John Reid's guide to soldering
Postby Capri on Sat Feb 24, 2007 11:15 pm
[Cut & Pasted from the thread in Styling - Capri]
1) Strip the end of the wire you are using and get a length of heatshrink and put it over the wire you are going to join.
2) With your 2 peices of wire twist both ends together.
3) Wrap a peice of solder arround the joined wires.
4) After you have twisted the two wires together and wrapped solder arround them both you can start to solder.
You have soldered the two wires together - it is now virtually unbreakable aslong as you have done a good job.
5) Now with your newly joined wires - slide the heatshrink which you put on one of the wires earlier over the join.
6) Now all you have to do is heat up the heatshrink to make it shrink (dont overheat it otherwise it will catch fire).
As I said in step 4 - it will be virtually unbreakable - below I will show you a bad solder join and a good solder join :
Bad Join :
Good Join :
hope this helps and is this anywhere near being a guide on how to solder and heatshrink ?
Capri
Postby Smo on Sun Feb 25, 2007 12:40 am
One thing I'll add; It's often a good idea to wait a short while for the join and surrounding wire to cool a little before moving the heat shrink over the join, or the heat coming from it can sometimes shrink it before it fully covers the join :)
Smo
Postby lee si on Thu Mar 15, 2007 10:37 am
very good, what type of soldering iron are using there, i take it that blow tourch is also good for this method,
im off to solder in my mk4 clocks now
lee si
Postby knuckles on Thu Mar 22, 2007 10:33 pm
Excellent guide mate :D
Where can i get that heat shrink from ?
knuckles
Your car: Fiesta Rs turbo
Postby ~ John Reid ~ on Thu Mar 22, 2007 11:45 pm
the sildering iron there isnt the usual one its a weird one which is well....... crap but heats up quick.
Best one for soldering I think is :
http://www.maplin.co.uk/Module.aspx?Tab ... 5&doy=22m3
The one used in the pictures is a solder gun I think.
And you can get the Heatshrink from Maplin :
http://www.maplin.co.uk/Module.aspx?Mod ... k&doy=22m3
~ John Reid ~
Postby gumpy on Fri Mar 23, 2007 1:21 am
great guide mate all i need now is a soldering iron.
gumpy
Location: barry, south wales. drives: fiesta xr2i replica
Postby ~ John Reid ~ on Sun Mar 25, 2007 12:55 am
Dont forget your solder aswell :P
~ John Reid ~
Postby cookie456_the2nd on Mon Mar 26, 2007 11:54 pm
Good guide mate.
Thats how too get a good, proper solid joint.
cookie456_the2nd
Postby rs-tom on Sun Apr 29, 2007 11:05 pm
what about flux?
rs-tom
Postby properphatboy on Fri May 04, 2007 3:25 pm
rs-tom :what about flux?
Solder usually comes with it in nowadays.
properphatboy
Your car: Peugeot 306 D L
Re: John Reid's guide to soldering
Postby Nisi on Tue Nov 04, 2008 8:01 pm
what size heat shrink would i need thanks and were can i get the solder to put around the two wires
thank you
Nisi
Postby Garry J on Sat Nov 15, 2008 12:09 am
Have a look on the maplin website http://www.maplin.co.uk, you can either find a centre near to you and go collect all you need or buy it all online.
I'd recommend going to a store, i'm like a kid in a candy shop when i go in, always come out with far more than i went in for.
Heatshrik comes in two or three different sizes for all thicknesses of wire and solder is available to. You'll have plenty of change from a tenner for both items.
Garry
Garry J
Postby steviesnutz on Wed Mar 09, 2011 11:55 pm
top buy from maplins too is a wee gadget called a micro-jet , it is fueled by cheap refillable butane cigarette lighters, multi use , soldering , heat shrinking and heating siezed nuts etc, cheap too !
steviesnutz
Your car: fiesta xr2i
