Fuel Pump Not working.
Postby jamesosman on Tue Aug 31, 2004 9:36 pm
Hey guys i have recently put my frst engine back into my cars shell and when i put my ignition on to start it all the lights and stuff come on but my fuel pump is not workin. i have checked that the fuel pump works by overriding the wiring but it just wont go on when i put the ignition on and consiquently want start. Can anybody HELP.
jamesosman
Your car: Ford Fiesta Rs Turbo
Postby Project on Tue Aug 31, 2004 10:38 pm
Check your engine bay earths chap, especially the one from the engine loom to the battery -ve.
/Munk
Project
fiftyoneCL
fiftyoneCL
Postby Ben_frst on Tue Aug 31, 2004 10:42 pm
have u tried the inersher (spelling) switch its located in behind the little flap in the passenger footwell just push the button ontop :D
Ben_frst
Postby manx_boy on Wed Sep 01, 2004 12:19 pm
well my fuel pump has died!! but i tried in the little flap in the passenger footwell just push the button ontop but i tried to start to the engine also there is no buz sound for fuel pump. so that why fuel pump has died. anyway i have to buy new fuel pump
andrew dawson
manx_boy
Postby MFkev on Thu Sep 02, 2004 3:37 pm
Before you go and buy a new pump test to see if there is power getting to the pump, Lift up the rear bench pull the plug off and use a multimeter, should get a reading for a few secs when ignition is switched.
Mr. T once captured Bigfoot, but released him after he shaved the beast and realized that it was just Chuck Norris walking around naked in the woods.
MFkev
Postby jamesosman on Thu Sep 02, 2004 10:17 pm
Yes i have tried the inertia switch and the earths. the fuel pump works but have put multimeter on it and the plug is not getting any power :-? Any more ideas guys?
jamesosman
Postby Hartza on Fri Sep 03, 2004 9:12 pm
jamesosman :Yes i have tried the inertia switch and the earths. the fuel pump works but have put multimeter on it and the plug is not getting any power :-? Any more ideas guys?
Relay in the box? Mine was in bad shape, first it didn´t start every time, then it died completely. Relay was full of rust´n stuff :)
Hartza
