i need your opinions on my fiesta rs turbo- work being done
19 posts • Page 1 of 1
right guys i just want your opinions with my fiesta rs turbo as ive finally found a guy to do all the work on my fiesta rs turbo! good rep on the series 1 forum and rs owners club! initially it was having a 3/4 spray as there are small chips and light scratches etc but im thinking just get it all done (it is 24 years old now
other work being done is -
all the horrid abs completely removed, NON abs brake lines sprayed in olive green, new gold unions, driveshafts refurbished in satin black (believe satin was the factory colour?), new brake servo along with master cylinder installed - basically as it came from factory without abs! also new genuine ford wheel bearings and cv joints to put on while its all off!
price quoted for all work and full respray with bodykit off is £3100 - does this sound reasonable?
- rob pace
Re: i need your opinions on my fiesta rs turbo- work being done
Good idea getting the whole car done...Mercury never matches old mercury.
Ive seen some driveshafts in gold zinc colour and others in satin aswell so theres two options.
No real reason for using gen ford wheel bearings as pattern are just as good and alot cheaper.
Zinc unions might be a bit of a mare as you will have to cut and re flare the original break lines which can considerably shorten them, and the flaring tool will not fit on some of the short bends on the lines themselves ( as they turn onto the master cylinder etc). You can get the nuts zincd but it can be graft as the zinc plater will have to hold the whole line whilst he zincs just the nuts.
Pricewise if its cash then thats a fair price...Mine was around the £2900 mark cash.
- RS EDDIE
thanks edd, he has a very good reputation, picking me up etc and showing me stages of the work and removing the kit with me! ive had the rear kit off and rear arches are spot on! but dont know whats hiding behind the front arches
hopefully its as good as the rear, rear offside arch only had a tiny bit of rust smaller than a 5p piece!
thank god the abs is going also!!!
had the front bearings for ages and got them for a bargain price at the time!
- rob pace
If that's all you got at the rear the fronts should be ok mate
- rsturbonutter
- Your car: Fiesta RS turbo
rsturbonutter :If that's all you got at the rear the fronts should be ok mate
hope so, just need to get it running right, but he knows about the running issues!
anyone know if escort rs turbo black rivets are correct for the fiesta rs turbo bodykit?
- rob pace
rob pace :rsturbonutter :If that's all you got at the rear the fronts should be ok mate
hope so, just need to get it running right, but he knows about the running issues!![]()
Rivets are the same Rob 6869991
- JasperJ
JasperJ :rob pace :rsturbonutter :If that's all you got at the rear the fronts should be ok mate
thank you mate, calling for parts uk now to see if they have any!
- rob pace
Tom Peters has packs of 10 on Ebay rob
item no 231162486740 same as escort/fes
- JasperJ
JasperJ :Tom Peters has packs of 10 on Ebay rob![]()
cool, how many does the fiesta rs have in total? cant remember!
- rob pace
microcat says 18 m8 so I assume its 9 per side
- JasperJ
JasperJ :microcat says 18 m8 so I assume its 9 per side
your a star! i could do with microcat! had it on my old pc but not on this one!
- rob pace
be bloody quick rob
Ebay 271388955719
Ebay 271388955719
- JasperJ
They are not the correct ones for the Fiesta RS Turbo - these are specific to the Sapphire Cosworth and a different size to the ones used on the Fiesta.
- tompeteRS
- Authorised Trader
rob pace :i could do with microcat! had it on my old pc but not on this one!
You'll find this site useful then
http://eucatparts.com/?action=cat_ford_ ... d_model=68
- Turboboy67
- Your car: 911GT3 RS
tompeteRS :They are not the correct ones for the Fiesta RS Turbo - these are specific to the Sapphire Cosworth and a different size to the ones used on the Fiesta.
My Bad.
Apologies Rob
- JasperJ
JasperJ :tompeteRS :They are not the correct ones for the Fiesta RS Turbo - these are specific to the Sapphire Cosworth and a different size to the ones used on the Fiesta.
My Bad.![]()
typically I missed the top fixing 1s, bloody Ford 3 different plastic rivets in cossy side skirts.
Apologies Rob
ok mate, are the escort rs turbo ones for the series 2 the same for fiesta?
also why would them cosworth ones not be up to the job anyone know? diameter of the head to big or small? they look absolutely no different in the pictures compared to the series 2 ones on ebay
- rob pace
Price seems to be about right,and yes do the whole car while your at it mate.
Bad thing is you wont want to drive it and get chips lol,just had the rallycar completely done(im a panel beater so did most myself apart from spraying)and its too good to rally now
- rs_fiesta
rs_fiesta :Price seems to be about right,and yes do the whole car while your at it mate.
ill drive it in the summer dont worry
- rob pace
been at fords today on the e-cat system, a guy who owned a 3 door sierra from new was a great help
, got some rivets but i need more so its a start! they are showing new rivets and other rare bits available in Portugal so i need to learn some Portuguese!
there showing new bodykit items aswell so i am going to e-mail them and hope for a reply!
if anyone has all the finis codes for the bodykit that would help!
- rob pace
