Modification Products (FAO Adrian)
4 posts • Page 1 of 1
Right...
I added new products in the Transmission and Suspension categories, and because they were in those specific categories, I omitted 'gearbox' and 'suspension' off both of the product names. Now, when you see the modifications listed in the main garage menu, it looks a bit odd because it lists "OE Fiesta RS Turbo" and "Ford BC - 5 Speed non-LSD (Standard)"
I take it there's no way I can edit these now, even though I'm the creator? I assume because someone else can select these products and it would then be kind of irritating for them if their modification suddenly changed
So could these be altered for me (and obviously anyone else who wishes to select them) to have "Gearbox" (or may be "Transmission") and "Suspension" (or may be "Shock Absorbers and Springs" - I don't know which would be better really?) added to the ends of these products, pleeeeeease?
I decided to post this instead of just PM'ing Adrian so that others could may be see what caught me out before doing it themselves
Edit: I know I could delete the modifications and then add new ones, but this would then leave the products still and make it rather untidy, or so I assume?
- Smo
Re: Modification Products (FAO Adrian)
I've edited these. It's all based on IDs, so if someone adds "Recaros" and it changes to "OEM Recaros" anyone who added it when it was "Recaros" will be automatically updated to the new name.
Anyone can add products but only the admin can edit them.
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
Yeah, that's what I thought would happen! (I've a fairly good understanding of database design
Cheers for that
One other thing... Should there be an "Exhaust" category, or is that something that really comes under Engine?
Cheers for that
- Smo
Just went to edit a modification too, and when I clicked "Modify Modification", I got this:
The things I adjusted were the Product Rating (previously left blank) and the Purchase Rating (also previously left blank).
General Error
SQL ERROR [ mysqli ]
Out of range value adjusted for column 'installer_id' at row 1 [1264]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Please notify the board administrator or webmaster: forums.admin@fiestaturbo.com
- Smo
