Heaters/Blowers??
Postby Starky on Wed Jul 25, 2001 7:13 am
Would you belive it now my bloody heaters/blowers have stopped working as well as my fogs!!!
Does anyone know what the fcuk is wrong with my car?? could it be an electrical fault, battery or somin??
Help please, it's doing my nut in!!
D
:mad:
Starky
Postby Fezzy Turbo on Wed Jul 25, 2001 10:55 am
check the relays. Sounds like you have moved some by accident.
Mine do the same, the heater relay also works the radiator fan as well :eek: so you will need to get it fixed as soon as possible
2009 FRS2 : 377bhp ATW / 395lb/ft :)
1990 FRST : Sold.
Fezzy Turbo
Tartan Turbo Terror
Tartan Turbo Terror
Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Postby Ian C70T5 on Wed Jul 25, 2001 11:06 am
Classic FRST Problem, my old one did it, this one does it, yours does it..
When you look at your relays it the far left middle relay, the green one..
It gets too hot and melts the fusebox and needs wiggling or removing and cleaning..
I have to clean and check mine every few days now..
My old one, had the relay removed and relocated to the side of the fusebox and held on with clips.. Then the wires rewired and redirected, this never failed..
Where as when you look at my latest one, it melts the plastic breaking the contact and turns the FRONT FOGS,Engine FAN and Internal FAN off... NOT GOOD, overheat time...
Hope this helps mate.. :wink:
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby Starky on Thu Jul 26, 2001 5:38 am
Fcuk mine!!
You've just noted every thing thats wrong with my chariot!! (hence all the messages on the board!!) at the moment the fogs don't turn on, the blowers have stopped and the engine fan doesn't turn on either!!! and yesterday I found out that one of my front lights is dimmer than the other(could this be related too?).
Where can I find the relays and what do I need to do to fix the problem M8??
:sad:
D
Starky
Postby Ian C70T5 on Thu Jul 26, 2001 11:02 am
Open the fusebox face in the dash by your right foot, 2 screws... undo these, the fusebox falls out easier and as you look its the relay (green) in the middle far left... wiggle it take it out, clean it, clean the contacts, place back in wiggle, whallla, it works....
The light dimmer than the other wont be related mate sorry, probably a different wattage bulb in each... :wink: or it is blown slightly on one of the fillaments and needs replacing
_________________
<font size=-1>[ This Message was edited by: Ian FRST on 2001-07-26 11:04 ]</font>
Ian C70T5
Das Ist Kapput
Das Ist Kapput
The fog dimmer than the other wont be related mate sorry, probably a different wattage bulb in each... :wink:
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby Starky on Fri Jul 27, 2001 5:07 am
Wicked M8!! Had a go with it last night and sorted the problem and now my fogs, engine fan and blowers are working again!! :grin: :grin: :grin: :grin:
Thanks M8
D
:smile:
Starky
