Help - Running problems
2 posts • Page 1 of 1
Hello all
I'm in need of a little help if I can please before I go bloody mad !
Here we go.
I have a 91 frst running OFAB, I have a massive over fueling problem and very poor idle. I can get it to run lets say 80% better when either the Map sensor or the Map suppressor is disconnected.
I've changed the following so far for various problems
Map sensor
Crank sensor
Coil pack
Coolant temp sensor
Fuel pressure reg
EDIS unit
C.O pot
ECU
I've had the ecu loom out and pinned out for loom breaks
Could someone give me just a new route to follow please
Ian
Here we go.
Map sensor
Crank sensor
Coil pack
Coolant temp sensor
Fuel pressure reg
EDIS unit
C.O pot
ECU
Ian
- iparkes
- Your car: 91 FRST
Re: Help - Running problems
Update
Have replaced complete manifold now, still over fueling. Has anyone ever had ecu failure on the OFAB ??
Ian
Ian
- iparkes
- Your car: 91 FRST
