Megasquirt ECU Fitted!Throttle Bodies Running!New Head!!PG10
looks brill, defo get a filter on them TB's before it goes up in flames though!
6 Point Safety Devices Cage.
- purple_fiesta
Cheers guys!
Yeah it does pop alot!
Current updates are - not many! lol
I still have the head to put on, and to sort a less restrictive exhaust manifold.
Im also planning on tidying up some under bonnet wiring and fitting an ITG Megaflow Air Filter.
Once all this is done, hopefully i wont be tempted to do any more engine mods! lol
Im aiming to have it all in before Ford Fair and mapping it up too. Want to do some runs there.
Asad
Asad
- Asad
- ant pittaway
jim566 :Even tho i dont drive a fiesta may i congratulate you on your hard work and extremely informative how to. You seem to have made a name for yourself m8 hence i ended up here. TOP JOB![]()
*scuttles off to start work on his mondeo*
now thats a proper 1st post
welcome to the board mate
- CyberMODS
Cheers for all the comments!
Was definitely a top project and getting more and more popular!
Let me know if you need a hand
Asad
- Asad
ive got a 2.0l zetec running megasquirt.
ported and polished head, 2050cc, kent cams and pulleys, 4-2-1 manifold, higher compression, large exhaust system.
badly needs more mapping tho.
also i will be fitting honda fireblade throttle boddies later this year.
- escortbreakers.co.uk
asad; in your megasquirt, do you changed r4 and r7 resistors from the original values to the 27k ohm recomended for ford sensors, and then calibrate with easytherm, or only calibrate with original resistors, or how do you did it?
could you give me your config files for that? and your base maps for a 1.8 everything standard?
thanks
thanks
- krestudon
Hi,
Just change the reisiters to 27k . . noi calibration is needed they will work straight off.
We sell MS ECUs built and setup for Zetecs at http://www..mtechautomotive.co.uk
Have a look . .
Matty
Have a look . .
Matty
- DJMattyT
thanks i already have an assembled MS, all i need now is a base map to start working
i've been looking at your forums but where the 1.8 base map should be, i cant see nothing.
i've tried registering, but i cant log in...
- krestudon
Any vids? Ive just got myself a set of bodies and read through this entire post, very interesting! No doubt i'll br pestering you with a few pm's trying to set up my ms, if that ok?
cheers!
cheers!
- lucasdemoley
- muz
my mate has a 2.1zetec running gsxr1000 bodies and everything else imaginable as well as megasquirt.
just a quick video of induction noise while mapping around blackpool
http://www.youtube.com/watch?v=hlfpkJxYP3g
Formally Andyswidefez
Yes, i have a fat RS! lol
BIASmotorsport
- AndysFatRS
BIASmotorsport
- AndysFatRS
andyswidefez :my mate has a 2.1zetec running gsxr1000 bodies and everything else imaginable as well as megasquirt.
I'm guessing that gauge on the laptop that's flashing/flicking rapidly is the air/fuel ratio? Is he running narrowband/standard lambda still?
- Smo
yeah thats afr. hes running a narrowband sensor thats knackered, but its not running alpha-n yet so it doesnt reference the sensor. although for mapping purposes there is a wideband mounted in the manifold and the reader hanging from the rear view mirror
BIASmotorsport
- AndysFatRS
