mk3 fiesta heaters not working?
8 posts • Page 1 of 1
mate was complainging about his heaters not working. He said the fan cuts in an everything on his frst, however when he puts the interior heaters on you get nothing, just the revs drop abit as if the heaters have been put on, and its draining power?
any ideas on whats wrong?
* I TOLD YOU FIGHTING THE RS CAUSE *
- RScrew69
- Brammer
- Your car: Sierra Cosworth
someone must know what he can do to sort it, it seems like the heaters wanna work cos the revs drop, but why don't they work?
anyone else had this problem before? can't find anything in the search forums aswell.
Anything or ideas on similar or how you'd go about fixing the problem folks?
nice one
nice one
- RScrew69
try the interior fan 'resistor' under the paravan
this is under the bonnet .. where the interior fan electrical connection is made..
replace the resistor .. and i guess your problems are solved..
- Jur
RScrew69 :interior fan resistor? not heard or seen this before, and whats a paravan?
First of all (-: i'm from holland.. so some things are called differently in english .. ..
the interior fan is .. just like the window whiper mechanism in a compartment under the bonnet.. in dutch we call the piece of metal with the vents a "paravan" (it can also be of plastic with other models/types of cars)
ok .. back to the topic.. the resistor i'm talking about is a coil-resistor.. and has several connections..
your interior fan has 4 positions .. 0 = off .. 3 = full power..
this resistor controls the speed of the fan. and is (indirectly) controlled by the switch of the interior fan.
- Jur
