considered using a TT 225 engine aswell? could save alot of hassle in the long run. quite a few place do after market management aswell.
- James-UK
- Location: Cornwall Drives:Whatever is outside at the time.
Wicked mate! Looks sexy!!
How high will the prop output be in comparison to the floor of the car as a matter of interest?
Steve
Steve
- Captain Tightpants
very nice mark!!! like the project mate.... cant wait to see it all come together....
rich
rich
My ProjectS..
viewtopic.php?t=97195&start=0
rich
07834862431
rich
07834862431
- rich_frst
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
- XRMike
Very nice, what mower do you use on your grass and how do you keep it looking so dry in this poor weather?
Seriously though - can't wait to see all this stuff being modified to fit the Ford setup, will be awesome when done
- andyhardy
andyhardy :Very nice, what mower do you use on your grass and how do you keep it looking so dry in this poor weather?![]()
Cool to see all this progress. Interesting point about the gearbox location, should come in handy when adapting the bellhousing to suit. Looking forward to seeing the fabrication work coming up on the underside i must say. Keep up the good work sir.
- Pez
coming on brilliantly fella. thats an interesting thing about the top gearbox mounts being the same width apart. does the main shaft centre up with the engine.
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
James-UK To be honest, no i haven't, but I don't want to as 1)it'll makes things too easy and 2)I want to keep everything 'Ford' as much as possible
Ian Nice one, I'll remember that. Cheers!
Boris lol he loves it, a high cholesterol sl@g
Mr Steve No idea our kid, not til e in car like
andyhardy lol!! Yeah I've killed the grass by walking on it too much (between the house and garage)
Ian Yep agreed, I'll do my best mate
JJ Now that I can't answer atm, more than likely not...I may be pleasantly suprised though!
Cheers everyone else for the support, there's a lot of love in here tonight
Will get up some more interesting pics soon, with some stuff I've made.
i'll have a look and measure up a fiesta 'box for ya tommorow if you want, then you'll be able to find out
JJ
JJ
- jdfiesta
- Your car: V70 T5
Just a quick question, did you make your own caliper brackets to utilise the FRS Brembos or are they the ZooMotorsport ones. If they are the zoo ones, whats the quality/fit etc of them?IE did the calipers still require machining to fit under 16's or seriously throw the offset off?
- muz
dude since u live just down the road from me pretty much i expect a ride in this car when its done lol. looks fuckin amazing. Always wanted a go in a 4wd fezz haha
keep it up m8
ollie
keep it up m8
ollie
- niracka
- Your car: E46 M3
muz - my own mate, I had the wheels and calipers machined. VERY tight fit under 16's, I'd recommend a 320mm disc.
Ollie No prob!
I've been pretty slack with the car recently, not done anything for weeks! Got stuck back in this past few days though stripped the remainder of the underseal, exposed the seams and welded them.
I'm going all out with the seam welding, going beyond what would normally be done...but every little helps
As above but with the welds cleaned:
Rear end:
Ollie No prob!
Rear end:
How useful being able to work on the car on its side like that, the benefits of spit-roasting it are enormous! Imagine trying to clean off the underside, then weld all that lot with it up in the air, straining around underneath it!! Do you fancy a Norris Designsesque chopping and lowering of the A, B and C pillars to reduce weight and C of G?
Keep on with it matey, a lot of satisfying stuff yet to come
DaveRom :Looks excellent as usual![]()
Have you managed to start the Robot Wars project yet?
lol no, the moral and human rights issues got the better of me
- GavStyli
- Your car: Fiesta Turbo
bumbaclaaart!!!!
Nice one Mr Stewart. Good to see you in action once more, the living legend that is Excursion.
- chumkila
- Dirty Post Whore!
- ant pittaway
