Just Lowered and Getting Bad Rubbing! UPDATE!
Postby MrRS1800 on Tue Dec 20, 2005 9:04 pm
UPDATE:
Following on from below, i went and checked the part numbers on the suspension last night, only to discover that ive been sent the wrong kit!!!! Ive got the 60mm kit when i asked for the 35mm!! No wonder its rubbing!! Thats from a company called soundsperformance on ebay, so beware! I dont know whats going to happen now, have contacted them so ill see what they come back at me with. Cheers for all your ideas tho guys!
Just lowered my RS1800 by 35mm using a GMax shock and spring kit. The cars got 15 inch rims with 195/45 tyres.
Thought everything would be fine but im getting some mega rubbing on the front. Has anyone else experianced this?
The car seems very low for just a 35 drop, wasnt expecting it to be this low. Im hoping its just on the arches which i will attempt to roll tommorow! Also it seems lower at the front then the rear... hmmm
Image[/img]
MrRS1800
Postby Dazza on Wed Dec 21, 2005 12:45 am
Did you buy the suspenions new or 2nd hand?
Its possible you have the wrong ones, either Mk3 or Mk3.5 as am led to believe there different.
Try and find out what its catching on
Dazza
Postby knuckles on Wed Dec 21, 2005 1:16 am
Fact : Did you know the Rs 1800 is lower than a standard 1.1 fiesta :D
Im not sure how much lower but if you lowered 35mm using gmax then technically your car may be 45mm lower than the standard fiesta.
So either get arches modified or try a set of spacers.
One last thing - dont fully load the car with people then go over speed bumps. Thats the quickest way to ruin the exhaust.
Knuckles :)
knuckles
Your car: Fiesta Rs turbo
Postby The Gilly on Wed Dec 21, 2005 7:40 am
cars a generally lower atthe front due to the weight of the engine
does my big look arse in this?
The Gilly
Postby musicdrummer42 on Wed Dec 21, 2005 8:55 am
how the hell do you get scrubbing, mine's lowered about 45-50mm front on 195/50/15 tyres and it doesn't scrub at all.
musicdrummer42
Postby mrorange2 on Wed Dec 21, 2005 9:06 am
My FRST scrubs on the front drivers side its just had GMAX shocks and springs installed. has rolling your arches worked for you?
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby rsboy82 on Wed Dec 21, 2005 10:21 am
mines lowered 60mm with 45 profiles on and i have no scrubbing at all apart from on full lock maybe try lower profile tyres
rsboy82
Postby mrorange2 on Wed Dec 21, 2005 10:41 am
i know my problem will be because i have 50's on need 45 just bit strange that it only rubs on one side. How ever r_bowdidge has 45's on so i cant see why he's getting troubles. I have noticed that the Gmax suspention aint that hard still got some roll to it. did you get the 35mm kit or 30mm?
mrorange2
Postby Brammer on Wed Dec 21, 2005 10:57 am
Mine scrubs on the front and i'm on g-max and standard rims need to get the archs rolled the kit is far to wide needs trimming back.
Brammer
Your car: Sierra Cosworth
Postby mrorange2 on Wed Dec 21, 2005 11:00 am
so if i trim my arches back it'll be fine? Wish i had spend that lil bit more on the spax vsx kit :( You got any good tips on trimming the arches?
mrorange2
Postby MrRS1800 on Wed Dec 21, 2005 6:26 pm
I didnt get a chance to roll the arches today, i had a look tho and from what i can tell its just catching the lip of the arch. I think its because my alloys suck eggs and have got the wrong offset, there fore sticking out too much. Im going to take a dremel to it tommoro becuase ill have to cut the plastic bit of the arch away before rolling the metal back.
P.S its a Gmax 35mm kit.
MrRS1800
Postby 2iKRIS on Wed Dec 21, 2005 6:42 pm
I used gmax 35mm lowerin springs with 185/55/15 tyres and they dont catch at all apart from on full lock. Im only running on the escort gti wheels though so are prob not as wide as most.
Kris
2iKRIS
Postby Percy! on Wed Dec 21, 2005 6:50 pm
Seems odd, mine lowered slightly more on a 35mm spax kit and I am have no problems, with that my shocks are very hard so don't bounce around too much.
Percy!
Your car: Citreon
Postby dee_RS_2ltr on Wed Dec 21, 2005 8:03 pm
i lowered my old xr2i 35mm on gmax supersport kit and didnt getting any rubbing. but im lowering my RS1800 50mm on friday so i'll see what happens then :D it does look really low in the pic for a 35mm drop tho :-? .
dee_RS_2ltr
Postby MrRS1800 on Wed Dec 21, 2005 8:11 pm
Yer i thought it looked a bit low too. Im wondering if ive been sent the wrong springs or shocks for the front now!!?? I was expecting the front to be about the same as the rear.
MrRS1800
Postby Jay on Thu Dec 22, 2005 1:52 am
this mite not be the problem.. but i would deffinately reccomend doing it even if it doesnt solve it... there is a rubber donut between the top of the suspesion strut and the suspension mounting area on the front. Mine looked lower at the front and I changed these because mine were pretty worn. It raised the suspension up about 8-10mm.... and improved the steering feel of the car aswell...
Formerly Jay246
Jay
Car: 1992 Ford Fiesta RS 1800
Postby MrRS1800 on Fri Dec 23, 2005 1:32 pm
Ive just been outside rolling the arches as best i can. Took it for another spin and its still rubbing just as bad as before. I think its time to take it to a bodyshop and get them to look at it. Anyone know of a decent one near Romford, Essex???
MrRS1800
Postby dee_RS_2ltr on Sat Dec 24, 2005 6:44 pm
no sorry mate. try doing a google search or something.
dee_RS_2ltr
Postby AGAR on Sat Dec 24, 2005 7:02 pm
Bought the same kit off ebay (with -35mm springs) not off the same guy though - bought them from the Fiesta Centre.
What are the part numbers of the 60mm springs so i can make sure i aint got them!
AGAR
Postby chris-fiesta on Sun Dec 25, 2005 10:07 pm
just trim the inner lip m8 and keep the current drop, i think it looks sweet :wink:
chris-fiesta
Postby j7aoc on Sun Dec 25, 2005 10:38 pm
r_bowdidge :Ive just been outside rolling the arches as best i can. Took it for another spin and its still rubbing just as bad as before. I think its time to take it to a bodyshop and get them to look at it. Anyone know of a decent one near Romford, Essex???
R-tec do arch rolling there ment to be the best around there in west london think
j7aoc
Postby chris-fiesta on Sun Dec 25, 2005 11:10 pm
m8 dnt bother with a bodyshop, i modded my arches and im on 17s with a 40mm drop and dnt get no scrubbing!!
the guide on the stites hoepage is ace i did pretty all of what it said to do, cant go wrong :Q
chris
chris-fiesta
