Muz's Escort RS Turbo TRACK CAR. Lancia Integrale bonnet on
Re: Muz's Escort RS Turbo. Fusebox dash panel finished.
jonyb4 :dont understand why the relays needs to be there though, but looks very good
Race car style, so everything is easily accessable and close to hand. I like that look in a track car.
FRSJON :nice one mate,something i wish id done
Something to think about, Jon? It's pretty easy to do, to be fair. Fingers crossed it works ...
- muz
it does look cool
actually really like the panel muz looks smart! unlike the poofta owner
- MAD_Adamski
jonyb4 :it does look cool
Also hugely practical, good call.
Nothing to see here...
- andymac
- Elite Pie Master
MAD_Adamski :actually really like the panel muz looks smart! unlike the poofta owner
Adam, you are, without a doubt, the biggest repressed homosexual I know!
Few new bits bought for the car.
A lifeline twin chamber extinguisher and Mocal oil cooler sandwich plate with thermo and lines.
- muz
god thats a piece of kit!
Not much of an update but got a few more bits in paint. My rocker cover and fuel rail are at AH Fabrications getting JIC fittings welded on and a new oil catch can is being made. I also picked up my new fuel swirl pot off them with JICs. GOne for a 1l item to keep it nice and small and I've worked out at full load it will give me 30 seconds of surge protection, which is plenty.
That soon went matt black with the rest of my little bits which needed doing, FPR, fire extinguisher mount and clutch master cylinder.
and my alloy fuel filter
I've put an order in withTorques for all the JIC fittings and teflon hose I need to finish the car (about 20!) so they should arrive in time for when I'm next home and able to work on the car.
- muz
very nice
Really nice mate. Cnt wait to see more
- fiestarsturboblack
- Your car: fiesta rs turbo
Few more bits.
Got a Fuelab fuel pressure regulator and a new controller for the fire system.
All my Torques fittings and new hosing arrived
Rocker modified with a single -10 outlet and the others blanked off, a proper mount on the oil separator and -6's put on the fuel rail.
and a new catch can made up with proper breather and -12 fitting.
- muz
Only did a few hours this morning as I have to go pick the mrs up from work, so decided to finish my fusebox panel.
Decided to move the kill switch to the little panel on the dash where the speaker thingy goes to free up some room for the switches.
The engine start button has gone in it's place along with switches for fan over ride, fuel pumps, anti lag and ignition relay and a spare for when I need it. Still need to buy a horn button and put it in the top right corner.
Also got rid of the fire pull as I'm now using an electrical system.
Mounted the fire controller into the dash.
Done all the wiring I can outside of the car. Now I need to connect it to the car loom and power source then make the looms up for headlights, horn, thermostat etc.
- muz
Thought it's about time I got the fuel system installed. Decided that the fuel pumps looked odd, one being dull silver, the other being an off-gold colour, so decided to paint them. Found an unmarked tin of 1k in my workshop and it turned out to be a matt Battleship Grey type colour so thought I'd see how they came out, and love it! Great colour for the pumps.
While I was at it I painted the fuel rail, catch can, rocker cover, and oil separator matt black and treated them to the new style AH decals.
I didn't like how blingy the Fuelab reg looked with the silver bottom, and the badly etched idiot instructions on the front so I filed them off and gave it a coat of matt black too. The blue I can live with as it matches the fittings.
Proper bulkhead fittings. I needed to knock up some spacers for them to sit properly.
All fitted up
Time to make some fuel lines. Luckily, some of my existing braided fuel lines had barbed connectors on already to join to the fuel tank ect, so these were made useful.
The accumulator has been removed and the filter now sits where this was.
Catch can fitted
Next thing was where to mount the breather and regulator. I decided to mount them on the strut brace so knocked up a few mounts for these.
While I had the welder out I decided to knock up a mount for the rear tow strap.
and got a small job out of the way mounting my cooling fans.
Engine bay as it stands.
All fitted up
Catch can fitted
- muz
Thats the sort of updates i like
- mikeymikeyp
Very nice
Re: Muz's Escort RS Turbo TRACK CAR. QUIP FUEL LINES AND FUEL SY
looks great muz
any reason you havent done a coil pack conversion ?
