FRST t2 turbo exhaust housing. cheap as.
21 posts • Page 1 of 1
- rob pace
- rst in progress
grind down the side of a bolt so it fits in the hole and use that.
of get it re-tapped.
if you do decide to get another let me have the old one
There is a guy posted in the general thread asking if his knackered T2 is worth anything.. Maybe worth a try
Car is back...
- AndyBlackFRST
- BANNED SELLER
jayrs :get it drilled and tapped, thats what i was gunna do if i was to get it mate
liams who replyed in this post live about 2 miles from me and he has one on a knackered t2 turbo unit.
im awaiting his reply. or pez is going to do it for a charge.
rob
- rob pace
shiftelec :corect me if im wrong was it not a 17mm spaner to undo it?
what it is, its a stud, you screw it into the housing by hand, connect the downpipe up and screw a 17mm nut onto it.
i can pm my address if its ok?
rob
- rob pace
lol the stud is 10mm thread which is a 17mm spanner/socket which u use to undo it the stud its self should be like an exhaust manifold stud threaded at both ends and a shank in the middle, which do you need a die nut or the taps?????
back with the rs badge after a 12yr absence!!!
- shiftelec
- Your car: did have a '90 Fiesta rs turbo
shiftelec :lol the stud is 10mm thread which is a 17mm spanner/socket which u use to undo it the stud its self should be like an exhaust manifold stud threaded at both ends and a shank in the middle, which do you need a die nut or the taps?????
the thread is buggered in the housing, i try and screw a perfect exhaust stud into it and i can turn it a little and it wont move.
sorry not sure of the term "die nut"
- rob pace
you have a tap and die, the tap you use to put a thread in a hole a die is used to put a thread on a bit of bar so you need the tap.
bear in mind its a corse thread mate.
just to throw a spanner in the works the nut on the studs on my FRST and the 1 i stripped and a FRST i got turbo from the other month had 19mm nuts on them
i got a thread gauge and 3 T2's in the shed, if you want i will tell you the size and TPI so you know what thread to put in it.
oh yeah, dont break the tap or your be in the shi t
"to throw a spanner in the works" the socket which fits my T2 IS 17mm which make the teeth per inch thread size 10mm and to quote microcat "10mm" nut and i have just got bloody wet to check this!!!!!
- shiftelec
shiftelec :"to throw a spanner in the works" the socket which fits my T2 IS 17mm which make the teeth per inch thread size 10mm and to quote microcat "10mm" nut and i have just got bloody wet to check this!!!!!
mate im not saying your a lier or wrong, im saying that the few i have use a 19mm nut.
have to say i just checked on a stripped focked one i got and that has 17mm nuts
so fock knows whats going on
maybe the ones ive got with bigger nuts have been refurbed by turbo compaines
