judder under braking
Postby xander7 on Thu Jul 24, 2003 7:12 pm
my si has developed an annoying judder under braking, it is obviously more noticeable de-celerating from high speeds, but it does it at low speeds as well. i suspected the discs and pads were knackered, but i've looked at them, and the discs aren't warped, and the front pads and rear shoes have loads of life left in them.
my tracking isn't out, as that was done recently, so i am now confused as to what the problem is ? can anyone help??
xander
xander7
Postby pugeyed on Thu Jul 24, 2003 7:37 pm
mate when u say u have checked the discs and there not warped , have u just done it by eye or what mate , as i had this with the xr thought they were ok , turned out they were warped , changed em and the pads , problem solved,
cheers mark.
pugeyed
Postby snake on Thu Jul 24, 2003 7:52 pm
need to check em with dial gauge, also pull the handbrake up could be rears
snake
Trainee Burger Flipper
Your car: ford
Postby xander7 on Thu Jul 24, 2003 8:05 pm
i assumed that an uneven surface on the disc would indicate a knackered disc, but mine are perfectly smooth, but grooves or ridges etc.
could the handbrake be a factor then, if so, in what respect ?
xander
xander7
Postby MikeyXR2i on Thu Jul 24, 2003 8:19 pm
no the surface of the disks won't be rough or anything in any way, the disks will be warped through the repeated heat thats put through them when braking. you can't see it by eye. new set of disks i think is called for.
MikeyXR2i
Postby SimonT on Thu Jul 24, 2003 8:27 pm
could also be bent wheel hubs
Too old and too bald.
SimonT
Your car: Fiesta Zetec S TDCi
Postby scudd81 on Thu Jul 24, 2003 8:28 pm
this has happened to me u cant feel it with ur bear hand, when they did mine they checked it the disk was warped. got em changed and problem sorted. if u change pads and disks im pretty sure the problem will b sorted
:Q
scudd81
Postby xander7 on Thu Jul 24, 2003 8:30 pm
bugger, that isn't good if it is new discs, i only replaced them 12months ago, and i was told to bed them in gently for first 1000 miles or so, which i did, and i've still managed to warp them (possibly). will thepads need replacing too, as they have loads of friction pad left.
where do i get hold of a dial guage, and how do you use it to check the disc condition
cheers for help so far guys ;)
xander
xander7
Postby Jockster on Thu Jul 24, 2003 8:35 pm
If you've had them a year m8 I'd change them
I melted a set of disks in a fortnight in january :(
Jockster
Postby xander7 on Thu Jul 24, 2003 8:40 pm
i thought they lasted a tad longer than that though !!!! although i have done about 15k in the last year or so, so i suppose it should be expected !!!
i mite change discs, pads and replace the brake fluid as well, just to be sure !!
xander
xander7
Postby scudd81 on Thu Jul 24, 2003 8:54 pm
if ur changin the disks u might aswell get new pads while the calipers r off.
:Q
scudd81