- FRSJON
It will be one of the first things I do when Jano sets it up. Notice there's a switch for Anti Lag, also.
- muz
Gave it a long overdue wash today. the water coming off the car was brown. This is just hosed off, nothing else. Needs a proper, full valet when it's back on the road.
and also fitted my battery kill pull and fire extinguisher button.
- muz
looks great muz
... just not sure on the yellow ah fab stickers
maybe window mounted versions???
- FRSJON
Agreed car does look great muz.
Not had much time to work on the old girl lately due to work and no money due to getting married in November, but had a little play with the front bumper today. While the cooling package will certainly be effective, using anything resembling a standard front bumper is completely out of the question, so had to get creative.
My already modified bumper before I started.
Due to where the pipe work needs to go some of the bumper foam needed removing. As its a track car I decided to remove all of the foam out of the bumper and the original mounts and have a little trim to get it to roughly fit and cut the holes for Aerocatches.
Trail fit and it's all good. Needs some filler here and there but at least I know a front bumper fits! You can see in the pictures how big it is!
- muz
Love it muz. [ERRR] have u got left o do?? An how easy is it to plumb in the fire extinguisher an electrical part of it???
looks superb muz
- ollieRS
I hadnt realised this is a track star ,thats a lot of work for a track female provider of 'horizontal refreshment' ,have you got a track motor at the moment
- mikeymikeyp
Long time no see/speak!
Car is looking great, can I ask what size those fans are? They look like Kenlowe's? Mine have a load of plastic grates over and look a lot thicker. Are they OK exposed to possible debris and rain like that? Or are they dry weather only?
They are 10 inch Kenlowes, Max. They will be fine on the front like that. I shouldn't think rain would cause a problem? Debris wise, not too fused if they are damaged. I would rather replace a fan than the intercooler!
Bit of an update:
The main effort the last few days has been to trim back the rear arches to stop the rear wheel rubbing. Can't make that any more exciting than it is.
and done. The wheels don't catch at all now, so I'm happy.
Apparently I do a lot of this when I work on the car
A few pics of some odd jobs I've squared away.
Made up some 170MPH dials.
Done the hydraulic clutch
Made some small carbon fibre mudguards with a odd piece of carbon I had kicking around.
I also wasn't happy with the rear brake lines as they ran very close to the tyre, so I've replaced with with proper 90 degree bulkhead fittings and re made the rear lines.
Bit of an update:
- muz
Quality muz total quality
,see your brake bais/master /servo thing is it a straight fit as in take off the old one and just bolt it up ,,,iv been looking at a few for a mates s2 just wanted a straight fit,, thats why i was asking
- mikeymikeyp
mikeymikeyp :Quality muz total quality
Yeah, it's a straight fit. Removed the servo and bolt this on the existing mounts. As to how good it performs, though, I couldn't tell you I'm yet to test it.
- muz
muz :mikeymikeyp :Quality muz total quality
cheers mate whered you get it from
- mikeymikeyp
I bought it off a mate but you can get them from Compbrake.
- muz
Well, it's been a long time coming, but I bothered my ass to tidy the workshop up. It probably didn't look too bad in the pics, but it was seriously, seriously untidy! To the point where it wasn't a nice place to work on the car, hard to actually find anything, tools missing etc.
Wheeled the car back and this is the state of it.
I also decided I wanted my locker down at the bottom of the workshop and have the work bench back to work on.
And all clean.
I might be a little more enthusiastic to actually work on it now.
And all clean.
- muz
Finally got round finishing my fuse box build. As with pretty much everything, I do something, am not happy with it, so do it again
Nice package from Polevolt. New cable where needed, and proper connectors and covers.
Bit of a difference between the old looms and the new ones!
New fan loom.
New headlight looms
Fuse and relay set up all wired up.
Then I needed to put the dash in to see how much cable length I needed to reach etc and thought I'd have a little test fit.
Now all that's needed is to wire up the gauges and the rocker switches and hopefully the wiring is all finished.
The wiring is a massive hurdle, as when finished I can then fit the dash and put the seats in and the interior is complete.
New fan loom.
New headlight looms
- muz
- FRSJON
- MAD_Adamski
- mikeymikeyp
