Guide: Obtaining and fitting a K&N Filter for HCS Engine
Postby RichMk3Fez on Thu Feb 02, 2006 10:43 pm
Hi again,
Ok, guess ill have to suffer it.. I drove the car straight after we fitted it, and it seemed to start 1st time with no trouble. I will give it a go tommorow morning (from cold) and see what happens. Do you reccomend that i leave it open then? As i was considering trying to cover it.
Thanks again,
Rich
RichMk3Fez
Postby AGAR on Fri Feb 03, 2006 4:05 pm
RichMk3Fez :Hi again,
Thanks again,
Rich
I recommend you keeping the standard filter for winter. I learnt the hard way - took about 30mins running the k&n until my carb froze and left me stranded all of a sudden in traffic when the car stopped.
AGAR
Postby RichMk3Fez on Sat Feb 04, 2006 1:44 am
Hi again,
Ok i have kept the old filter in the boot, just incase of any problems. I have a 1994 m-reg, which is the single point injection model as ive been told by many a person. Would this still suffer from the carb freeze as u mention?
Thanks,
Rich
PS. I currently have something blocking that hole up (as mentioned before) so do you think i should keep it blocked, or leave it open?
RichMk3Fez
Postby AGAR on Sat Feb 04, 2006 12:33 pm
Thanks,
Rich
As concerns your engine - if its single point injection as you say it won't have a carb.
For the hole, i'd personally keep it opened - but i don't think it makes much difference whether its open or not.
AGAR
Postby RichMk3Fez on Sat Feb 04, 2006 4:35 pm
Thanks very much, and thanks for all the information you lot have given me.
Started it yesterday morning and it fired up first time, seems to be ok, and im guessing its ok due to the fact its single point injection.
Now to get the exhaust fitted :Q
Rich
RichMk3Fez
Postby AGAR on Sat Feb 04, 2006 9:36 pm
No problem - glad to be of help here for once, rather than asking stupid questions myself :Q
AGAR
Postby jamesworth747 on Sat Feb 11, 2006 2:31 pm
put one of these on and its running at just under 1500 revs is that ok??
jamesworth747
Postby AGAR on Sat Feb 11, 2006 3:05 pm
jamesworth747 :put one of these on and its running at just under 1500 revs is that ok??
Ye need to block off the pipe coming from the carb that used to be connected to the underside of the standard filter. If your unsure what one it is, test it by putting your thumb over the end of the pipe when the engine is running and the revs should drop to a more resonable value.
AGAR
Postby jamesworth747 on Sun Feb 12, 2006 11:22 am
wel ive blocked it now the rev counter is showing 1000 rpm when cold so not 2 bad cheers
jamesworth747
Postby RichMk3Fez on Sun Mar 12, 2006 1:40 am
Hi guys,
After having a few problems with the fez it is now back on the road. Becuase of this, I decided to put my K&N filter back on for a bit of noise :)
So just a quick general question for the experts out their.
Basically, when I fitted the filter on, I was also sent one of the little oil breather filters. Becuase of this, I understood that I didnt need to drill the plate of the K&N and feed a pipe through it, like a normal installation would have??
Anyway...... I noticed that after the filter was fitted on and I started the engine that their was a fair bit of white smoke coming from the oil breather. I was told that these fumes are probably created with the standard airbox, except they arent seen or noticed becuase they are recylced in the back into it? So, my question is.. Is this the case? Or have I got a problem somewhere along the line?
Just so you guys know, almost all the smoke does clear away after the engine has been running for 2-3minutes and I have also driven it on a couple of longish journeys with no problems.
Never the less, any answers would be helpful..
Rich
RichMk3Fez
Postby Jpex on Sun Mar 12, 2006 11:16 am
With mine insted of doing all that with the breather pipe i just bought a little breather filter for £4... still works the same an looks good.
Jpex
Postby the_dude_with_the_food on Thu Feb 01, 2007 9:14 pm
hi guys, just a quick question.
i have a mk4 escort 1.3 carb. when i fitted my k&n and a little breather filter my car seems somewhat sluggish, doesent want to go anywhere. im guessing this is down to to much air goin in and not enough petrol, how can i sort this out? cheers in advance, mike.
Postby HCS PIMP on Sun Jun 03, 2007 10:56 pm
got a filter for the 1.1 sat in my shed yours for 20 posted if u want it
HCS PIMP
Postby DravenFeista on Sun Jul 01, 2007 11:52 pm
id rather have a cone than a panel filter....anway to bodge in on?
i cut some of the sides on my original filter an erm...it makes a luuurrvly noise....it added a bit of oomph as well...
DravenFeista
Postby fiesta crazy on Fri Jul 13, 2007 2:56 pm
I tryed a small breather filter on my oil cap, but when your driving the car, the fumes just come in throught the air vents, how can i stop this happening.
Jack
fiesta crazy
Postby benrob on Sat Aug 04, 2007 11:46 pm
i just seen the pictures of the KnN bolt on u posted up back in this thread and was just wondering what i should do come MOT time as i got one fitted on mine will i have to remove it and replace the old air box or can i leave it on
benrob
Re: Guide: Obtaining and fitting a K&N Filter for HCS Engine
Postby scottmk3 on Fri Feb 15, 2008 11:25 pm
hi sorry for bringing an old post back up, i have a bolt on filer on my 1litre carb engine and to be honest i didnt think much to it even with the carb tweeked and ive reverted back to the standard air box, so my question is, would the K&N replacment filter that they product that fits in the standard air box be worth it?
scottmk3
Postby Tweek on Sat Feb 16, 2008 1:40 am
No matter what you do it won't feel ANY better unfortunately.
Your car: VW Golf GTD
Postby Ollybee on Sat Feb 16, 2008 10:40 am
How come Scottmk3 has got zero posts!?
Ollybee
Car: 1996 Ford Fiesta Quartz
Postby Ratspeed on Sat Feb 16, 2008 1:57 pm
On my CVH i get a bit of oil come out of my little breather filter . All the breathers are unblocked with new rocker cover,cap etc. Doesn't blow the dipstick out so not much pressure crank case wise. anyone else had this?
Ratspeed
Postby Ollybee on Sat Feb 16, 2008 2:05 pm
Common problem. The engine is supposed to ingest it and burn it up, therefore it's not noticed with the normal air box until the element is replaced and the oil is all over the inside of the air box. Only way around it is to put a pipe on the filler cap and run it down to the bottom of the engine bay.
Ollybee
Postby Ratspeed on Sat Feb 16, 2008 5:28 pm
All i did was pipe the breather from the rocker cover into the k&n base plate with a 90 degree elbow and its sorted. I get the odd drip of oil on the inlet manifold but i can live with that
Ratspeed
Postby sterling01 on Fri May 08, 2009 2:53 pm
This thread only mentions the 1.1 and 1.3 HCS engines.
Will this K&N fit on my 1.0 HCS engine?
sterling01
Postby - Danny Boy - on Thu May 14, 2009 2:09 pm
Yep it will do.
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Willhelm on Sun Apr 04, 2010 4:03 pm
i am going to buy a K&N as described above for my fiesta 1.3 CFI !! i was planning on running the pipe from the oil cap to and oil catch tank with a breather ! Will this work ok if i blank of the inlet vaccum hose ??
Willhelm
Previous
